SuperTrooper169's 2009 Dodge Charger R/T R&T Thread
Old 05-29-2017, 11:00 AM
  #1641
In the Mid-South meow
SuperTrooper169's Avatar
Received 2,145 Likes on 1,096 Posts
Caddy's for 50+.
Old 05-29-2017, 04:45 PM
  #1642
CLtotheTL32's Avatar
Received 9,502 Likes on 6,173 Posts
I can't believe it's been 4 years already!
SuperTrooper169 (05-29-2017)
Old 05-29-2017, 06:57 PM
  #1643
JT4
CTSV,TL, Audi Q7 & A5SB
JT4's Avatar
Your car looks better today than it did four years ago..
Old 05-30-2017, 10:43 AM
  #1644
rockstar143's Avatar
Received 19,984 Likes on 14,494 Posts
You're not 50?
Old 05-30-2017, 10:47 AM
  #1645
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
J's 50.. but you're only as old as the woman you feel
Old 05-30-2017, 10:57 AM
  #1646
Mmmmmm....
Old 05-30-2017, 12:23 PM
  #1647
I definitely feel 50 some days.
Old 05-30-2017, 12:31 PM
  #1648
ttribe's Avatar
Received 5,923 Likes on 2,920 Posts
You and me both, my friend.
Old 05-30-2017, 12:33 PM
  #1649
you feel 50 what?
Old 05-30-2017, 12:35 PM
  #1650
50 teets
Old 05-30-2017, 12:36 PM
  #1651
denzeltrainingday.meme
Old 06-19-2017, 08:55 AM
  #1652
This happened on our road trip to Savannah, GA and Charleston, SC last week. Sapphire averaged 20.45 mpg over the 1,100 mile round trip. Not her greatest showing of mpg, but no more cylinder deactivation so it comes with the territory. It'll only get worse once the gears go in. Gotta pay to play I suppose.
Old 06-19-2017, 11:30 AM
  #1653
The Third Ball
Sarlacc's Avatar
Received 4,937 Likes on 2,627 Posts
now you're getting it!
Old 06-19-2017, 12:06 PM
  #1654
CCColtsicehockey's Avatar
Received 3,764 Likes on 2,539 Posts
I came in here expecting to finally hear the gears were installed.....but no.
At least you have learned to live with cylinder deactivation turned off. One step in the right direction
Old 06-20-2017, 09:35 AM
  #1655
I'm a slow learner.
I've had so much other stuff going on I haven't had time to track down the bolts/nuts that attach the driveshaft to the diff. They're proving to be difficult to find.
Old 06-20-2017, 10:35 AM
  #1656
Ahhh I thought it was just a direct bolt up replacement
Old 06-20-2017, 10:58 AM
  #1657
Kind of sort of is, but it uses a different back section of the drive shaft from an SRT, so instead of a 3 bolt flange on the diff it has a 4 bolt. I found the rear section of the driveshaft and the coupler that goes in between them, so the only thing left is the 8 bolts that connect everything together. I've read it's best to not re-use the ones you take off, which I'd only have 6 of anyway, so trying to figure out their part numbers and how to get a hold of them has been rough.
Old 06-21-2017, 07:40 AM
  #1658
Oh yeah I do remember you mentioning that now. Crazy how they are different for just a gearing change.
Old 06-21-2017, 09:39 AM
  #1659
Chrysler had some odd things going on with the diffs from different years, no pun intended. For instance, 06-08 SRTs with the 3.06 open diffs used a 4 bolt flange until they switched the open diffs to 3 bolt flanges in 09 and up SRTs, except for the Getrag equipped cars, which used a 3 bolt flange from the begining, which just so happened to be the same 3 bolt flange used on 09-10 R/Ts with the 2.65 open diffs, but the one advantage of 09-10 R/Ts were they had thicker, more sturdy axles than the 06-08 SRTs, so earlier SRT owners would swap in the R/T axles. So in theory, I'll have the best of both worlds; a stronger 4 bolt flange with the thicker axles that came on my R/T. Confused yet?
