Patch, Plug or replace?
Old Jun 17, 2012 | 04:27 PM
WILLDOGS's Avatar
I shave my change purse
So while visiting my pop today, I noticed a screw in his front right tire on his Cadi DTS
Uploaded with ImageShack.us
You guys think that this could be patched or plugged? Or would he need replacement? The screw is about 2 inches long and air started to escape as we pulled it out so I screwed it back in quickly.
Reason I ask is because it is so close to the sidewall
Old Jun 17, 2012 | 04:31 PM
It's Clutch's Avatar
Hello Officer
Replace. Can't fix something on the shoulder.
Old Jun 17, 2012 | 04:35 PM
umcp's Avatar
+1 on replacing. It's basically on the sidewall.
Old Jun 17, 2012 | 04:37 PM
WILLDOGS's Avatar
crap thanks
Old Jun 17, 2012 | 04:57 PM
Majofo's Avatar
Nope.. I've had several much lower on the side. Take it a reputable tire shop. If they say replace, tell them to fuck off.
I think you can patch, any lower, plug. As long as you don't mind a bent slim jim sticking out.
Old Jun 17, 2012 | 05:00 PM
PyroDave's Avatar
replace. not worth the risk, let your pops have peace of mind, especially on these nyc streets $150 doesn't compare to peace of mind on a new tire
Old Jun 17, 2012 | 05:12 PM
charliemike's Avatar
Fahrvergnügen'd
I had the same type of screw in my tire because the dealer doesn't sweep their floors.
Turned out it wasn't even long enough to pierce the outer rubber.
Might be nothing.
Old Jun 17, 2012 | 05:21 PM
speedemon90's Avatar
Patch wont work, at least at firestone, i've had it farther away though. I think its too close to the side to plug as well since there's a lot more pressure there especially when you are turning.
Also if there's a nail in the tire, leave it in there, dont attempt to pull it out. Normally it will hold the air good enough for you to take it to a tire shop nearby.
WILLDOGS's Avatar
Yea I think I'll just take him to get it replaced tomorrow. I don't want him driving around with a plug or patch near the sidewall now that I think of it.
Might be nothing.
Old Jun 17, 2012 | 05:32 PM
SpiderX1016's Avatar
The sidewall flexes too much for a patch to hold and at that angle, it won't sit flat.
You can probably plug it and have it hold but I wouldn't. I don't touch anything 1-2" from the sidewall. Too much of a liability.
Old Jun 17, 2012 | 05:37 PM
Majofo's Avatar
Old Jun 17, 2012 | 05:50 PM
CLtotheTL32's Avatar
I got "screwed" last year and had to replace the tire...
Old Jun 17, 2012 | 06:17 PM
Majofo's Avatar
Old Jun 17, 2012 | 06:43 PM
subinf's Avatar
One on the right for me
Replace. Too close to the edge
Old Jun 17, 2012 | 06:47 PM
Hello Officer
This nail is closer to the shoulder portion.... which shouldn't be patched.
Old Jun 17, 2012 | 07:08 PM
fuzzy02CLS's Avatar
I'd try a patch 1st. I also have had damage in this area. It was close, but it was just enough to patch. Held for well over 2 years. Problem is most tires shops will not do it for liability reasons.
Old Jun 17, 2012 | 07:35 PM
subinf's Avatar
^ - Yep. I'd send them home. Or quote them for a new tire.
Old Jun 17, 2012 | 08:59 PM
Will Y.'s Avatar
Registered but harmless
Might be nothing.
I'd have the tire shop pull the screw to see if it was long enough to pierce the tire all the way through.
If the screw went all the way through, your father should get a new tire.
If not, your father need not get a new tire.
Old Jun 17, 2012 | 09:04 PM
WILLDOGS's Avatar
Lol, for the 3rd time, the screw has pierced the tire. Air came out when we started to pull the screw out.
Thanks again all
Old Jun 17, 2012 | 10:00 PM
StreetKA's Avatar
you'll be fine plug it
Old Jun 18, 2012 | 02:02 AM
v6cord2k5's Avatar
seizure force field!
Neither. Leave the screw in place since the tire isn't leaking.
Old Jun 18, 2012 | 02:23 AM
SodaLuvr's Avatar
If the other tire on that axle has less than 1/2 left, I usually replace the other tire as well. This is optional, but I am pretty picky when it comes to tires.
But as the others have mentioned, replacing the tire is the safest option here. No legitimate tire shop will patch that damage, though you could try a plug yourself but YMMV.
Old Jun 18, 2012 | 05:51 AM
Legend2TL's Avatar
AZ Community Team
replace it, your life is worth more than a $200 tire
Old Jun 18, 2012 | 12:45 PM
WILLDOGS's Avatar
Thanks again all, he is all set after a trip to Mavis tire this morning.
That screw cost him $170...sucks but what can you do
Old Jun 18, 2012 | 02:14 PM
Majofo's Avatar
Did he keep it as a spare?
cycdaniel
Dec 17, 2019 10:58 AM
PeterPort
Oct 14, 2015 06:19 AM
Allen_442
Sep 8, 2015 06:01 PM
NSolace
Sep 3, 2015 08:14 PM
quake97
Aug 30, 2015 07:57 PM
