Porsche Carrera GT - 0-192mph (video)
man, I searched and didn't find it..... my bad. I've never seen it before.
Originally posted by SFLA_Type-S
How much does that car cost?
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
Originally posted by srika
about $440k, not including dealer markup..
there are a good amount of dealers out there not asking for markup and there are still build dates available
Jim in case you forgot about the specs of this car, here's a refresher. I think you could MAKE yourself like this car.
Engine
No. of cylinders
Displacement
5.7 liters
Maximum power (SAE)
605 hp @ 8,000 rpm
Maximum torque
435 lb-ft @ 5,750 rpm
Maximum engine speed (revs)
8,400 rpm
Compression ratio
12.0 : 1
Transmission
Layout
Rear-wheel drive
Gearbox
Six-speed manual
Clutch
Two-plate ceramic dry clutch (Porsche Ceramic Composite Clutch)
Limited-slip differential
Multi-plate with locking under power and on overrun
Running Gear
Front suspension
Double wishbones with inboard spring-and-damper units
Rear suspension
Steering
Power-assisted rack-and-pinion steering
Brake
Porsche Ceramic Composite Brake (PCCB) with 14.96 in (380-mm) ceramic discs internally vented and cross-drilled, six-piston monobloc aluminium fixed calipers front and rear
Traction control/ABS
Traction control with ABD and ASR; ABS 5.7 (four-channel system)
Wheels
Front: 19 x 9.5
Rear: 20 x 12.5
Tires
Front: 265/35 ZR 19
Rear: 335/30 ZR 20
Weights
Unladen weight (DIN)
3,042 lbs (1,380 kg)
Performance
Top track speed
205 mph (330 km/h)
0-60 mph
3.8 secs
0-124 mph
9.9 secs
50-75 mph
4.0 secs (in fifth gear)
Quarter mile
11.4 secs @ 131 mph
Dimensions
Length
181.61 in (4,613 mm)
Width
75.63 in (1,921 mm)
Height
45.91 in (1,166 mm)
Wheelbase
107.48 in (2,730 mm)
Luggage compartment volume (VDA)
2.2 cu ft (63 liters)
72 liters non US markets
Tank capacity (refill volume)
24 US gallons (92 liters)
Engine
Water-cooled, naturally-aspirated V10 with 68-degree angle and four valve heads; engine mid-mounted with longitudinal layout
Specific output: 105.5 hp (SAE) per liter
Dry-sump lubrication with nine-fold oil pickup for optimum performance under all load conditions
Titanium connecting rods for smoother and more immediate engine response
VarioCam® variable valve control on intake camshafts
Electronic engine management (2x Motronic ME7.1.1)
Aluminium twin-flow resonance intake manifold
On-board diagnostics for monitoring the emission control system
Stereo lambda control
Transmission
Rear-wheel drive
Six-speed manual gearbox; transverse layout with transmission oil cooler
Limited-slip differential with locking under power and on overrun
Two-plate ceramic dry clutch: Porsche Ceramic Composite Clutch (PCCC)
Chassis
Double wishbones with pushrod actuated spring-and-damper units on front and rear axle
Forged magnesium wheels with high-speed Michelin tires (front: 19 x 9.5 with 265/35 ZR 19, rear: 20 x 12.5 with 335/30 ZR 20), central locking system and tire pressure monitoring
Body
Open-top two-seater layout with two-piece detachable hardtop in carbon fiber
Carbon-fiber chassis (consisting of monocoque, windscreen surround and supplemental safety system)
Carbon-fiber carrier for engine, gearbox and rear suspension with a honeycomb core
Engine carrier bolted to rear of monocoque as second fully stressed member
Frameless doors in carbon fiber with integrated side-impact protection
Front/rear lids, rear side panels and sill panels in carbon fiber
Front and rear aprons in plastic
Automatically extending rear wing
Underbody panelling with rear diffuser
Electrical systems
Remote central locking
Electric windows with door-seal protection
Power release lids
Electrically adjusted mirrors with internal heating
Single-blade windscreen wiper
Safety
Porsche Ceramic Composite Brake (PCCB) with 14.96 inches (380-mm) ceramic discs internally vented and cross-drilled, six-piston monobloc aluminium fixed calipers front and rear
Traction control with ABD and ASR; ABS 5.7 (four channel system)
Driver and passenger airbags, side airbags
Bi-xenon lighting system with halogen auxiliary lights and integrated headlight cleaning system
LED tail-light technology
Anti-theft protection system with infrared interior surveillance
Electronic engine immobilizer
Engine
No. of cylinders
Displacement
5.7 liters
Maximum power (SAE)
605 hp @ 8,000 rpm
Maximum torque
8,400 rpm
Compression ratio
12.0 : 1
Transmission
Layout
Rear-wheel drive
Gearbox
Six-speed manual
Clutch
Running Gear
Front suspension
Rear suspension
Steering
Brake
Wheels
Front: 19 x 9.5
Rear: 20 x 12.5
Tires
Front: 265/35 ZR 19
Rear: 335/30 ZR 20
Weights
Performance
Top track speed
205 mph (330 km/h)
0-60 mph
3.8 secs
0-124 mph
9.9 secs
50-75 mph
Quarter mile
11.4 secs @ 131 mph
Dimensions
Length
Width
75.63 in (1,921 mm)
Height
45.91 in (1,166 mm)
Wheelbase
Engine
Transmission
Rear-wheel drive
Chassis
Body
Electrical systems
Power release lids
Safety
this is a current porsche
navtool.com
31
11-16-2015 08:30 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
navtool.com
09-25-2015 05:15 PM
