Problem with gf's car
Old Aug 17, 2006 | 09:46 AM
mc_yanzo's Avatar
Masshole
Hey all, my gf's 95 Chevy Cavalier is having a problem that I feel you experts can diagnose...
Sometimes the car starts on the first try, other times it takes 10 times before it starts. There has never been a time when I could never get it started and had to leave it. When the key is turned and it does not start, the engine only turns over once then dies, and there is no clicking sound that I hear. It almost sounds like it's gonna start, then nothing. I do hear some fan or belt sounds coming from the engine, but those sounds stop once I return the key to the off position.
What could be some potential problems? I'm thinking spark plugs, fuel filter/pump, or ignition...?
TIA
Old Aug 17, 2006 | 09:59 AM
SwervinCL's Avatar
Nom Nom Nom Nom
Starter?
Old Aug 17, 2006 | 10:03 AM
SakiGT's Avatar
Sounds like the starter to me as well. Usually an easy take old one out, put new one in job. I did my alltrac's in a half hour.
Old Aug 17, 2006 | 10:07 AM
Crazy Bimmer's Avatar
Well if it turned over then dies then i woudnt say its the starter.
Old Aug 17, 2006 | 10:31 AM
S A CHO's Avatar
That was uncalled for...
I'm also thinking starter because of the clicking sound,also spark plugs if its not firing correctly, or spark plug wires which can corrode, especially ones that are 10+ years old...
Just a couple thoughts to get the ball rolling...
Old Aug 17, 2006 | 12:41 PM
mc_yanzo's Avatar
Masshole
2 things that I think you guys misread:
S A CHO - There is no clicking.
Jesal - The engine doesn't necessarily turn over and die, it seems like it is about to turn over but it doesn't.
Thanks for the help. I'm going to start with the spark plugs and work my way to the starter.
Old Aug 17, 2006 | 12:48 PM
crazymjb's Avatar
Check the battery terminals too, yes, it could be that simple.
Mike
Old Aug 17, 2006 | 12:49 PM
S A CHO's Avatar
[QUOTE=mc_yanzo]
[QUOTE]
Crap, I misread your post...
But still check the plug wires, its worth a shot...
Old Aug 17, 2006 | 01:08 PM
SodaLuvr's Avatar
I'm thinking fuel system...
Perhaps Fuel Filter and/or sending unit, or may be fuel pump itself. Just a guess though.
Old Aug 17, 2006 | 01:10 PM
Moog-Type-S's Avatar
The sizzle in the Steak
Battery and terminals...check them.
Old Aug 17, 2006 | 02:13 PM
NSXNEXT's Avatar
Fuel pump, fuel filter.
When was the last time it has a tuneup?
See how easy it is to replace the fuel filter.
The other thing I'd do is put a 1/2 can of Seafoam in a full tank of super unleaded gas. Sounds like maybe it just needs to be cleaned out.
Old Aug 17, 2006 | 02:15 PM
SodaLuvr's Avatar
I'm starting to think that it may be a sending unit or pump issue as fuel filter alone shouldn't cause such serious "starting" problems. Clogged fuel filters usually cause driveability issues...but I could be wrong.
Old Aug 17, 2006 | 02:26 PM
mc_yanzo's Avatar
Masshole
I think the car has had at least one tuneup in the past 25,000 miles, but not sure...
I'm gonna check the battery, terminals, and spark plugs tonight.
Old Aug 17, 2006 | 03:09 PM
BlueCLS6's Avatar
ex 6 Speed owner :(
When my Accord was having starting problems, it turned out to be the main PGM-FI relay. It just sometimes wouldn't click over to run the fuel pump. Sometimes it would start, but sometimes it would take 5+ tries. If all else fails, maybe look into that...
Old Aug 24, 2006 | 04:27 PM
mc_yanzo's Avatar
Masshole
Update - It was the starter. All fixed! Thanks for the help.
Old Aug 24, 2006 | 07:54 PM
GreenMonster's Avatar
You should buy her a decent car instead of blowing all that money on Sox tickets
Old Aug 28, 2006 | 12:11 PM
mc_yanzo's Avatar
Masshole
Tell me about it!
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
jfman55
Sep 5, 2015 02:55 PM
jordanboi
Sep 5, 2015 01:33 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
