could it be?? i think my ps3 died...
Old 07-15-2008, 01:01 PM
Mizouse's Avatar
Received 2,793 Likes on 1,988 Posts
Thumbs down could it be?? i think my ps3 died...
i think my ps3 is dead, i copied over some xvid movies, with my ps3 attached to my monitor. turned it off and moved it over to the plasma TV in the living room. tried turning it on but it beeps 3 times and then has a flashing red light.
i dunno what to do, this is the launch console and my warranty is expired
Old 07-15-2008, 01:07 PM
says "hello to my TLX".
Sun Diego CL-S's Avatar
This is not possible!
I hate saying it but, is everything connected properly? Try shutting the power off with the switch behind the console. What sort of site did you download these videos from anyhow? hehe
Old 07-15-2008, 01:10 PM
Mizouse's Avatar
yea, i hooked it back up to my monitor, still the same thing, switched it off in the back on and off many times.
and the movie was from mininova, harold and kumar escape from Guantanamo bay
Old 07-15-2008, 01:11 PM
Mizouse's Avatar
what sux is that if it cant be fixed, id be stuck with getting a POS 40gb with no BC. and there are plenty of times where i have loaded up ps2 games.
Old 07-15-2008, 01:13 PM
Go Giants
Whiskers's Avatar
Received 1,235 Likes on 824 Posts
Did you spooge on it during the bottomless party scene?
Old 07-15-2008, 01:29 PM
Mizouse's Avatar
umm... now its not doing it...
Old 07-15-2008, 01:44 PM
Ken1997TL's Avatar
Received 2,329 Likes on 1,309 Posts
So its working now?
I'd turn it off using the back switch. Let it sit for a minute and turn it back on
I recently got Oblivion for the PS3 and it ended up crashing during a huge battle and doing the same thing.
Old 07-15-2008, 02:15 PM
What Would Don Draper Do?
JediMindTricks's Avatar
so it's working now?
Old 07-15-2008, 02:28 PM
Mizouse's Avatar
yea its working now, i tried flipping the switch off in the back and it didnt work. so i left it alone for about 30 minutes and now its working again
Old 07-15-2008, 02:44 PM
csmeance's Avatar
Received 2,012 Likes on 1,431 Posts
overheated from watching to much porn on blu-ray is my guess...
Old 07-15-2008, 05:07 PM
'08 MX5 GT 6spd.
MarbleGT's Avatar
Received 1,192 Likes on 485 Posts
^^ Yes.
Old 08-18-2008, 11:30 PM
Mizouse's Avatar
wtf.. my ps3 has been turned off for the longest time, and now it just did the same thing.
Seems to happen everytime i disconnect the HDMI cable from my pS3
Old 08-19-2008, 01:43 AM
fhwagads
FuriousGeorge83's Avatar
its the video settings returning to default I believe. next time try using the regular cables that came with it and see what happens
Old 08-19-2008, 01:48 AM
Mizouse's Avatar
well this is exactly what i did.
I had my PS3 hooked up to my computer monitor via HDMI cable, and audio via optical output to my logitech Z680's.
what i did was, flip the switch in the back, unhook all that, bring it over to the plasma TV in the living room and hooked it up with the component cables that were already hooked up to that TV.
when i flipped the switch in the back of the PS3, the red light would turn on for a split second give me 3 beeps and then flash the red standby light.
anyways its been 2 hours since i tried powering it on, hopefully it works now
Old 08-19-2008, 01:51 AM
Mizouse's Avatar
Old 08-19-2008, 07:03 AM
Go Giants
Whiskers's Avatar
Old 08-19-2008, 09:18 AM
Pete1burn's Avatar
If you change the output or unplug it, it defaults to factory settings for video. You need to hold the power button down when you turn it on until it beeps a few times. I think it's like 5 seconds or something. That will make it output through all of the available ports, and then you can set the output again.
Old 08-20-2008, 01:22 PM
Mizouse's Avatar
I cant even turn mine on.
when i flip the main switch in the back, it normally goes to the red standby light. but for me it goes to the red standby light, then a split second later it beeps at me 3 times and then the red standby light just flashes.
all the other videos i have seen on youtube, people have the red standby light come on after flipping the main switch in the back, and then after pressing the power button in the front only then does it give the 3 beeps and then flashing red light. Mine doesnt even do that.
Old 08-20-2008, 01:50 PM
Nom Nom Nom Nom
SwervinCL's Avatar
Sony sucks.. I went through 2 ps2's. Both are now doorstops..
Old 08-20-2008, 01:53 PM
Mizouse's Avatar
.. what does this have to do with helping me?
Old 08-20-2008, 02:33 PM
Nom Nom Nom Nom
SwervinCL's Avatar
Not really helping you... At all...
Have you talked with Sony to see if there is anything they can do? Or say to help you?
Old 08-20-2008, 02:34 PM
uzzmaan's Avatar
whenever i hear about ps3 issues like this, i bow down and pray mine doesn't die.
