geForce 6800 Problems
Old Jan 5, 2006 | 08:29 PM
MarbleGT's Avatar
'08 MX5 GT 6spd.
In my new comp the geForce 6800 256mb card is acting up. Is anyone aware of whats causing this, can anyone help me. Am i going to have to get another card? I will start a game and it will be fine, then after about a minute or so the game starts to jump and shutter.....PLEASE HELP!!!
Old Jan 5, 2006 | 08:42 PM
TLover's Avatar
What driver are you using?
Old Jan 5, 2006 | 09:00 PM
MarbleGT's Avatar
'08 MX5 GT 6spd.
i got the latest one of the nvidia website earlier, how do i check and see which one im using....bare with me, im not EXTREMELY computer saavy
Old Jan 5, 2006 | 09:13 PM
MarbleGT's Avatar
'08 MX5 GT 6spd.
i have ForceWare 81.98
Old Jan 5, 2006 | 09:45 PM
TLover's Avatar
Is this card replacing an older NVidia card? Did you upgrade the driver recently? You might need to use Driver Cleaner (or other program) to wipe out any old versions of NVidia drivers.
http://downloads.guru3d.com/download.php?det=745
Then do a clean install.
Good luck.
Old Jan 11, 2006 | 10:55 PM
CleanCL's Avatar
how old is the card? does it happen with every game or certain games?
yup like said above. i would first remove any trace of old driver. install a fresh copy. make sure nvidia doesn't require any preqreqs such as latest directx though it shouldnt make that much of a diff.
also in the other post, someone mentioned making sure its clean in there, free of dust.
Old Jan 12, 2006 | 12:03 AM
MarbleGT's Avatar
'08 MX5 GT 6spd.
I fixed it in most games.....i downloaded rivaTuner (geForce specific card customizer) and forced off the fastwrites and disabled all startup programs through "msconfig"......i would say it worked by about 90%. Appearently the later geForce cards have several problems. At least im not the only one!!
System Specs... 1 1/2 week old Dell XPS 400, 3.0 ghz, 1g of ram, 160g of memory, 256mb geForce 6800...<----Should not have ANY trouble with ANYTHING thats out right now.
Old Jan 16, 2006 | 01:45 PM
BC2G's Avatar
Registered Big Dog
i've had that problem before when i had the resolution to great, games require a smaller resolution scale or whatever
Old Jan 16, 2006 | 04:37 PM
Beelzebub's Avatar
I just built a new machine.
Asus A8N Premium SLI Motherboard
Dual core AMD 4400+
2gb Ballix Crucial memory
2 WD 320GB 16meg disks
XFX geforce 7800GT factory Overclocked to 450mhz
This thing flys.
I am Playing fear Maxed out and the thing screams at min 32, Max 190, Avg 78 frames a sec.
Old Jan 17, 2006 | 05:32 AM
Casper42's Avatar
04 TL 6MT NAVI ABP/Q
From your original post, it sounds like your card/system is overheating.
I would make sure that all the fans in the machine including the one on the 6600 are all operating as expected.
In the Advanced Video Settings, there is a Tab for your 6600 and then a Temperature Settings sub item. You can see the video card's temps in there. Just beware that Video cards will drop temps very quickly, so you wanna have this running, then launch your game, and then drop the game as soon as possible after it starts getting twitchy.
PS: Your comment about running "anything" out there right now is a little bit off. I'm running a top of the line machine with a 7800GTX and I can run most games full settings, but some of them still run better when kicked down a notch on the quality/size settings.
Old Jan 17, 2006 | 06:24 AM
Edr0e's Avatar
Refresh rate?
Can your monitor handle it?
Old Jan 18, 2006 | 07:32 PM
tiguy99's Avatar
Sounds like artifacts. Listen to the pros above and tweak your card so its not getting pushed too hard. Kick it down a notch below the tops and your games will love you. My Geforce 6600GT still owns most games I toss its way
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
AcuraKidd
Sep 25, 2015 11:18 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