Old 07-28-2017, 10:51 AM
  #1660
I finally found my nuts.
Old 07-31-2017, 10:14 AM
  #1661
I've got my lube.
Old 07-31-2017, 10:16 AM
  #1662
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
nuts and lube... woohoo...
Old 07-31-2017, 10:33 AM
  #1663
I know right? Gathering the parts for the install has been incredibly time intensive, so I'm trying to have fun with it so I don't lose interest and pull my usual sell and move on routine. Only a tool or two more to get then it's install time.
Old 07-31-2017, 10:37 AM
  #1664
get those nuts lubed already
Old 08-22-2017, 11:07 AM
  #1665
No update on the diff as I just haven't found the time to make the install happen yet. One of my front Goodyear F1 Supercars went flat on me this weekend. I didn't realize the inside was down to the cords. Thankfully it didn't blowout and just went flat when we parked at a restaurant to eat. Got two new Nitto Motivos the next day to replace the F1s. I've been happy with the rear Motivo 255s, so went with the stock 245 size in the front.
Flipster23 (08-22-2017)
Old 08-22-2017, 11:09 AM
  #1666
KaMLuNg's Avatar
dat blue...
Old 08-22-2017, 11:10 AM
  #1667
Wow...lucky it just went flat, man.
Looking good!
how have you not slapped some 20MM rear spacers on that bitch yet? Would really set off the aggressive rear end look.
And don't tell me you haven't thought about it or that I'm an idiot or a pussy or anything like that either. I know you were about to.
Old 08-22-2017, 11:16 AM
  #1668
Oh I have definitely thought about it. I'm even considering widening the rear wheels so I can throw so bigger tires on there, especially if I do go with a cam down the road. Charger guys drop these wheels like the plague so I can pick up two more cheep and have a wheel shop widen them to 9" so I can run at least a 275s on there. Either way I could run a decent sized spacer on there to push them out a little more, too.
Old 08-22-2017, 11:18 AM
  #1669
yay.
Old 08-22-2017, 11:21 AM
  #1670
Besties again?
Old 08-22-2017, 11:23 AM
  #1671
uh. that never changes, you know that.
Old 08-22-2017, 11:27 AM
  #1672
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
Get a room.
Old 08-22-2017, 11:32 AM
  #1673
2 Queens?
Old 08-22-2017, 11:33 AM
  #1674
Flipster23's Avatar
1 cup....
That was so wrong, on so many levels. I Iz soory.
Old 08-22-2017, 11:34 AM
  #1675
1 King it is!
Old 08-22-2017, 01:17 PM
  #1676
You can come crown my throne anytime you want.
rockstar143 (08-22-2017)
Old 08-22-2017, 01:23 PM
  #1677
Received 5,440 Likes on 3,721 Posts
Hope you like the Motivos, I didn't care for them on our Flex & went with Michelin Pilot Sport AS3+ this time. Plain amazing.
Old 08-22-2017, 02:28 PM
  #1678
Thanks. I know people have mixed feelings on them. I've had the backs on for 20,000 miles now and they've served me very well. They still have tons of meat left and they hook pretty good. I think they're more of a compromise between comfort and performance than the Pilots which are definitely geared more toward the performance side. Tread life and ride quality are just as high on my list of priorities.
Old 08-22-2017, 03:13 PM
  #1679
They weren't bad when we bought the Flex, unknown mileage at the time.
The AS3+ have some great treadlife reviews & I'd gotten the recommend from an admin on another forum that has them on his Livernois tuned Escape.
Old 08-22-2017, 04:01 PM
  #1680
Your Friendly Canadian
Aman's Avatar
Received 1,485 Likes on 1,049 Posts
I know they're not a recent purchase but you really made a good decision with the wheels.
Sucks to hear about the tire. Any idea why the inside got so worn down? Alignment issue or something?
Quick Reply: SuperTrooper169's 2009 Dodge Charger R/T R&T Thread
