The Official Honda S2000 Thread
Old 10-05-2015, 01:22 PM
  #6081
rockstar143's Avatar
Received 19,994 Likes on 14,502 Posts
it's not his height, it's his girth
  #6082
dude...I'm 230 lb and 6'1" and I fit in an S2000 like a glove...even after knee surgery, bending to get my left leg in is the worst part and it's still not unbearable.
Old 10-05-2015, 01:29 PM
  #6083
Turd Polisher
TylerT's Avatar
Received 3,017 Likes on 1,515 Posts
I was just about to say & congratulations! ......
But Flipster fooled me.
With dealer photos.
Old 10-05-2015, 02:09 PM
  #6084
I drive a Subata.
JS + XES's Avatar
Received 2,603 Likes on 1,571 Posts
I'm 6'0" 150lbs & though it's been a while, don't recall any discomfort, cramped cabin feeling when I've been in/driven any S2ks.
I'm 6' 150lbs too. Never felt comfy driving a S2K for more than 30 minutes for some reason. haha
Old 10-05-2015, 02:14 PM
  #6085
Turd Polisher
TylerT's Avatar
Probably because your blinker fluid was low
Seriously though, my mom's AP2 is much more comfortable than mine because it has stock suspension, plush new RE11s, and the seats have much better cushion.
I daily drove that car for a few days and despite my car having more vroom vrooms, I hated getting back into it
Old 10-05-2015, 02:21 PM
  #6086
Received 6,105 Likes on 4,006 Posts
6' and 150lbs? You skinny!
I'm 5-8 and 180, I fit in the S2000 just fine.
Old 10-05-2015, 03:51 PM
  #6087
Chapter Leader (Houston)
TLDude876's Avatar
Received 1,085 Likes on 810 Posts
I'm bullshitting around at the dealer... Driving cars seeing how the try to bend you over on a s2k 24k 50k miles.... I've decided that my black ass can't fit inside one that well.
When you're not bullshitting you'll make yourself fit. I remember researching and a few months later I was at a car meet and a guy had one selling. I sat in it and immediately stepped out with the excuse that I can't fit. Maybe because the car had flames on the paint job but my mind was sort of against that particular car to begin with. 6 months later a fellow azine buddy bought one and brought it over for me to check it out. One whip around the block and I made myself fit. Needless to say I had my s2k in my garage 6 days later. It is not the most comfortable car but the fun factor outweighs all the negative points. BTW I'm 6'2" /225 lbs
Old 10-05-2015, 06:58 PM
  #6088
damn dennis...with stats like that any chance to pm me nudez?
Old 10-05-2015, 07:39 PM
  #6089
TLDude876's Avatar
^ clear your inbox
Old 10-05-2015, 07:40 PM
  #6090
We're chapter leaders...we gots space, ninja
Old 10-06-2015, 08:51 PM
  #6091
Turd Polisher
TylerT's Avatar
Sanding & shaping are done! Paint should be going on in the next few days, or whenever I have time.
So, remember that idle issue I was having?
Despite cleaning IACV, replacing the TPS sensor, running gas treatment, etc .. my idle issue came back (it was especially bad if I didn't start my car for 3-4 days or my AC was on).
I was a little frustrated, so I popped my hood and pulled all of my coilpacks to see if any spark plugs were loose and they all checked out OK, but there was a shit load of white residue on the coil pack & spark plug (cylinder 3)
Cleaned the plug chamber with carb cleaner, wiped everything down, installed a new Denso coilpack and it ran it for about 20 minutes w/ the AC on full.
Idle issue is gone.
I don't want to jynx it... lets just hope it's fixed this time.
Old 10-06-2015, 09:19 PM
  #6092
Turd Polisher
TylerT's Avatar
Calling Spark plugs gurus
The interwebs says white residue means cylinder 3 is running lean.
Could this be caused by a bad coil pack? Bad plug?
