wifes car wont move
Old Aug 25, 2010 | 08:06 AM
01clsstock's Avatar
i am so smart S M R T
Angry wifes car wont move
Well i was goiong to trade in my wifes 04 Mazda 6 for an 06 tl, but thought that would be weird if we both drove the same car. (even if mine is an 05 and different color) So the wife drives her car home yesterday, parks it in our garage which is at the bottom of a slight incline , and goes inside the house. She comes out later to start the car and nothing car wont turn or crank and the key light keeps flashing. Something has to be wrong with the imoblizer and chip in the key. Problem is i cant get the car into gear to push out of the garage to get it towed because its imoblized Should have traded the mazda for the tl. Triple AAA says they can tow it but they will probably damage the car... great.
Old Aug 25, 2010 | 08:26 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Wrong forum.
Old Aug 25, 2010 | 08:28 AM
Turbonut's Avatar
Disconnect the battery for a couple of minutes to see if that makes a difference. You can always override the shift lock through the access "door" on the console.
Old Aug 25, 2010 | 08:31 AM
NSXNEXT's Avatar
Moved to Car Talk
Old Aug 25, 2010 | 08:39 AM
01clsstock's Avatar
Question
can you explain further the access door? this is located in the center stack? or under the car? I disconnected the positive plug from the battery for ten minutes and it still made no difference. Do i have to disco the negative battery connection as well?
Old Aug 25, 2010 | 09:03 AM
csmeance's Avatar
try putting in the ignition in the stall position, that might let the shifter lock let off so you can put it in neutral.
As far as the immobilizer, are you sure that's it? If it's not cranking then I doubt it's the immobilizer as that system just prevents the fuel pump from pumping fuel. It could be the starter or the battery!
Old Aug 25, 2010 | 09:19 AM
01clsstock's Avatar
I can jump start the car but as soon as i put my foot on the brake it dies. Also the key fob wont unlock or lock the car and a red light with a key on it keeps flashing on the dash. (handbook says consult dealership which says i need to bring the car down but car is stuck in park and wont come out regardless of what setting the key is on)
Old Aug 25, 2010 | 09:25 AM
The Dougler's Avatar
Unofficial Goat
Check your owners manual for something called a shift interlock override. Not sure where they put it on mazda's but there will be a means to manually override the shifter interlock.
Old Aug 25, 2010 | 09:49 AM
dallison's Avatar
registered pw
sounds like a remote start or immobilizer.
Can you try another key?
Old Aug 25, 2010 | 09:58 AM
01clsstock's Avatar
i wish dude we only have one key
Old Aug 25, 2010 | 10:21 AM
CocheseUGA's Avatar
Battery and alternator dead?
Old Aug 25, 2010 | 10:53 AM
1StGenCL's Avatar
958 & 991
I searched for a pic of your shifter but couldn't find one for your year. There should be a cover or hole of some sort by the shifter that you can depress with a pen or key to release the shifter. In the pic below, you can see it is on the bottom left. Does your car have something similar? Your manual should help you out too
Edit - did you try a new battery in the remote? I know it doesn't have anything to do with the immobilizer but you say it wont unlock the doors either and it is a cheap maybe fix. Surprised AAA didn't tell you look for the shift override
Old Aug 25, 2010 | 11:09 AM
phee's Avatar
I got the Shifts
its electrical. im guessing battery or alternator
Old Aug 25, 2010 | 11:23 AM
Pure Adrenaline's Avatar
Dragging knees in
Try it with the TL battery in the Mazda.
Old Aug 25, 2010 | 11:58 AM
01clsstock's Avatar
First off Thanks
for all of your replies. This is why i love this site. I am going to take the battery to autozone to test it today after work. If that doesnt work i will release the interlock shift linkage (thanks for the pic , looks pretty similiar in the 04) and have it towed. At least i have a plan now. i ws feeling hopless before
Old Aug 30, 2010 | 07:57 PM
1StGenCL's Avatar
958 & 991
Update?
Old Aug 31, 2010 | 11:12 AM
01clsstock's Avatar
Thumbs up update
All those that said electrical where right on the money. Took the battery out and tested it at autozone. it was shot so i replaced it with a new one. I also cut off and replaced the negative battery connection as the old one was corroded to sh*t. Now the car works mint!!! Good look on the advice
Old Aug 31, 2010 | 02:57 PM
Dragging knees in
Good stuff.
Now trade it in??
Old Aug 31, 2010 | 04:16 PM
mrmako's Avatar
Someday, an RS6 Avant+
Nice. That electrical connection from the ground wire to the chassis is pretty important. once clean and connected, cover with some of that stuff you cover battery terminals with. It's like a grease, but thicker and it will keep away corrosion.
foxriderar77
Nov 19, 2020 10:17 AM
Feb 25, 2020 09:57 AM
Fabian43
Jul 13, 2016 09:07 PM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
kuzdu
Sep 10, 2015 08:42 PM
