Maintaining a Ferrari 550..
1 Post
By Michael Sheehan
Answering daily phone calls and emails provides a never-ending supply of topics on which to pontificate. The "real-world" cost to drive a late model Ferrari is one of the more frequent questions I'm asked.
I recently sold an unusually well-documented 1998 550 Maranello, S/N 111317, with 36,200 miles to a client in the jet aircraft industry, and comparisons between Ferrari and jet costs inspired this column. Like a private jet that requires three to four hours of maintenance for every hour of flight time, Ferraris are not cheap to own.
FIRST TWO YEARS ALMOST FREE
550 Ferrari S/N 111317 was sold new on March 19, 1998, at $225,000, to a wealthy Santa Monica real estate investor and used for weekend retreats to his ranch in Ojai, a 150-plus-mile round trip. Thanks to an unlimited mileage warranty, the first two years were relatively expense free.
The first bite came in August 2000, five months after the warranty expired. At 13,637 miles, the owner brought the car in for a 15,000-mile service, two rear tires, and an oil, filter, and coolant change for $2,665.70. Two months later, in October, at 17,220 miles, noisy cam belts and bearings were replaced at no cost (thanks to a warranty extension by Ferrari). The windshield washer reservoir was also replaced for $529.25. A month later, in November, at 17,618 miles, the front spoiler and three wheels were refinished because of road-rash, at $1,285. Total for the first year out of warranty, and about 4,000 miles: $4,479.95, or $1.12 per mile.
As 2001 rolled around, in January, at 18,124 miles, two ball joints and sway bar bushings were replaced at $253.47, a standard procedure for a heavy, high performance, front-engined car with power steering. Three months later, in April, at 18,998 miles, a coolant leak, new front tires, another repaint of the wheels, and a detail added $2,718 to the ongoing maintenance bill.
A few days later, at 19,002 miles, the check engine light came on and an O2 sensor was replaced at $261.31. A month later, in late May, at 19,329 miles, the dash pod had to come out for an instrument panel repair, at $1,290.18. Five months and 1,289 miles later, in early October, at 20,618 miles, an annual oil and filter service and new rear tires added $2,386.60 to the expense column.
$8,988 FOR SECOND YEAR OUT OF WARRANTY
In December 2001, a service at 21,358 miles for dash lights, rattles, and a radiator R & R for coolant leaks closed the year out at $2,078.82. Total for the second year out of warranty, and another 3,740 miles: $8,988.38, or $2.40 a mile.
In January 2002, at 21,966 miles, the owner had the battery replaced, new suspension bushings installed, and a wheel alignment for $1,228.35. In March, at 22,956 miles, the license plate frame was replaced for $124.99, and in May, at 23,802 miles, the power steering pump was replaced and the fluids serviced, at $500.95.
Four months and 2,657 miles later, in September, at 25,607 miles, the steering box, power steering rack, and rear shocks were replaced, and the wheels were aligned for $8,641.69. The year ended at 26,236 miles, with a compression and leakdown problem discovered in late December at the 30,000-mile service. New cam belts, engine mounts, and a valve job followed, with all 24 valves and valve guides replaced at $7,954.66. Fortunately for the owner, Ferrari supplied the valves and guides under an extended warranty. Another year, another 4,878 miles, adding up to $18,450.64, or $3.78 a mile.
TOYOTA MONEY: 37 CENTS PER MILE
The Ferrari gods were smiling in 2003, with only 672 miles added and one service for hood shocks, in March, at 26,908 miles. Cost of ownership was only $249.38. Little use means no visits to ever-vigilant Ferrari mechanics, who point out problems that need to be resolved. This year cost Toyota money—just 37 cents per mile. Of course, there weren't many miles driven either.
In 2004, 550 S/N 111317 saw little use, but frequent visits to the service center, beginning in January, at 31,688 miles, for a seat control switch and wiper blades at $1,366.43.
