Who has what: A Dash cam Story
#42
In all of my dash cam installs, I've been running wire down the passenger A-pillar. Sometimes there's some fuses in the passenger footwell I can tap if I am lucky, but usually I just go behind the glovebox and splice with the cig lighter power.
I've never installed a rear dash cam before, but I think I would probably just run that second wire parallel down the A-pillar, behind the passenger dash trim, and then underneath passenger door baseboard trim. I would probably go back into carpeting to get around the B-pillar before running underneath passenger rear door trim and eventually come back up the C-pillar.
I've never actually done it, but conceptually I think this would work. And messing with floor carpeting is a lot easier than messing with the glued headliner.
juniorbean (02-13-2019)
#43
Tapping the cig lighter would depend on if you want full-time power for 'away recording' (car specific) I know my Mercedes shuts down the cig power when everything else shuts down.
#44
But they do make dash cams with their own battery to come on when they sense motion. I don't have any of these though.
I even turn off the g-sensor on my dash cams that are supposed to save a snippet automatically when it detects a bump. I've found out that over time, bumps will fill up the card with protected files and eventually you're not recording when you think you are. I just want a true set and forget cam till you need it, especially for cameras in my parent's car.
#45
Thanks, still pondering adding a pair to our cars. This has been a good thread for some info.
#46
I got a 5 pack from amazon and with the DC converter it works great! IF only acura's crap batteries could keep up! Thank god for AGM batteries.
#49
Evil Mazda Driver
So far I have had 2 uses for mine but wasn't for idiot drivers. The first was when I had a hug rock kicked up that smashed my windshield. I had proof for insurance to get the window repaired but it wasn't ever needed. Second was just two weeks ago when a large tree branch at work broke of a tree and fell next to my car. It leaned up against the car a little bit. Thankfully I didn't have any damange. The rear video though would have been great evidence to give my work had I needed to have their insurance cover damages.
#52
Null and proud of it
Here's a sample of front and rear footage of my DR750. This is back from when I had the Elantra.
https://youtu.be/WtTou14sgdo
No wrecks??? I want my 3:57 back...
Where was this filmed anyway? I like it!!!
#55
The Third Ball
Received 4,825 Likes
OK quick update.
I've bought one dash cam so far, just installed it in my wife's car. I went with the Aukey as Amazon had it on a lightning deal and it had really good reviews. Seems OK.
I think I'll go Roav S1 for my car. Still looking.
And since both our cars are SUVs and happen to have 12V power in the hatch area I'm thinking of just getting a couple cheap $50 dash cams to run separately in the rear. Much simpler than slaving and running power to a dual system.
#56
The Third Ball
Its the Aukey DR02 btw
#57
Registered RDX Member
Vantrue N2 Pro, 17 RDX
I'm using a Vantrue N2 Pro, dual cam in my 17 RDX. I used the Vantrue Mini USB 12V-24V to 5V Dash Cam Hardwire Kit with Low Voltage Protection to power-up, so draining the battery shouldn't be an issue.
I plugged it into port #28 on the fuse block so it's always on, it does have PARK mode which will detect motion and hits to the car. It's not small enough to hide behind my mirror but my radar detector blocks it from my view.
So far I've had good luck with it (no stories to tell as of yet) and since I can't really see it, I hardly notice it's there.
Mjakaz09TL
09-10-2010 07:42 PM
vp911
220
05-24-2006 11:46 PM
