Worn Tires
Old Jan 18, 2011 | 10:22 PM
r3mix3r's Avatar
Worn Tires
I have about 15k miles on the G37S Sedan and the tires are pretty much bold in the rear. As I've asked around it seems pretty average for the stock summer tires they put on the car. The rear right tire is actually the most bold, and they say that's normal as well. I did the penny test, and looked at the bar indicators, and it seems they are at the bald level of 2/34"...
The question now is living in Florida where it's not raining/snowing right now...how long can I run these tires? The tires are a little more worn out on certain spots than others, but the tread is still visible if that means anything. I have so many expenses that came up recently, I'm not sure if I'm ready to drop a few hundred on the rear tires. They are not rotatable either...I did find some great deals on TireRack, but I just want to know how much longer I can actually safely drive on them, and when are they literally an endangerment?
Thanks!
Old Jan 18, 2011 | 10:43 PM
mcflyguy24's Avatar
They are an endangerment already if they only have 2/32" left. As long as it is dry out you'll have better traction actually, but the second it rains your screwed.
Old Jan 18, 2011 | 11:01 PM
friesm2000's Avatar
B A N N E D
, and iirc with under 2/32's of tread, they are actually illegal to drive on, if a cop wanted to be an asshole
being that you are in florida, with no snow, you can get away with more worn tires, but i have recommend tire on cars at work, because the tread was starting to get low (they still had "life" though technically), but for maximum grip especially in the snow, the customer really should think about new tires though
Old Jan 18, 2011 | 11:05 PM
csmeance's Avatar
Thanks!
As long as it's dry out and you check the tires frequently, you can run them. Being aware of the "penny" trick and being self conscious about your tires shows me that you know when something isn't right with the car. Like I said, check frequently and be prepared to spend the money soon. I'd avoid driving over 60 and as well 100% avoid wet conditions.
Old Jan 18, 2011 | 11:11 PM
lightjak_tsx's Avatar
Nice info thanks
Old Jan 19, 2011 | 02:23 AM
AZuser's Avatar
_
You typically want to start looking for new tires when your tires are at 4/32.
Old Jan 19, 2011 | 03:47 AM
speedemon90's Avatar
Isnt that normally the case for certain tire, like all weather?
Because summer tire's compound is good, when its worn down it wont have better traction.
I know the theory behind it is, with worn tires you have more grip because more rubber is touching the road. But thats not true for all tires, and I think summer is one of them
As for OP just keep an eye on them, and watch out for water patches if they ever show up on curves. Or else on dry roads you should be fine. Keep checking to make sure you arent seeing any cords, or whatever they are called.
Old Jan 19, 2011 | 06:15 AM
dallison's Avatar
registered pw
The question i always ask is, Would you feel comfortable sending your wife off alone in the car?
Old Jan 19, 2011 | 12:59 PM
friesm2000's Avatar
B A N N E D
OP might be
but yes, would he be comfortable sending his wife/partner, with his kids in the back seat out
Old Jan 19, 2011 | 01:56 PM
Moog-Type-S's Avatar
The sizzle in the Steak
Single guys pay no heed to this post, and keep driving.
alex2364's Avatar
This is like asking if you're ok driving without any seat belts on. Sure you're fine, til you crash. And being in FL, I know they have almost daily quick thunderstorms so it's almost impossible to avoid being in the wet.
Old Jan 19, 2011 | 04:20 PM
vas25tl's Avatar
The Box
There's a tire ad at the bottom of your thread. I think that speaks for it.
Get up to $80 when you purchase a set of select Goodyear or Dunlop tires.
On a serious note, I'd replace them as soon as possible. You don't want to risk your life or potentially a terrible accident because you didn't want to spend the money you'll end up spending anyway.
Old Jan 19, 2011 | 06:14 PM
RaviNJCLs's Avatar
You realize that you are trying to milk a set of tires that are already pass the point of being unsafe and you are driving a $35K car. WTF....go buy some tires. It is not worth someone's life.
Old Jan 20, 2011 | 09:14 AM
1StGenCL's Avatar
958 & 991
Yea, you should buy tires but probably can get away with a bit more mileage. You just have to ask, is 1,000 miles or so worth getting in the car, praying it doesn't rain? Does it drive ok now?