Old 10-07-2015, 08:16 AM
  #6093
Received 8,711 Likes on 6,718 Posts
Usually injector issue I believe. Have you done any injector maintenance? perhaps a can of Berryman's B12 in the gas tank might help. perhaps maybe Cyl 3 injector is clogged (but not to the point of CEL, yet).
If i were in your shoes, a can of B12 Chemtool would be the cheapest approach (costs like 3.50 on amazon?) last time J and I bought them
TylerT (10-07-2015)
Old 10-07-2015, 10:16 AM
  #6094
oonowindoo's Avatar
Received 4,273 Likes on 3,050 Posts
With the amount of miles you have on that thing. Just get all the them replaced if they have not been replaced before.
I mean the coil pack and spark plugs all together. There are only 4 of them.
Edit:
Nevermind you already replaced the coilpack. The white residue could be from hardcore racing and drifting even the spark plugs were in Vtec.
TylerT (10-07-2015)
Old 10-07-2015, 10:23 AM
  #6095
Turd Polisher
TylerT's Avatar
4 fresh Iridium spark plugs are sitting in the garage right now and I ordered some of that B12 Chemtool mentioned earlier in this thread.
Best thing to do is to check the coils / plugs after a few months and report back
Old 10-07-2015, 11:16 AM
  #6096
On the plug or between the coilpack and the plug? If it's on the plug then lean condition. If between the coil and the plug then corrosion issue. Spark plugs are great areas for water to pool and with the amount of electricity that goes through that area, it's a great opportunity for corrosion. Clean it up and put it back together.
If on the plug, change it out or clean it with some fine steel wool. IMO, change them all out if you have a lean condition.
If you're filling your car up with top tier (or other good) gas, it will contain enough detergents in it to prevent injector build up and build up on the intake valve. Most of those cleaning products don't do much to a fuel system run with good gas. If it's an injector issue, it'll usually be because of a bad solenoid in the valve and that's not something the cleaner will fix.
For that little money though, can't hurt.
Edit:
Huge +1, swap them all with the mileage you have. I would swap them every 60k miles, it's not all that expensive to do. Not like you have a V12 Mercedes with two plugs per cylinder.
TylerT (10-07-2015)
Old 10-07-2015, 11:56 AM
  #6097
Turd Polisher
TylerT's Avatar
Interesting, maybe the ignition coil seal wasn't 100%?
I detailed my engine bay by coating it with degreaser & removing it with water, that's the only instance where water would have been under my hood. Can't think of any other way.
Unfortunately, I didn't have the time last night to take out & examine each plug, just each of the 4 coil packs.
Thanks for the information Sam!
Old 10-07-2015, 12:41 PM
  #6098
Take out and examine each plug. If it's just one plug that's running lean then that points to a different issue than if they all do.
It's easy to get corrosion even with humidity and salt water air like where you live. It doesn't take much. Clean it off with a wire brush and reinstall. Make sure it's sealed up nice and tight.
People always say great things about California cars but if they're from the coastal areas, corrosion is just as (if not more) likely than ones from the midwest just due to the salt water in the air.
IMO, the best ones come from an area with a high desert. Cool, dry conditions are the best.
Old 10-07-2015, 12:52 PM
  #6099
TLDude876's Avatar
Ha! That's what clogged my fuel injector. Trying to be ocd and washing the engine bay. Did all of this start happening after you did the wash?
Old 10-07-2015, 01:22 PM
  #6100
Turd Polisher
TylerT's Avatar
My car had spuddering issue(s) prior to washing out the engine bay, but it symptoms were definitely much worst after it.
Damn OCDness
Old 10-17-2015, 07:28 PM
  #6101
Turd Polisher
TylerT's Avatar
Primer / Paint / clear coat is done! I'll post more pictures once the clear coat is set and wetsanding is done.
Here's a teaser:
Is it perfect? Nahhh, but it'll certainly do.
$1500 job done for just under $300 in tools & supplies.
Old 10-17-2015, 07:30 PM
  #6102
-------Tim-------
Slpr04UA6's Avatar
^congratz on the work!
Bet you learned a lot during the process! That's Priceless!
