Oil change washer help??
Hi i did my first oil change today and i bought an oem filter from a honda dealership. The worker asked if i wanted a washer and i said yes. The washer they gave me had an aluminium outer side of the circle and a rubber inside of the circle. The washer looked different as that one that i took off. I also googled the part number that he put on the receipt "94109-14000" and it does not match what with he gave me. Do you think it will be fine?
Never seen that type of oil drain plug washer before for Honda's, seen similar types for some American engines. I'd be a little leary of using something else and would have insisted on the traditional Honda aluminum crush oil washer.
FWIW, I coat the aluminum crush washers with a little Permatex Aviation gasket sealer on both sides before using them. Adds some sealing and fastening protection.
cast.aluminum
Jan 9, 2016 09:33 PM
