ttribe's German-Kimchi-Then-German-Then-Blow-Up-Engine-Then-Fix-It Journey Thread
#3801
AZ Community Team
I had new plugs and coils installed on the new engine. Those have been checked and re-checked.
The only code is the ongoing crank position sensor code. We've replaced that sensor three times now.
They also built a wiring harness to bypass the sensor to see if it still occurred (it did and that is the harness that got pinched).
This is a long shot but check if the shop checked all the PT-CAN bus termination resistors in the engine wiring harness. Since they were swapping out a motor and messing with all the ECU sensors/actuators connections, a termination resistor could have been damaged with all the harness movement. A poorly terminated CAN bus can produce intermittent ECU faults and engine performance.
The following 2 users liked this post by Legend2TL:
CLtotheTL32 (02-16-2023),
ttribe (02-14-2023)
#3802
#3803
Sorry to hear of the struggles, but glad you're still partially able to still enjoy is.
Limp mode was what push my uncle to dump his 1995 W140 S420. Going into limp mode at 75mph & having the car arrest itself down to about 30 was not a fun time on a busy CA highway.
#3804
I'll bet it wasn't! When it happened to me, the car put itself into neutral, but I lost power steering. It was pretty unnerving.
#3805
Yeah, his was a 1995 S420, that my grandmother gave them when she upgraded to a 2001 S430.
He dumped it to Carmax & bought a Camry
ttribe (02-14-2023)
#3806
Now that you have BM3. Scroll down to maps and download OTS Stage 2
civicdrivr (02-15-2023)
#3807
Joneill44 (02-14-2023)
#3809
Your Friendly Canadian
Received 1,492 Likes
Well, I'm sorry the problem hasn't been completely nailed down and eliminated yet.
This sounds way better than an out of spec crank or any engine internal problem. That should count as a win.
The following 2 users liked this post by Aman:
civicdrivr (02-16-2023),
ttribe (02-15-2023)
#3810
Certainly not ideal, but I'm glad you ruled out needing another engine. Best of luck, Tim! We're all rooting for you.
ttribe (02-16-2023)
#3811
still running good? ... most of the time?
#3812
The following 14 users liked this post by ttribe:
00TL-P3.2 (02-23-2023),
1StGenCL (02-24-2023),
Aman (02-23-2023),
CCColtsicehockey (06-21-2023),
civicdrivr (02-24-2023),
and 9 others liked this post.
#3813
Nice... by now do you already have a OBDII reader hardwired in your car?
ttribe (02-23-2023)
#3815
#3816
Hopefully this is a new beginning of many troublefree years to come... But you might need to keep a laptop in your car at all times now just in case
ttribe (02-23-2023)
#3817
TylerT (02-24-2023)
#3820
I heard he might even remove his tintz just to be safe
Joneill44 (02-23-2023)
#3821
Assholes.
The following 6 users liked this post by ttribe:
00TL-P3.2 (02-24-2023),
Aman (02-23-2023),
CLtotheTL32 (02-23-2023),
Joneill44 (02-23-2023),
oonowindoo (02-24-2023),
and 1 others liked this post.
#3822
I'm happy for you, Tim!
ttribe (02-23-2023)
ttribe (02-24-2023)
#3825
Turd Polisher
Very very happy for you, Tim.
Crazy how some damaged pins / connector can cause so many issues.
Enjoy the hell out of the car!
ttribe (02-24-2023)
#3826
Gonna be honest here Tim.
You needed a win. Real bad. So I'm happy.
but this did feel like I'm watching a porn workin up a chub...what's it gonna be?!? something juicy? something to gossip about? brunette? redhead?!?!
and the porn started and it was a dude with tiny tits just blowing kisses at the camera but never showing us the goods. very disappointing outcome in that regard.
but honestly...I'm really happy for you. A simple fix is not only something you deserved...it was something you needed.
#3827
Now that that we have a happy ending, any objections to the revised title change of "ttribe's German-Kimchi-Then-German-Then-Blow-Up-Engine-Then-Fix-It Journey Thread"...?
#3829
Options!
#3830
Yumcha (02-24-2023)
#3832
Azine Jabroni
I clearly need to go back and read a bit
#3834
Azine Jabroni
#3837
AZ Community Team
Glad this BMW had a happy ending
#3838
Well, after I last documented what I thought was the solution on here, it started acting up again. I ordered some new wiring harnesses that took several weeks to get here from Munich, but when they got here they were the wrong ones. When my install shop was doing some test driving, they noticed the Auto Stop/Start wasn't working. From previous experience they knew the electrical system had to be in top shape for that to work, so they started doing some tests with a meter and some more driving and isolated a power drop. They tried some new relays in that section of the system and the car magically came alive, again. I've put a couple thousand miles on it since then, including my annual Devil's Highway run in N. Arizona and it is like new again. No issues.
BTW, I didn't notice the Auto Start/Stop wasn't working because I never use it.
The following 8 users liked this post by ttribe:
00TL-P3.2 (06-20-2023),
civicdrivr (06-20-2023),
CLtotheTL32 (06-27-2023),
RPhilMan1 (06-20-2023),
and 3 others liked this post.
