Problem: loose, odd steering/ride
Old Oct 6, 2008 | 03:14 PM
hveagle's Avatar
I drive a 2005 Accord sedan and I've been experiencing a really loose steering feel of late. It's hard for me to describe exactly -- it just feels like the steering has a lot of "play" and the steering response is not as tight as I remember it. The steering effort also feels a bit lighter than normal.
Also, there seems to be a excessively floaty feel and excessive body roll on turns (more so than normal, I should say -- I know that the Accord is no sports sedan).
I've actually had the car checked out twice, once by my local guys and once by a dealer service center, but they both said that they could find nothing wrong...
I'm at wit's end here. Any suggestions?
Old Oct 6, 2008 | 03:48 PM
dallison's Avatar
registered pw
has it always been like this and how long have you had the car
Old Oct 6, 2008 | 06:46 PM
hveagle's Avatar
The car was bought new, I'm nearing the four year mark.
And, no, the car had a significantly tighter/better feel originally.
Old Oct 6, 2008 | 07:22 PM
Street Spirit's Avatar
Check the tire pressure.
Old Oct 6, 2008 | 07:34 PM
The Dougler's Avatar
Unofficial Goat
look at all the ball joints and suspension bushings.
Old Oct 6, 2008 | 08:10 PM
dallison's Avatar
registered pw
my uncle has a 2007 and said he will not buy another accord. he had a 97 camry since new and put on 200k
Old Oct 6, 2008 | 08:23 PM
TheMirror's Avatar
Disinformation Terminator
How many miles on the car? Several of those symptoms sound like deteriorating shock absorbers.
Old Oct 7, 2008 | 05:06 PM
hveagle's Avatar
Thanks for the responses, guys.
Street Spirit -- the tire pressure is ok
The Dougler -- are these areas that I should have checked specifically, or is there a general tune-up or inspection that also includes these items?
TheMirror -- approx. 57K on the car. The thing is, the dealer said that the shocks and struts were within spec...
Old Oct 7, 2008 | 05:19 PM
Unofficial Goat
Well they are areas that if worn out could produce symptoms similar to those you are describing.
Old Oct 7, 2008 | 07:14 PM
KaMLuNg's Avatar
are you talking about a dead spot in the steering wheel??? where it feels like you move the steering wheel before it grabs the actual wheels???
Old Oct 9, 2008 | 02:05 PM
hveagle's Avatar
Kamlung: at times, it does seem like there is a slight delay in the steering, but it's hard to say if that is from a dead spot rather than from something suspension related...
It seems like the consensus is that I should have my suspension checked?
Old Oct 9, 2008 | 03:18 PM
FiveLiterCheater's Avatar
have the fluid flushed and refilled
Old Oct 10, 2008 | 10:30 AM
vas25tl's Avatar
The Box
Kamlung:
That would be the first thing I'd do... control arms, ball joints, cv joints, cv boots, etc....
Old Oct 10, 2008 | 10:50 AM
TheMirror's Avatar
The struts in my TSX started to go really soft at almost exactly that point; a 2005 car with about 55K miles. It maybe wasn't as pronounced as you describe, but it was significant. Wish I could drive the car in question, I'd be able to give you much better feedback..
Good luck,
-Mirror
Old Oct 10, 2008 | 05:32 PM
hveagle's Avatar
Mirror -- Thanks for the feedback. I wish you could drive the car, too. For that matter, I wish that I could have an Acurazine mechanic
That sounds like the likely culprit... Did you experience similar steering sensations?
Old Oct 10, 2008 | 06:25 PM
mcflyguy24's Avatar
Just guessing but it's probably your shocks at the mileage your at. My 02 TL def feels much less responsive now at 64k than it did at 38k. I bought some tokico hps shocks and am awaiting new springs. Every car I've owned the shocks started getting weak around 50-65k miles, but still "within spec".
ITSJESTER
17
Dec 6, 2018 02:29 AM
dainmezron
Oct 16, 2015 06:56 PM
Houston
Oct 8, 2015 01:27 AM
Skirmich
Oct 1, 2015 12:59 PM
hrothgar02
Sep 28, 2015 11:08 AM
