Lexus IS: Possessed Steering Wheel Problem
Old Feb 11, 2010 | 06:34 PM
  #41
neuronbob's Avatar
Whiskey. Tango. Foxtrot. That is some freaky stuff.
Originally Posted by phee
once agin. all these electrical nannies fucking everything up.
Yeah. Yet another reason to keep my AP1 S2000 forever. No nannies other than ABS.
Old Feb 11, 2010 | 07:00 PM
  #42
dallison's Avatar
registered pw
i would expect this with a benz b/c it seems like there are so many more electronic devices controlling the car.
Old Feb 11, 2010 | 08:54 PM
  #43
AS3.0CL's Avatar
F1 cart racer
There was recall on the complete steering rack last February to prevent any problems.
Toyota knew of the issue a year ago, why because my whole stearing rack was replaced on mine.
sucks for that guy if his was never replaced....
Old Feb 11, 2010 | 10:38 PM
  #44
ThermonMermon's Avatar
to sum toyota: thats the risk you take in being an electrical/tech innovator.
Old Feb 11, 2010 | 11:06 PM
  #45
onebadna1nsx's Avatar
Hello Friend
From the owner on Club Lexus.
Originally Posted by aQuarius26
UPDATE 02/11/10
SERIES OF EVENTS:
1.) P/S went out. (at the precise moment I enter a parking garage in the daytime with the lights set to auto mode and they engage)
2.) Dealership replaces Power Steering ECU
3.) 2 Weeks later I start the car before leaving work (with lights set to auto mode) and as soon as I touch the steering wheel it begins to shake rapidly as if possessed. (SEE VIDEO in post #8)
4.) Give dealership the video with the car they try to replicate the problem. Two weeks later after failing to re-create the problem, corporate tells them to replace the steering rack assembly just as they did 6 months earlier for the TSIB because they simply do not have any idea what caused the steering wheel to shake.
MY CONCLUSION:
After doing some research here on CL, I've found and talked to a couple other members who have had the same problems, and both of which also had aftermarket HID systems.
Member #1
This member had their ECU "go out" (as mine did) and actually had their dealership in Florida conclude that his HID Ballast was mounted too close to the power steering ECU, and thus "fried" his P/S ECU.
Member #2
This member had their steering wheel violently shake (as mine did) when they started the car at night with the lights set to auto mode.
It's been almost two months since I got my car back and I have had no P/S issues.
However I have not set the lights to Auto mode since, and though I can't prove it, I truly believe that sometimes when the auto lights go on, the ballast freaks out the system OR vise versa.
I personally followed Muzzman1'S write-up about how to install and HID kit, and if you check out that thread, you can see where I mounted each ballast.
http://www.clublexus.com/forums/is-s...-pictures.html
I plan to relocate both ballasts in the spring by extending the wires to keep both of them as far away from any ECU or Fuse box type devices as possible.
ORIGINAL POST
Alright, I'm lost, the P/S light went on in my car this evening and I have total loss of power steering.
I stopped at AutoZone and got some Power Steering fluid but can not find the reservoir for the life of me.
The manual does not say anything about Power steering as far as I can tell so I am looking for any direction I can get at this point.
Where do I fill up the reservoir?
Thanks, Kyle
Originally Posted by lobuxracer
That actually may have a lot to do with it. The switches do not directly actuate the relays for the lighting, they send a network command to the BEAN ECU to actuate the relays for the lights. So this could be a Body Electrical Area Network issue in conjunction with the aftermarket HID ballasts. It's possible there's an initialization procedure the steering ECU is not completing properly because there is electrical noise from the aftermarket ballasts. Or any of a hundred other possible things - but fundamentally, there is clearly an issue with two cars using aftermarket HIDs, and no other reports of this issue from cars with OEM HIDs, or ordinary Halogen lights.
While the video really looks bad, there are a million videos with things going bad where aftermarket parts have caused issues with the OEM systems. The unfortunate part is, Lexus has no obligation to fix this problem until the OEM lighting is restored because (essentially) the problem is only found on cars with aftermarket lights. There is no warranty from Lexus for aftermarket and no warranty of fitness for aftermarket anything, so they're pretty much off the hook to solve this from a legal perspective. They may try to be nice about it and help resolve the issues but there's nothing forcing them to do this.