A week later, in early February, at 31,860 miles, sway bar bushings were replaced at $208.63. In late February, at 32,035 miles, the handbrake shoes and rear brake rotors were replaced and four new tires were fitted, at $3,365.79. In early March, at 32,122 miles, a coolant leak added $903.21 to the annual cost. Another year, another 5,214 miles, another $5,844.06. The cost per mile, $1.12.
In late December 2004, Ferrari 550 S/N 111317 moved on to her second owner, for $90,000, and no service bills were added to the year. A real estate investor and self-confessed "Porsche guy," the second owner had always wanted a Ferrari and bought the 550 simply because he knew the car through the original owner.
Only weeks into Ferrari ownership, in January 2005, at 32,945 miles, a 30,000-mile service was again done, under the "while-you're-at-it" theory, because of oil leaks. The front shocks were also replaced, at $6,196.57. Only weeks later, the second owner also had the nose repainted, and his 550 "personalized" with the front fenders modified for fender shields and the calipers redone in yellow, at $7,759.70.
NOT FOR THE TIMID: $10.27 PER MILE
A month later, in March, the steering wheel was recovered for $450, and in April the windows were tinted and a "clear bra" installed for $935. Only weeks later, the owner continued to personalize his 550 with a Tubi Exhaust for $3,155.94. In August, at 34,235 miles, the oil hoses and other minor items were replaced, at $3,194.44. Total mileage for the second owner: 2,113 miles and $21,691.65. Most of this work was pure pride-of-ownership personalization, but the financially timid need not apply, as the cost per mile, at $10.27 per mile, was approaching that of an M1 tank.
As 2006 rolled in, our second owner next had a new clutch installed, in January, at 35,625 miles, for $4,852.59. After sitting for six months, the second owner decided that he really was a "Porsche guy" at heart. The 550 was too big for his tastes and so, in August, 550 Ferrari S/N 111317 was picked up from his home and dropped off for an a/c service, at 36,196 miles, for $519.40. Cost of ownership for the second owner, for 2006: 1,961 miles at $5,371.99, or $2.73 per mile.
In August 2006, our subject 550 was again sold for $90,000, with 36,196 miles, to the third owner, the president of a corporate jet maintenance and sales company. During the pre-purchase, an oil leak was found, and while the estimate was $3,000, the final bill was $1,582.58. The third owner appreciated the subtle lines and wanted a user-friendly Ferrari that could be driven daily in New York weather and traffic.
A long-time Ferrari owner, he appreciated that virtually all of the depreciation was reflected in the purchase price and that at 36,000 miles, adding mileage wouldn't kill the value. His last toy was a new Porsche Turbo at $160,000, and while it had been nice to order a car exactly as he wanted, the depreciation wasn't worth the thrill when he sold it after three years for $95,000.
The warranty on 550 S/N 111317 ran out in March, 2000, at about 13,500 miles. Our subject 550 went to the third owner in September 2006 at 36,200 miles, so the total miles out of warranty was 22,700 miles, with a total spent of $65,760.50, or $2.90 a mile, right at $11,000 a year.
Ferrari ownership is both a lifestyle and a socio-economic statement, just as owning a polo pony is a different venture than keeping a draught horse. As one former owner of S/N 111317 put it, "I spend more than that on crap on eBay every year." No other statement quite sums up the difference between those who lust for a Ferrari from those who can pay the price of ownership.
dɐɹɔ ǝɥʇ ʇɐɥʍ
I read that over at 6speed.com and a lot of the maintanance they listed is normal wear items or excessive, like painting the wheels and replacing tires, all cars have those problems if you drive hard and curb your wheels. And replacing an exhaust with a performance exhaust is not required maintance - IMO
license plate frame for $124... mint.
1 Post
Originally Posted by shrykhar
And what was wrong with the windshield washer reservoir? For 529 bucks?
This is the point i was trying to make. And its not like you can go on ebay and find these parts yourself haha.