Old Jan 20, 2011 | 09:24 AM
pttl's Avatar
My first Avatar....
You drive a G37s and you have "bold" tires....
Get tires.
Old Jan 20, 2011 | 09:51 AM
thevikas87's Avatar
Your mom is in
Go buy new tires.
Worse comes to worst, and you cannot afford two new tires, and you MUST drive it, then buy some used tires after inspecting them thoroughly. I do not recommend this at all, but it is an alternative if you're in dire straits.
Old Jan 20, 2011 | 11:26 AM
jayhawk815's Avatar
Get tires.
This. I can't say that I never pushed the limits with tire wear, but that was in college and was truly broke. If you can afford a g37s, you should be able to properly maintain it.
Old Jan 20, 2011 | 11:33 PM
OperationDarkie's Avatar
Ultra Negro
WTF are "bold" tires, I need to get some of them shits...does it help me perform better on the track? If so gimme your bold tires.
Old Jan 21, 2011 | 01:31 AM
Gfaze's Avatar
S E L L
You should also check out treadepot.com. I've gotten a couple good deals on there.
Old Jan 21, 2011 | 09:34 AM
majin ssj eric's Avatar
Punk Rocker
If you wanna really cheap out you can try one of those used tire places. We have one here in town and they have sets of nearly new tires for as much as 75% below MSRP. Just have to hope they have your size in stock...
Old Jan 21, 2011 | 10:23 AM
fuzzy02CLS's Avatar
If it's dry, & you don't speed around you should be able to get more use. But yeah if it rains & the road is slick you may be skidding. How long are you trying to hold on to them? A few hundred miles should be ok, but don't push it.
Old Jan 21, 2011 | 01:47 PM
Hapa DC5's Avatar
אני עומד עם ישראל
15k out of the tires? Hmmm I'm almost at 7k and my tires are around 7/32 all the way around. I figured I could get 20k+ out of these tires. I also baby the car too.
I'd just get tires man. It does rain even if it doesn't snow.
Old Jan 21, 2011 | 03:50 PM
RedRyder's Avatar
Be a better driver
What do you mean they are not able to be rotated? Even if they are directional, you can still switch the fronts with the rears. Or are the fronts worse?
I'd sell some stuff or take out a loan. If you have to ask if they're okay to drive on, they're probably not.
Old Jan 21, 2011 | 10:38 PM
Hapa DC5's Avatar
אני עומד עם ישראל
Staggered, larger tires in the rear.
Old Jan 22, 2011 | 01:03 AM
friesm2000's Avatar
B A N N E D
i've heard of 8ki miles out of a set of tires, and NO it was not a supercar or anything, but just a Subaru Outback XT (turbo), but i don't think the alignment was perfect from the start though, and babying does help make them last longer too
also don't you mean "It doesn't rain, it POURS"
Old Jan 22, 2011 | 01:09 AM
Hapa DC5's Avatar
אני עומד עם ישראל
I have the same car so I figured 15k seemed a little early for tires.
With him in FL it rains in the middle of summer so I wouldn't be rocking tires that are almost bald.
Old Jan 22, 2011 | 12:36 PM
05TLdcc's Avatar
Coal
Dude just frickin buy tires.
Old Jan 24, 2011 | 12:10 PM
Majofo's Avatar
You'll be fine OP. You'll definitely fail the safety inspection with those tires.
Old Jan 24, 2011 | 03:38 PM
friesm2000's Avatar
B A N N E D
what safety inspection in florida
Old Jan 24, 2011 | 03:41 PM
Majofo's Avatar
lucky.. no wonder the turbo tl started out there.
Old Jan 24, 2011 | 09:33 PM
friesm2000's Avatar
B A N N E D
or emissions (got those here; but only every 2 years though, and to pass that , "all" the emissions equipment has to be on it for visual, then it just has to blow good numbers ; then you will pass)
btw, i have gone through emissions with a bad master cylinder ; it actually went on the way out while driving to the emissions center
Old Jan 25, 2011 | 07:54 PM
RaviNJCLs's Avatar
Have you gotten those new tires yet?
mugen_kid
Nov 13, 2015 10:38 PM
BKSleeper
Oct 7, 2015 10:20 AM
Robospinner
22
Sep 24, 2015 08:47 AM
fallacy
Sep 4, 2015 10:15 AM
