Tundra 86'd for an 86 which was 86'd for a Sequoia
Old 05-10-2023, 10:22 AM
  #3201
LFG RANGERS!!!!!!!!!!!
e30cabrio's Avatar
Received 1,954 Likes on 1,342 Posts
5/8 I went to smog & had numerous, not ready monitors. I did the hellish 5 minutes @55, decel without brakes to 20 stand on your head & remove your bowels 2x & got all but evap ready. Went back yesterday (my B-Day) & it turns out the CEL has not been lighting up, it needs a set of resistors & code on the teensy I was unaware of.
The guy that wrote the code has the fix & will eventually give it to me, he is busy. As I sold my old cluster, I just ordered one on eBay just in case. Worst case, I'll slap the eBay cluster in and get it smogged, come home & reverse the process.
MODDING IS FUN!
Old 05-12-2023, 08:25 PM
  #3202
e30cabrio's Avatar
Mostly blue switch lights achieved, I'm particularly happy with the PSB-1, I got a roll of blue film, cut it to size & put it inside.
Old 05-13-2023, 12:30 PM
  #3203
e30cabrio's Avatar
I am sure it was fine but I was not thrilled with the gap so did this.
Old 05-16-2023, 08:27 AM
  #3204
e30cabrio's Avatar
Guys on the forum are doing this mod, I like it!
Old 05-21-2023, 04:59 PM
  #3205
e30cabrio's Avatar
Some a$$hat in China just tried to steal my Apple ID. Hassle signing back into all my stuff, guess less than getting my sh!t back. :P
Old 05-23-2023, 03:01 PM
  #3206
e30cabrio's Avatar
Radiator has been acting up, got a new OEM Denso.Should I be concerned about this?
I was able to bend most of the fins back.
Old 05-23-2023, 03:12 PM
  #3207
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,394 Likes on 4,939 Posts
I wouldn't accept that.
e30cabrio (05-23-2023)
Old 05-23-2023, 08:05 PM
  #3208
e30cabrio's Avatar
They issued a refund & don't want it back.
Any thoughts on this one?
RadRace 4 Row Aluminum Radiator for 2007-2014 13
$379 RadRace 4 Row Aluminum Radiator for 2007-2014 13 Toyota Tundra Sequoia 4.6L 5.7L V8 8Cyl 2008 2009 2010 2011 2012 2013 Radiators
https://www.amazon.com/gp/product/B09NDJ1429?smid=A1VFTSGS57TMKV
Old 05-24-2023, 10:44 AM
  #3209
e30cabrio's Avatar
Since I am in a time crunch, leaving 3 am Friday for L.A. I just dropped it at the shop that did the bung, they will fix the new broken radiator & install or sell me a refurb & install.
Old 05-24-2023, 11:21 AM
  #3210
rockstar143's Avatar
Received 19,994 Likes on 14,502 Posts
I would have installed that...
especially once it was free.
Old 05-25-2023, 08:34 AM
  #3211
e30cabrio's Avatar
I argued with Amazon about not getting a replacement in a timely fashion so loudly they said keep it & have your damn money.
I need a good radiator to go to L.A. at 3am tomorrow so I took the damaged radiator to a shop, they pressure tested it & found it good, tested mine & it's leaking, they installed the new one, I was running at 205 before pre overflow nipple breakage, now it is 190.
I will order the CSF when I get back from L.A.
After 4 r&rs the bolts to the gas tank straps were a mess.
While it was there, they dropped the tank, welded in studs & put the tank back, now I can drop the tank to my heart's content (none) and not worry about the damn straps. Shoulda been studs in the first place imho.
Old 05-25-2023, 04:43 PM
  #3212
e30cabrio's Avatar
2015 LX570 RSCA switches work! Less amber, moar blue!!!
Also, my first TRD item!
__________________
1StGenCL (05-25-2023)
Old 05-26-2023, 09:19 AM
  #3213
More amber!
Old 05-26-2023, 11:01 AM
  #3214
e30cabrio's Avatar
Soooooooooo, 260 miles in on my trip to L.A. I lost all fuel pressure. Towed to a Goodyear, happy they can get to it in about an hour, not so thrilled to pay 550 to r&r the tank and hopefully install the hose for the last time.
GRRRRR
Old 05-26-2023, 12:12 PM
  #3215
e30cabrio's Avatar
On the rack!
Old 05-26-2023, 12:58 PM
  #3216
e30cabrio's Avatar
It's the hose, other guys used but the mechanic said it is not high-pressure They are ordering the right one & will make sure it is together correctly & it will have a warranty (but I'd have to drive to Indio.
Old 05-26-2023, 02:09 PM
  #3217
e30cabrio's Avatar
These guys are great, they took me to Napa, only local place that has it, (I have this same 50.00 hose at home) so I did not have to pay their markup.