Photography Nerd
Boeing/Airbus Jetliners
Originally Posted by Dan Martin
The washer jug is over $120 for the TL, so I guess $529 for a car that costs 6 times as much isn't that out of line.
Yeah, but isn't it still made out of the same kind of plastic or similar materials? Or is it constructed out of some kind of special aircraft-grade plastics that can withstand 30,000 ft and the temperatures at that altitude? Riiiiight!!
Received 2,329 Likes
Originally Posted by Deity711
That's ridiculous. To me luxury is not having to worry about any of that stuff.
Hence my lust for an NSX.
I could do most of the work myself IF it needed it.
Were RR or Bentley's ever reliable? The 550 is much more a sports car than a luxury car. As is every Ferrari.
this accessory makes a great addition to any Italian passenger compartment.
http://www.unicahome.com/p20780/arca...x-by-arca.html
///M Power
mmmmmm....
Originally Posted by SkillmatiC
excuse me, but does that say $586 for a tissue box?...
. it's a tissue box HOLDER. (tissue sold separately.)
Originally Posted by daemonicus
oh! oh! it actually comes with a box of kleenex already inside. shit, you cant beat that.
I don't see what's wrong here.
If you can afford a 225,000 dollar car,
You'd probably be able to afford the maintenance costs for an expensive car.
Just like how if one can afford a supercar, and afford all the gas that you need to buy whenever you drive it.
^^^^ yea id have to agree for $225K... BUT the same costs for a $90K car? arguable.
What I mean is, the 550 sold for 90K the last 2 times, and the owner has to pay the same maintenance costs as for a 225K car. That is kinda ridiculous. Wanna hear something more ridiculous - I ran this article by someone I know who has a '98 F355 - that for sake of this argument was considerably less than the used 550 here. And, he said he pays a LOT more to maintain it than this 550 here. Ridiculous.
1 Post
Since when is a Ferrari a luxury car
Luxury is having enough money that you dont need to give a f^%k
Yes it is!
Don't doubt for a second that if I was lighting Cubans with $100 bills, I wouldn't consider getting a Ferrari. Heck, at that point I could probably just send Jeeves to take care of my car(s). I understand a sports car (luxury car, whatever, doesn't matter) requires high maintenance. I understand what Ferraris are about.
But if a $100 washer reservoir was good for 95K miles and 7 years in my TL (before I wrecked it), why can't Ferrari engineer a $500 reservoir that lasts as long, if not longer? Things like valves and belts I can understand, it's a high performance V12. But the washer reservoir? A $124 plate frame? Pay to play indeed.
My whole thing is, I've come to expect a completely reliable car for $30K. So if I was paying $225K (or even $90K), I'd expect it to be an immaculate machine. I guess some people value performance and prestige over reliability. I don't.
Thats fine. Which is why you would drive an Acura and not a Ferrari. Nothing wrong with that.
Photography Nerd
Ferrari only sold about 500 550's a year in the US when they were making them. so they're not going to be getting the same volume discounts as Acura does when it cranks out 5,000 TL's a month. It costs a lot to create the tooling and molds needed for a custom part like a washer fluid bottle. There's no doubt Ferrari is still making good money on the part, but just keep in mind that their manufacturing costs are going to be many times greater than a high-volume Honda.
Go B's Go
The sizzle in the Steak
'Big Daddy Diggler'
....and people say F-Bodies are poorly built. I have a friend that track races his F Body with almost 200k now and the only thing thats been done is a new water pump, timing chain, rear main seal and tires/brakes/fluid changes. Other than that, the car is mint and still pulls low 13's. It's a stock 98 LS1 Formula. Also the car doesnt make any ridiculous squeak or rattle noises, and i now it's time for a bushing re-do.
Not comparing both cars, but the Ferrari needed more money in repairs in under 50k miles, than my buddy at almost 200k. Like sstated above, You gotta pay to play.
emailnatec
29
09-28-2018 04:27 PM
STL TL-S
09-23-2015 08:52 PM
4drviper
09-23-2015 07:42 PM
