Well, the TSX needed new wheels....ISF is back (Page 64)
#242
Received 3,664 Likes
Thanks Vinny. You know I can't keep to just one set of wheels for to long of a time so I am sure those or a similar design will be tried in time haha.
#243
Well this past weekend was rather eventful with my trip to IA. The event was a blast and even with the headache of my wheel (now known to be tire) it was still absolutely worth it. Driving on the roads in Buckhead in Atlanta is awesome with the spots that go under the buildings. I would have to stop and fill the tire about every 30-40 miles if I was going 75-80 however I latter slowed down to 65 and managed to get in 120 miles without having to fill it to finish the trip. Should have known better but tried to stay up with some friends on the way home and sure enough had the same results so had to resort back to 65mph after stopping 5 times in the first 3 hours. Pics to come later.
#244
Well got home from work today and sprayed the entire wheel down with soap and water solution. After about 3min I found one small leak on the inside edge of the wheel which was the same side as before. Took it to DiscountTire and after about 5min they were able to reproduce it exactly where I said it was in there tank. So some more bead lock was applied. Guy said to let it dry for a while before I air the tire up. So hopefully this will be the end of my issues. Only good think is the tank proved the same thing I was confident in after my tub test that the wheel itself was not the leak.
Hopefully this will be the end of it.
#245
#246
DiscountTire FAIL!!! I went from one slow leak that I could at least make it the entire way to work on and fill up when I got there and fill it up before I leave to go home to 5 leaks on the back side that loose 1.5psi in 1 hour without even being mounted on the car. I don't know if I should just give it up at this point. Need to go home for the holidays 7 hours and don't know how I am even going to get there. Beyond frustrated at this point.
#247
Your Friendly Canadian
Received 1,484 Likes
Dang, sucks to hear about your problem. Are there any reputable shops in your area now or at home?
Sounds like the pinkies will be making a return on the F.
#249
Damn Jason, what a headache.
#252
Time to find a new tire store.
#253
#254
#255
Finally some pics of new wheels (Which have already been changed)
Ok so after sorting out the leaking wheel and working with the company who was absolutely great and helped me out every step of the way standing behind their product.
I did a shoot back in May of my new wheels on the car and just got around to editing them.
The wheels are ISSForged Spyders in 20x9 and 20x11. Tires are Continental ExtremeContact DW with 245/30/20 front and 295/25/20 rear. ISSForged has given me great customer service along the way with all the questions I had.
I already have changed my mind and they have the wheels back and I am having them refinished in a different color. I should have the wheels back this week or early next so hopefully pictures of those won't take as long.
No more type here are the pics.
#258
That's one sexy ass.
#261
Thats HOT.
How you liking the tires? I have the same on the TL and Love them.
#262
So far I love the tires. I can't even really break them lose at all which kind of sucks sometimes since I like to squeal the tires every once and a while.
#264
I drive a Subata.
Very nice!
#265
tehLEGOman
Received 1,982 Likes
No moar drifting into guard rails this time.
#267
The lips are staying chrome that is all I will divulge right now. I don't want to deal with polishing lips all the time when I will probably average between 20-25k miles a year for the next 2-3years.
#270
fstty I believe you changed the thread title last time so I think it is due for another change
#275
A little interior work now
Picked up some ThinkDesign carbon parts for the interior recently.
The ThinkDesign parts match the factory trim great. The weave size is slightly larger I believe but I could only just make it out when holding it right next to the center console area so you can't tell at all once they are installed. I also got some clear door lights as well to get rid of the red ones.
I included a quick install for the gauge trim. It isn't difficult but figured it might come in handy possibly. The vents are straight forward so and just pop out and the new ones clip right in.
I also picked up a Silver flat bottom wheel from Sewell but I am still waiting on that to arrive. Should have it in about 2 weeks time.
Now I just need to pickup the rear seat divider and maybe the latch to the armrest compartment in silver to finish off the interior.
Vents:
Great attention to detail in the construction
Gauge Trim:
Together:
Install:
Remove this side panel first
You can now pull down the lower trim around the steering wheel. You can remove it if you want but you don't have to.
Remove the left screw to the gauge trim.
Remove the right screw to the gauge trim.
Pop up the clips that hold the leather trim in place.
Remove two top plastic screw clips. After this you can wiggle the trim loose and out of the dash.
Reverse to install.
Before & After:
Clear Lights Before & After:
Vents:
Gauge Trim:
Together:
Install:
Reverse to install.
Before & After:
#278
In the Mid-South meow
Don't know how I've missed this thread, but dang, the IS-F is coming along beautifully! Love the vent and instrument cluster surrounds. Really pulls the interior silver accents together. And the wheels are beautiful. Can't wait to see the final product with the refinish.
#280
Nice stuff Jason! Looks great as always
Are you doing mostly cosmetic changes to the F or will you be doing power/performance upgrades as well? Also, take that damn license plate frame off
