Police siren and speaker
Old Apr 29, 2011 | 12:09 AM
mrconnecticut's Avatar
2004 Acura TL
my friend was selling his for dirt cheap so i decided what the hell let me just buy it to use for hollering at girls with the the speaker lol anyways my question is how do i install this? the speaker has two wires coming off of it ( blue & green ) and the siren box has two wires also ( brown & black ) that connect the the green and blue ones but which color goes to which? there is also another 2 wires which are red and black which obv are positive and negative. any help would be appreciated thanks
Old Apr 29, 2011 | 12:16 AM
mrlal8's Avatar
this will not help you get girls lol
Old Apr 29, 2011 | 12:23 AM
2004 Acura TL
it's a joke. i guess if nothing is in red texts on this forum everyone takes everything serious.. lets stick to the question though, thanks
Old Apr 29, 2011 | 12:45 AM
renedcruz's Avatar
'That's what she said!'
Old Apr 29, 2011 | 12:59 AM
2004 Acura TL
Old Apr 29, 2011 | 06:03 AM
ggesq's Avatar
Old Apr 29, 2011 | 06:07 AM
paperboy42190's Avatar
these are simple 12v source wires...hook it up to a switch, a signal wire. or whatever you want
Old Apr 29, 2011 | 07:28 AM
LoveMyTL-S's Avatar
Look at the brand and model, google it to see if there is a manual for it.
Old May 2, 2011 | 09:49 PM
2004 Acura TL
im not good with these things so more info would be greatly appreciated
Old May 2, 2011 | 10:05 PM
most wires in the car are 12v sources. you see how theres 2 wires coming out of the siren? now im not familiar with sirens but there are 2 possibilities:
1. one wire is positive 12v and one wire is negative. so it will make sound whenever it received signal from the source.
2. one wire is positive 12v and one wire is signal source. so the 12v is for the source of power and whenever the signal wire receives signal it makes a sound.
Old May 2, 2011 | 10:19 PM
2004 Acura TL
so where should the signal source wire be connected to?
Old May 3, 2011 | 01:05 AM
Drewman752's Avatar
The thing you talk into?
Old May 3, 2011 | 08:35 AM
HighRevving's Avatar
I am tempted to inform you that it is illegal in at least some states to use law enforcement sirens, lights etc.. But I won’t as I am sure you already know and/or it is legal in your state.
Old May 3, 2011 | 09:41 AM
nfnsquared's Avatar
Good grief. What, are you 21 or something?
Never mind, answered my own question...
Old May 3, 2011 | 10:25 AM
av2600's Avatar
Then you probably shouldnt be messing with your car's electrical system
Pay someone to install it, pimp.
Old May 3, 2011 | 10:28 AM
Comptechtl2367's Avatar
I would say pay someone to install it or have the friend you got it from put it in... or just dont put it in at all!!!
Old May 3, 2011 | 03:30 PM
LasVegasTL's Avatar
+1
Old May 3, 2011 | 06:50 PM
2004 Acura TL
good grief. what, are you 50 or something? go spend time with your wife and not your computer
Old May 3, 2011 | 06:51 PM
Drewman752's Avatar
Alright ladies, lets keep it legit. I don't think this should turn into a pissing match.
Old May 3, 2011 | 06:52 PM
tones160's Avatar
[x] FWCC [x]
Epic thread lmao, once you get that girl you'd like to holler at...let us know.
Old May 3, 2011 | 07:47 PM
VQPower37's Avatar
is it done being installed? i would like to c a vid on how it works
Old May 3, 2011 | 07:53 PM
Steven Bell's Avatar
You guys better read this.....
If this is going go turn into a pissing match, this thread will be closed and summer vacations will come early....first and last warning.
Old May 3, 2011 | 08:17 PM
tones160's Avatar
[x] FWCC [x]
True true, I always wanted to do that but over here once you get caught you will be charged for Impersonating a law enforcer. That's a serious charge. Just like having probe lights, you're able to have them installed but you can not run with them on.
Old May 3, 2011 | 09:58 PM
CL6's Avatar
CL6
My only car is a Bus
The box gets a hot wire and a ground and the speaker should plug into that if the box supplies the power to the speaker if not you'll need an amp in there. You should use an inline fuse to protect your vehicle's electrical system once you find a terminal. You have to figure out if you want it hot all the time or only when the car is running or if the key is in the accessory position.
If you don't know how to do that pay someone to do it for you.
Old May 3, 2011 | 10:18 PM
Sal's Type S's Avatar
What brand is it, looks like a FED signal. some have various wires for the horn so when you hit the car horn it will change the siren tone (intersection mode) also some are for radio rebroadcast so you can hear the radio out side car. some even have a mode that use the door or park switch so it wont work with door open or in park so when you get out of car chasing I mean the officer gets out the siren dont blast his ears off.
Old May 4, 2011 | 08:15 AM
charliemike's Avatar
Fahrvergnügen'd
Old May 4, 2011 | 09:28 AM
CCColtsicehockey's Avatar
Old May 4, 2011 | 12:26 PM
Ken1997TL's Avatar
Red text = Sarcasm
Old May 4, 2011 | 01:32 PM
Mr Marco's Avatar
Good lord, you-all are a bad influence. If he told you he bought a used cop car you'd all tell him to smoke the seats because it will get you high.
Here's my best guess. The green from the siren is a ground wire(this can go directly to the body of the vehicle). So the blue wire is for the signal output from the unit. The red wire is the power supply(hot). The yellow might be the output to the speaker. Not sure why the gray & brown are wrapped together. Sometimes there are remote power wires that are needed to operate the system(they need power from the ignition or the unit will not work). These might be the case with the two that are tied together(although these are usually blue). Looks like the pink was never used. Occasionally there are wires that connect to the two way radio in the cruiser so that they can listen to the radio outside the vehicle(to hear calls). Maybe that is the function of the pink wire.
Old May 4, 2011 | 03:27 PM
Osamu's Avatar
can't tell, but I know some PA systems require a amp, but if that's all he had installed previously and it worked, maybe it's built in.
Maybe just hook up the power and ground to a car or computer, and see if you can get it working before you bother installing everything.
my friend had one in like high school, and quickly proceeded to get a ticket for playing ice cream truck music.
Old May 4, 2011 | 04:24 PM
juniorbean's Avatar
Red text = Sarcasm
FWIW, the red text was edited in later... it wasn't originally posted with it... hence the mocking replies to the "girls" comment. I think we should put it back to the original
Old May 4, 2011 | 05:38 PM
stangg172004's Avatar
_____ like a rabbit
Terrible idea. My former friend back in HS had one and also had a blue LED bar that flashed. Nothing like a cop car but it was enough to put him in cuffs in the back of a squad car when he got caught cruising around with the light on beeping his horn. Not cool.
Old May 4, 2011 | 07:18 PM
tones160's Avatar
[x] FWCC [x]
So where does this story ends? 5yrs behind federal prison?
Old May 5, 2011 | 05:01 PM
_____ like a rabbit
No. He got some sort of citation. I dont remember the specifics.
Old May 5, 2011 | 05:18 PM
Moog-Type-S's Avatar
The sizzle in the Steak
Old May 5, 2011 | 05:33 PM
JS + XES's Avatar
I drive a Subata.
now.. what the f is this for again?????
Old May 5, 2011 | 05:46 PM
tones160's Avatar
[x] FWCC [x]
o_0?
Old May 5, 2011 | 06:10 PM
TylerT's Avatar
Turd Polisher
Old May 5, 2011 | 08:19 PM
Mr Marco's Avatar
Old May 5, 2011 | 08:20 PM
Ken1997TL's Avatar
