Turbo vs. HP
SHIFT_over.so.I.can.see
Turbo vs. HP
I'm trying to get a physics understanding of why a smaller turbo running at 5PSI will make less power than a larger turbo at 5PSI running on the same engine.
Can anyone help explain it?
at 5PSI, shouldn't the same amount of air be going into both setups? therefore shouldn't the power be the same?
ok, so boviously more heat is lost with the larger trubo since PSI is the same and volume is the same...
where's the heat lost on the larger turbo as opposed to the smaller one?
You also have to consider where the power is being made.
A smaller turbo will spool up quicker giving larger gains down low. However, it will run out of breathe up high; possibly dropping the boost and over heating the air. So while it gives you 5 PSI down low it may only supply 4 PSI near redline. Couple that with less efficiency, greater heating of the air thus less dense of a charge, and you have a lower peak power output.
TheCarBreathesNitrousToo!
Larger turbos are "larger" they carry more air and so they might be pushing 5 psi but its lets just say 1 cubic feet of air compressed at 5 psi whuke they smaller turbo is 1/2 a foot of cubic air at 5 psi.
Originally Posted by civic4982
how does it heat teh air more?
However, scalbert you're helping me understand how the air gets cooled more quickly. thanks.
Still trolling
It's all relative. A larger turbo is only usefull if the intake and engine can handle the larger volume of air. Putting a T04/5 on a 4 cylinder with stock intake manifold is a waste since your spooling is longer and the greater air volume can't be used effectively by the engine.
joflewbyu2
10-08-2015 11:16 AM
