Rear tire wear
Old Dec 23, 2014 | 11:32 AM
myke's Avatar
Rear tire wear
Had an alignment did on an 04 acura tl. Zeroed out the toe.rear tires continue to wear every few weeks.should I have weight loaded the vehicle before the alignment. Would putting bump stops on rear struts stop this horrible rear inner tire wear.i have had the car aligned and adjusted 3 times in 4 months.my rear tires are shredding from inside.Burnt out 5 tires on rear .
Old Dec 23, 2014 | 11:35 AM
post up your alignment sheet so we can see whats going on
Old Dec 25, 2014 | 09:59 AM
YeuEmMaiMai's Avatar
any adjustable parts installed? Might want to consider it... 3g TL have issues with rear suspension geometry loaded vs. unloaded...
Old Dec 25, 2014 | 10:47 AM
myke's Avatar
Yeah, I had rear adjustable camber arms put on.would bump stops solve the problem or do I need to try another alignment shop.I've tried 2 different shops already.
Old Dec 25, 2014 | 11:16 AM
the best place to get an alignment is the dealer imho. All they do is work on Honda / Acura and they will be able to get it right for you.
Old Dec 25, 2014 | 12:07 PM
myke's Avatar
Old Dec 25, 2014 | 12:09 PM
myke's Avatar
http://i725.photobucket.com/albums/ww252/mytrin36/Mobile%20Uploads/20141223_133222_zps2kwsupxc.jpg
Old Dec 25, 2014 | 12:15 PM
brian6speed's Avatar
Lone Wolf
I bet the toe bolt for the rear is moving when you hit bumps/potholes.
I installed adjustable arms and locked out that bolt so it can't move.
Old Dec 25, 2014 | 04:07 PM
myke's Avatar
Thanks.Im going to try that.How did you lock out that bolt.
Old Dec 25, 2014 | 04:59 PM
Legend2TL's Avatar
AZ Community Team
What bolt are you referring to?
Acura online store : 2004 tl rear lower arm parts
Old Dec 25, 2014 | 07:18 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
I think there was a TSB for this issue awhile back
Old Dec 25, 2014 | 08:19 PM
Will Y.'s Avatar
Registered but harmless
Maybe.
Is your car a non-Navi?
If so, there was a TSB for it, per this thread: https://acurazine.com/forums/tires-w...e-done-601284/.
Welcome to AZ.
TSB 05-050 for '04 and '05 TL with Turanzas (which I think were TLs without Navi units)
See https://acurazine.com/forums/third-g...-016-a-613659/.
Old Dec 25, 2014 | 08:25 PM
NBP04TL4ME's Avatar
Old Dec 25, 2014 | 08:42 PM
myke's Avatar
Nope, mine is an 04 Navi tl
Old Dec 26, 2014 | 12:20 AM
Will Y.'s Avatar
Hmm... My 5AT Navi TL came with Michelin MXM-4s as OEM.
IDK if the Turanza tires were OEM on the TL by region, Navi or transmission type.
There shouldn't be any suspension differences between Navi and non-Navi versions, but there are slight suspension & tuning differences between the 5AT and 6M versions.
I'd get the bump stops regardless-- it can't hurt, given the tire wear you're experiencing. The alignment specs look good.
KB1_EJ6
Nov 13, 2016 09:51 PM
gqdabien
Sep 8, 2015 11:41 PM
asahrts
Sep 4, 2015 05:55 PM
