RSX specs needed
Old Jan 25, 2007 | 02:26 PM
aznboi2424's Avatar
RSX specs needed
Looking into a base RSX and have a few questions about the engine. when is the vtec engagement point? or is the ivtec variable at different rpms? because i heard about something for 2200 rpm. and i think that the dual stage intake opens at 4600 rpm, if im wrong correct me. thanks.
Old Jan 25, 2007 | 02:34 PM
LuvMyTSX's Avatar
You may also want to try clubrsx.com
Old Jan 25, 2007 | 05:55 PM
signalpuke's Avatar
K20a3-Acura Rsx Base and Civic SI models come in with 9.8:1 compression and 2 liters of displacement. The Base motor is rated at 160hp at 6500rpm and 141lb-ft at 4000 rpm. This motor does not use the conventional VTEC mechanism from the earlier B series motors but does have VTC. Instead it only has 2 cam lobes on the intake side and 1 on the exhaust lob. This motor has no VTEC mechanism on the exhaust cam and runs on 12 valves before 2200rpm with the other 4 slightly opening. It also has smaller ports than the Type S and Type R. The motor comes with a 5 speed transmission instead of the 6 speed and has no LSD
K20a2-Acura Rsx Type S has 11.0:1 compression and 2 liters of displacement. The Type S is rated at 200hp at 7,400 and 142 lb-ft at 6,000 rpm. This motor also comes with a 6 speed transmission with no LSD. It has the same VTEC mechanism as the older B series motors but with the addition of VTC.
Old Jan 25, 2007 | 06:22 PM
afici0nad0's Avatar
http://forums.clubrsx.com/forumdisplay.php?f=17
notfast
1/2G MDX (2001-2013)
Mar 28, 2023 08:10 AM
cycdaniel
Dec 17, 2019 10:58 AM
proxus
Sep 16, 2015 06:18 PM
nuldabz
Sep 3, 2015 05:49 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