TylerT (10-17-2015)
Old 10-17-2015, 07:39 PM
  #6103
Turd Polisher
TylerT's Avatar
Thanks much!
It was quite a learning experience indeed. I'm just glad it all came together the way I had hoped.
Old 10-18-2015, 02:41 PM
  #6104
Turd Polisher
TylerT's Avatar
Done.
Mom's AP2 peeping in the background
Old 10-18-2015, 06:00 PM
  #6105
dude, car looks perfect, man...
bottom line when I fix something on the car is...
I ask myself, if I don't point it out, will someone else immediately notice it.
If the answer is Yes...then tell people to stop looking at my car.
Old 10-18-2015, 06:38 PM
  #6106
took some time, and figuring out importing...
but I decided to splurge, and I'm super happy I did.
DSC_0140 by rock star, on Flickr
DSC_0138 by rock star, on Flickr
Old 10-18-2015, 07:46 PM
  #6107
CLtotheTL32's Avatar
Received 9,507 Likes on 6,176 Posts
Great job, Tyler!
J, congrats dude!
The following 2 users liked this post by CLtotheTL32:
rockstar143 (10-19-2015), TylerT (10-20-2015)
Old 10-19-2015, 07:16 AM
  #6108
Thank you T!
To say that I'm very happy would be an understatement.
DSC_0203 by rock star, on Flickr
DSC_0172 by rock star, on Flickr
DSC_0198 by rock star, on Flickr
The following 3 users liked this post by rockstar143:
00TL-P3.2 (10-20-2015), CLtotheTL32 (10-19-2015), SamDoe1 (10-21-2015)
Old 10-19-2015, 08:12 AM
  #6109
TLDude876's Avatar
Best looking aftermarket exhaust tips I've seen. Those ap2v1 wheels look
Old 10-19-2015, 08:13 AM
  #6110
Thanks Dennis!
Honestly, I agree...especially since they don't loose the coolness factor of the oem exhaust shape/look. Same way I felt about trying to mimic it on the my TL aftermarket exhaust.
Love it.
J.
Yeah, honestly, seeing the car with silver wheels again makes me realize I don't want to go dark again...silver it is...
Old 10-19-2015, 08:15 AM
  #6111
TLDude876's Avatar
Or bronze
Old 10-19-2015, 09:09 AM
  #6112
Hell yeah! That sounds bad ass
Old 10-19-2015, 11:56 AM
  #6113
Turd Polisher
TylerT's Avatar
Thanks J
Exhaust looks & sounds fantastic!
Great job, Tyler!
J, congrats dude!
Thanks bruh.
Old 10-19-2015, 12:21 PM
  #6114
Thanks guys...
Dennis, I think we have different taste...
Old 10-21-2015, 11:39 AM
  #6115
Joneill44's Avatar
Received 3,596 Likes on 1,722 Posts
After now having the Rio color for some time now. Do you prefer it over the silver?
Old 10-21-2015, 12:30 PM
  #6116
It's funny...
Sometimes I miss how classy the sebring was, although after photographing it I felt it was very bland. The Rio photos so well and definitely demands a ton more attention. I love the car no matter what the color, but I have grown to give the Rio a slight edge. It's such a pretty color...defines the colors well and kinda goes along with a flashy little sports car well.
In case anyone is looking into the exhaust...
top down and top up with external mic vids..
Old 10-21-2015, 01:23 PM
  #6117
TLDude876's Avatar
Sounds so sexxyyyyyy
rockstar143 (10-21-2015)
Old 10-21-2015, 01:30 PM
  #6118
I drive a Subata.
JS + XES's Avatar
I have thoroughly enjoyed this episode this morning.
Old 10-21-2015, 02:05 PM
  #6119
TLDude876's Avatar
Man I got the chills watching the video. Just like a woman getting butterflies in her stomach. I think the S2000 is going to work with me tomorrow
Old 10-21-2015, 02:07 PM
  #6120
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
I didn't watch the video with any sound.
I just watched the video to see the driver.
Quick Reply: The Official Honda S2000 Thread
