Timing Belt Problem
Old Jun 19, 2008 | 09:52 PM
jwest2002's Avatar
7th Gear
Timing Belt Problem
I just change the timing belt on my Acura tl 2004, the mark match perfectly with the camshaft pulley TDC marks and the crank shaft mark, the car do not want to start is this is not my first time changing a timing belt, I guess the Acuras are a little more sensitive on that respect.
Can some one have a answer to this problem I will really apreciate the help
Lou
Old Jun 19, 2008 | 10:17 PM
The Dougler's Avatar
Unofficial Goat
you should have posted in the TL forum. you will get more help there. could you give more descriptions of the problem, what's it sound like etc. if everything is lining up to TDC, that should not be the reason.
1. is it turning over?
2. is the ground cable on the engine mount re connected?
3. did you replace the timing belt on the pulleys in the correct order?
4. Are both the front and rear Cam pulleys correctly lined up?
5. Did you perform a CKP patter clear/learn procedure?
Old Jun 20, 2008 | 12:54 AM
teranfon's Avatar
Moderator Alumnus
If you're confident the timing belt replacement was performed correctly, you may want to consider the crankshaft position sensor, or CPS. Perhaps it was pinched or inadvertently disconnected.
Terry
Old Jun 20, 2008 | 08:40 AM
Zippee's Avatar
It could be something unrelated to the belt-ignition wire not hooked back up or somesuch.
Old Jun 20, 2008 | 06:32 PM
jwest2002's Avatar
7th Gear
What is a ckp patter clear/learn procedure!
Old Jun 20, 2008 | 07:51 PM
fsttyms1's Avatar
Are you sure that it was TDC on the crank and the front cams were at tehir prospective marks before you took the belt off? If so did you by chance unplug or pinch the Crankshaft Position Sensor? If that were unplugged or damaged it wouldnt start. Does the car crank but just not fire? do you hear it hiccup at all?
Old Jun 20, 2008 | 08:10 PM
Unofficial Goat
AFAIK you need an HDS to perform this, and only the dealer has those.
Old Jun 21, 2008 | 01:04 PM
jwest2002's Avatar
7th Gear
The car crank but do not start. the TDC mark are correct in not spark on the plugs I check the coil relay and is ok, the pistons receive gas just do not do hiccup the shafts are turning over and the car do not wan to start
Lou
Old Jun 21, 2008 | 01:21 PM
Unofficial Goat
unplug the battery for 10 min to reset the ecu
Old Jun 21, 2008 | 02:00 PM
BENDER08's Avatar
Back in a TL again.
check your fuses
Old Jun 22, 2008 | 04:41 PM
jwest2002's Avatar
7th Gear
Originally Posted by vetalik
check your fuses
I have to Thank every one for all your help and suggestion, I finally found the reason way the car didn’t start, THE FUSE- I dedicated all this morning to check the fuses and finally realize the problem. The baby ran on the first crank, real smooth. I just have a question for any one who can help, the car is running a little high on the rpm's.The timing is off. Is there any way to adjust the RPM's?
Lou
vaughanml2
Nov 1, 2021 10:16 AM
redsox68
Sep 16, 2015 06:18 PM
merc009
Sep 14, 2015 06:43 PM
asahrts
Sep 4, 2015 05:55 PM
