Scion tC makes 327whp and 320 ft/lbs
Dyno vid:
http://www.scionspeed.com/turbotcdyno2.mpg
Dyno graph:
Stock internals @ 12psi.
Looks a little lean to me, especially in that 3.5k-4.5k rpm range.
Dyno graph:
Another vid, Save as:
http://www.tctunerz.com/component/op...atid,77/id,30/
I've never really taken a look at these cars. They are uber cheap! Might be a replacement for the CL-S in a few years. Can you get navi in the tC?
Originally Posted by Crazy Sellout
:torquesteer:
Some say the same about the CL with high horsepower, which is untrue. Can't vouch for this car since I haven't driven it but I'm sure an LSD will soon be available, it might already have one. I don't know much about these cars yet.
Untrue? My modded TLS had terrible torque steer Heard the 6-speed CLS is much better though.
Maybe you are use to your car now.
Originally Posted by Zapata
Yes.....but honda engine doesn't need that much boost to get that much power. Hence, honda engines > *
Depends on the engine though.. A good competitor to the Scion's engine is my Accord's 2.4L I-4. I have a feeling both would perform similarly under boost
Originally Posted by cusdaddy
Gotcha
nod.....just a honda fan that's all. Other very capable engines. Just my personal pref
A honda engine wouldn't make that much torque.
that's a 2.4L i4. that's alot of displacment. Until recently no honda engine had that much. Look at the stock k24 block with the RSX-S head. Nearly 200ftlbs of trq. I'd argue you'd see the same amount in a similar sized engine.
Not as of late. The new Camry is plauged with electrical problems and rattles.
well yah... but i didnt say Toyota is problem-free. every manufactor has their problems .... B-U-T....
AS BAD AS CLS???
and would u rather have electrical problems or every auto 5speed in the company has tranny issues??
Every 5 speed auto doesn't have issues. Everyone knows that, well except for you. There's only a 15-20% failure rate. Of course eventually all transmissions will fail, but from wear and tear, not the design defect.
EDIT: I have over 80,000 rattles on my CL-S and the only rattle I have comes from the license plate frame on the bumper.
Who said only 15-20%?
HONDA? and u believe what they said?
_______________________________
all my friends who drive CLS/TLS have at least replaced their tranny once.
anyways.
it is a known fact that toyota is known for reliability and Honda is for bang for the buck
Honda actually said less than 2%. The general concensus on the forum is that its about 15-20%
Yes Toyota is reliable, but they aren't bullet proof and when it comes to power, the Honda motors out there now trounce all over Toyota
^ Which isn't installed in any Toyota currently sold in the US. Slightly altered for a few Lexus applications, but it isn't nearly the same as the Supra.
Also, we were talking 4 cylinder.
Doesnt matter that it isnt installed in any current toyota he stated that Toyota engines > then Honda engines, and that is true Toyota has made better engines the obvious 2jzgte. And 3uz-fe, 2zz-ge, 7mgte, and i guess if you would like to talk 4 cylinder no honda 4 cylinder will match the 3sgte that the MR2 Turbo's came with
so over all if we are talking about stock engines that the car makers made for their cars throughout the years Toyota > then Honda, but if your talking as of right now currently and talking just 4 cylinder i will give that to you the K series Honda motor blows the GTS 2ZZ-GE away "i think" mod for mod stock for stock
i didnt say Toyota is bulletproof and they are not. but in general they are the closest one to Bulletproof.
and now ur talking about power/engine again, i never said Toyota's engine>Honda's NOR Honda's > Toyota's . because i dont know.