Old 05-26-2023, 02:44 PM
  #3218
e30cabrio's Avatar
The Napa hose is a Gates, the guy put it in and says it is good, I have a warranty so It's Goodyears problem now.
Old 05-26-2023, 06:44 PM
  #3219
e30cabrio's Avatar
Truck is fine, drove the final 100 miles without incident, fuel pressure is higher, I have a 13mm wrench to loosen the retaining nut but not allens, going to buy a cheap set for the truck.
Old 05-26-2023, 11:02 PM
  #3220
adderall or coke?
Glad you made it, you do not miss a beat.
Old 05-27-2023, 05:00 AM
  #3221
e30cabrio's Avatar
Why not both?
The only thing I can come up with on the hose is it's another Amazon knock off. It failed like non submersibles do.
Old 05-27-2023, 06:56 AM
  #3222
e30cabrio's Avatar
I just spent over an hour looking for a freaking cup of coffee. Nothing is open In this part of L.A. but a 7-11 4 miles away.
Good times.
lol
Old 05-27-2023, 03:51 PM
  #3223
e30cabrio's Avatar
I was about to order the CSF but searched reviews & there are several not great ones & it only has a 2 year warranty vs lifetime for Mishimoto so.
https://rcagarage.com/shop/cooling/r...-mmrad-tun-07/
Old 05-29-2023, 11:23 AM
  #3224
e30cabrio's Avatar
Washed the 700 mile L.A. trip off.
civicdrivr (05-30-2023)
Old 05-30-2023, 05:37 PM
  #3225
e30cabrio's Avatar
New easier drain oil filter kit came.
Old 05-31-2023, 10:25 AM
  #3226
with the fumoto on top do you even need to remove it?
Old 05-31-2023, 10:38 AM
  #3227
e30cabrio's Avatar
The filter needs to be drained before it's removed. The oem process has a plate that comes out and a fitting with a hose (if you buy it) or a little doohickey that comes with each filter. The oem housing is a pita to remove. This will simplify the process.
Old 05-31-2023, 08:04 PM
  #3228
e30cabrio's Avatar
3rd cluster was the charm, truck passed smog & is now registered until 5/25. Swapped the 18+ cluster back in. Hopefully we'll be in Mexico before then, if not, I'll swap the clusters.
civicdrivr (05-31-2023)
Old 06-02-2023, 12:40 PM
  #3229
e30cabrio's Avatar
Radiator came, FedEx just dumped it at my door, did not ring the bell. WTF???
Old 06-02-2023, 04:37 PM
  #3230
e30cabrio's Avatar
I like it! Seems lame to remove a perfectly good Desno OEM that's working though.
Bouns air freshener!
Old 06-03-2023, 08:38 AM
  #3231
e30cabrio's Avatar
Our gardner ghosted us about 2 months ago, took us three weeks to find a new one & 2 more to get an appointment.
Laurels run riot is getting exorcised this morning. Adios 500 bucks!
Old 06-03-2023, 11:13 AM
  #3232
civicdrivr's Avatar
A butane torch and an aerosol can seems cheaper.
e30cabrio (06-03-2023)
Old 06-03-2023, 03:49 PM
  #3233
e30cabrio's Avatar
He didn't show up, blamed his employees not showing. WTF????
Old 06-04-2023, 11:19 AM
  #3234
e30cabrio's Avatar
They came this morning, filled the trailer with less than 1/2
Old 06-04-2023, 01:04 PM
  #3235
e30cabrio's Avatar
Project de-laurel is complete, now it's upkeep time.
Old 06-04-2023, 01:51 PM
  #3236
e30cabrio's Avatar
I just went outside, it is 100000% brighter. But on the plus side we had a ton of birds nesting there, they gone.
Old 06-04-2023, 02:44 PM
  #3237
e30cabrio's Avatar
Found this on Instagram, made me count. 30 is my number (current is 5)
rockstar143 (06-06-2023)
Old 06-04-2023, 05:46 PM
  #3238
civicdrivr's Avatar
Did @rockstar143 make that?🤣
The following 2 users liked this post by civicdrivr:
e30cabrio (06-04-2023), rockstar143 (06-06-2023)
Old 06-05-2023, 07:57 AM
  #3239
Received 5,491 Likes on 3,748 Posts
15 here, 17 if I include the Flex & Expedition, 19 for the brief time I also had 2 motorcycles in the garage.
Currently own 3
e30cabrio (06-05-2023)
Old 06-05-2023, 09:37 AM
  #3240
civicdrivr's Avatar
So far, 9 cars, 2 motorcylces. The female would add four to that list but I don't want those cars on my record
Quick Reply: Tundra 86'd for an 86 which was 86'd for a Sequoia