Old 08-20-2008, 04:12 PM
Mizouse's Avatar
no not yet, most likely they are going to send me a cardboard box and have me ship it back to them to look at and fix/replace with refurbished unit.
since i wont be living in this address that much longer i am going to hold off.
Old 08-20-2008, 04:56 PM
Nom Nom Nom Nom
SwervinCL's Avatar
You never know. There may be some default system setup thing that is triggering this.
After some googling. Try taking the hard drive out and blow out the contacts, put it back in making sure its snug and then try to turn it on...
I dont have a PS3 so I do not know how easy it is to do this.
Old 08-20-2008, 04:58 PM
Nom Nom Nom Nom
SwervinCL's Avatar
And this
If you have Assassin's Creed in (along with autoplay discs on) without an active Internet connection, this may be the reason. I know this isn't with all cases, but it was with a friend of mine. The game kept trying to look for the update.
Three beeps should be something you hear normally when shutting down the PS3. Just make sure the PS3 is in standby mode (red light) before you EVER decide to flip the on/off switch in the back off.
If all else fails, have you ever had the PS3 connected to an HDTV, or changed the settings to HDTV settings, and then switched to SD, or vice-versa? If so, "...you may find you have a blank screen. Simply reset your PLAYSTATION 3 to restore the default SD setting in the following way: turn off the PLAYSTATION 3 system then press and hold the power button for approximately 5 seconds until you hear a beep."
If pressing the PS button doesn't turn the console on, it should if it's connected with a USB cable. The bluetooth may have been wonky at the time that your PS3 was last shut off.
Old 08-20-2008, 05:25 PM
Mizouse's Avatar
maybe i should make a video of my problem...
Old 08-20-2008, 10:56 PM
^Do it. It might help to catch exactly what's going wrong.
Old 08-20-2008, 11:38 PM
I'm Down Right Fierce!
BraveDemon's Avatar
^ If its not even turning on, I think it might be an issue with the hard drive connection. I would start with the hard drive, and making sure its secure. IF thats not it, I'd assume maybe the harddrive is dying.
I've heard horror stories of the hard drives dying out in these things from less than 10 hours played time.
I pray to god mine doesn't go out.
Old 08-21-2008, 11:36 AM
'Big Daddy Diggler'
bigman's Avatar
i've heard of the system freaking out when switching screens, but nothing like this.
Old 08-21-2008, 08:08 PM
Mizouse's Avatar
wow, i didnt know that the HD was this small..!!
anyways could i hook it up to my desktop and see if it works?
Old 08-21-2008, 08:18 PM
Ken1997TL's Avatar
Its a laptop hard drive..
You could always just buy a new one. Thats one of the best things about the PS3, you can pop in a 500 gig HD if you want
Old 08-21-2008, 09:29 PM
Mizouse's Avatar
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://img.photobucket.com/player.swf?file=http://vidmg.photobucket.com/albums/v61/mizouse/Movie-2.flv">
as you see mine goes directly to the flashing red light after flipping the switch on the power supply, every video i have seen goes to a solid red light and then when they press the power button goes green to yellow to flashing red etc etc.
Old 08-21-2008, 11:45 PM
Wow. WTH. Do you have a repair program from the store where you bought it? Maybe it's still worth sending in to Sony to get fixed.
Btw, are there any recalls(if there are any) for PS3 models that this may fall under?
Old 08-22-2008, 12:03 AM
Mizouse's Avatar
i did buy the extended warranty from walmart, and it is still valid, but it just means they will switch it with a 40gb which i do not want because it does not have backwards compatibility.
and i think a repair from sony would cost 150 bux, so i could get the replacement pS3 from walmart and use that saved money to buy a PS2, but i doubt i would use the PS2 that much, and would rather have a ps3 that could play it should i want to.
Old 08-22-2008, 12:39 AM
csmeance's Avatar
the solution of the problem is very hard to find, the error is common with installing other OS, there are a few simple steps.
1st turn main power off at least 15 seconds
2nd press the start button, hold till it beeps twice
3rd it must beep twice
this will rest the system back to the default setting you will have to reload any themes but all other information will be there like saved games etc.
Old 08-22-2008, 06:28 AM
Mizouse's Avatar
start button, the one on the controller?
Old 08-22-2008, 06:37 AM
Mizouse's Avatar
if so it wont work because it doesnt turn on so there is no way to sync up the controller.
Old 08-22-2008, 10:19 AM
switch with a 40gb and sell it? then use the money towards a BC ps3?
Old 08-22-2008, 02:24 PM
Yes, he did that
Lister00169's Avatar
Tell them to switch it with the 80 GB MGS4 bundle.
Old 08-22-2008, 02:44 PM
Mizouse's Avatar
that probably would be best since they have to give an equivalent priced model right?
since i got mine for $600
Quick Reply: could it be?? i think my ps3 died...
