Oil Drain Bolt
Oil Drain Bolt
I am a noob at oil changes but whenever I try to change the oil on one of my cars I always have a hell of time getting the oil drain bolt off. Any ideas or words of wisdom?
Some misleading advice here.... NEVER use a breaker bar to reinstall a drain plug, more and more cars are using aluminum oil pans your sure to strip the oil pan with a breaker bar. A new crush washer is by no means required every oil change, when I had my Acura I drove 42k miles and change on the factory washer and not a drop of oil dripping anywhere.
If you are using a breaker bar to break the drain plug free make sure you (i) are using the right size socket and (ii) that it is a 6 point socket. Other wise doing an oil change is about as basic of a repair one can perform, lefty loosey, righty tighty. If your still having problems go to the gym and start lifting some weights.
IBankMouse
06-13-2020 01:53 PM
neuronbob
23
07-16-2019 11:48 AM
STL TL-S
09-23-2015 09:52 PM
