Tire Pressure Question
LIST/RAMEN/WING MAHSTA 짱
We're always talking on here about making sure that the psi in our front tires are about 3 psi higher than in our rear tires to combat "understeer", since our cars are FWD.
Well, my wife drives a 2005 Jetta GLI. It's also FWD. I just noticed today that on the D/S door jamb of her car that the recommended tire psi is 36F/42R! Not only does the higher recommended rear tire pressure confuse me, but 42 psi is a very high recommended psi, and the maximum recommended pressure for the tire is 50 psi (they're Goodyear Eagle F1 GS-D3's).
Can anyone shed some light on the reason for this?
Thanks!
Thanks!
my rule of thumb is: cold tire pressure is 80% of maximum tire pressure
sometimes you can't go with door jambs because those are for factory tires. I don't think Jettas came with GS-D3s from the factory did they? If so, then don't bother going with the door jamb....
You should abide by the label inside of the driver's side door frame. Those are the numbers you want to use.
For example. My '04 manual TL calls for 35 pounds in the front and 32 in the rear, while my '05 automatic says to use 32 pounds all around. Since there is only a 1% difference in weight dispersion from front to rear between a manual and an automatic, one would have to wonder why such a difference in the front tire pressure. It's due to the suspension tuning on the manual versus the automatic.
Your best bet is to go with what Acura recommends. Also, running the tire pressure too high will both shorten the life of the tires and cause uneven wear patterns.
I read that the recommended pressure is what the dealers give you so that you'll get the softest ride while still being safe. They were saying that you could go a few pounds up to get a sportier ride without being detrimental to the tire. On my SI it's recommnded to run 32, I'm running 36 and noticed a slight improvement in the feel of the car. The Max is 42 PSI I believe.
Should I drop back down to 32?
If you can live with a slightly harder ride, pressures between recommended and 40 psi (measured with the tires cold) are fine for daily use.
I'd keep the Psi @ 36 if the feel is preferable- I use 37F/34R on my TL although recommended is 32F/R.
Thanks!
Thanks!
The drive wheels are not the sole determinant of which tires get more tire pressure, and tire pressure is not the car manufacturer's main way to combat understeer.