So the problem may not be caused by Lexus, but by the owner installing AFTERMARKET HID's.
See these two threads:
http://www.clublexus.com/forums/is-s...ering-out.html
http://www.clublexus.com/forums/is-s...eel-shake.html
Old Feb 11, 2010 | 11:39 PM
  #46
kingofire's Avatar
Is the guy seriously looking for a PS fluid reservoir when its an electrical component?
Old Feb 12, 2010 | 12:08 AM
  #47
Silva-type-s's Avatar
Got your mom in
so its the owner putting in aftermarket HID's and not Lexus?
wow. dam near everyone was ragging on lexus too. lol
Old Feb 12, 2010 | 01:36 AM
  #48
Hello Friend
Yup I bet it was the owner or whoever installed it's fault. Mickey-Moused wiring probably.
There's tons of IS X50 owners with aftermarket HID's..... No one I personally know has had this problem.... and I know tons of people driving IS X50's with aftermarket HID's.
Old Feb 12, 2010 | 11:00 AM
  #49
myron's Avatar
wow those gauges look nice and like the way they light up when the car starts up.
but that shit is so dangerous, wtf is going on with toyota. Seems like most of their cars now are deathtraps.
Old Feb 12, 2010 | 02:13 PM
  #50
Moog-Type-S's Avatar
The sizzle in the Steak
^^ I guess you did not read the posts above yours...
Old Feb 12, 2010 | 03:50 PM
  #51
crzygosu87's Avatar
Down for a photoshoot?
it's nice to see that the TL is pretty aftermarket friendly ... relatively speaking that is .... of course there is no real justification for it but nonetheless
I just ordered a set of aftermarket d2s bulbs too hahaa
Old Feb 12, 2010 | 04:17 PM
  #52
fsttyms1's Avatar
I dont know, regardless if you install aftermarket headlights or not it SHOULD NOT cause the steering wheel to do that!!!
Old Feb 13, 2010 | 04:52 PM
  #53
supraken's Avatar
Does the AP1 not also use EPS? What used to be my '04 AP2 had EPS...
Old Feb 13, 2010 | 05:45 PM
  #54
Scrib's Avatar
Administrator Alumnus
What the...
So does that stop? Or is the car completely undriveable?
Old Feb 13, 2010 | 06:00 PM
  #55
crazyasiantl's Avatar
shit
Old Feb 13, 2010 | 07:29 PM
  #56
majin ssj eric's Avatar
Punk Rocker
Mine has definitely never done that, though I don't have aftermarket HIDs either....
Old Feb 13, 2010 | 07:38 PM
  #57
mrmako's Avatar
Someday, an RS6 Avant+
Well, it could be a massive amount of current the ballast is drawing, and this may effect some ECU components.
I've never liked after HID's, as it draws a lot of power, and unless reputable, can really screw things up.
I don't see this as Toyota's problem.
Old Feb 13, 2010 | 09:46 PM
  #58
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
Holt shit just watched the video.
Old Feb 13, 2010 | 10:19 PM
  #59
TL1999's Avatar
GO DAWGS!! SICK'EM!!
what the f........really toyota
Old Feb 14, 2010 | 03:39 AM
  #60
dsickles's Avatar
uhhhh... this issue should never occur. no matter how much power a set of hids draw or how close they are mounted to the steering components.
Old Feb 14, 2010 | 05:34 AM
  #61
mrmako's Avatar
It's a matter of the quality of the device you install. Lets look at what an HID set up is: two xenon gas lights that require 10,000 - 20,000 volts to light up. You get a control module and a ballast that stores electricity and basically pumps up the 12 volt DC your car has to give you the required "ignition" of the gas.
So, that being said, if some crappy aftermarket kit pulls to much current, and the splice where you hook it in is near other sensitive electronics OR there isn't a good ground isolation for that system, it could fry anything near it.
Sorry but my background is aerospace engineering, and electronics are something I kind of know. In this instance, it may not be Toyota's fault. I do blame them, however, for their acceleration issues.
Unless there is more than what is posted, I think this is a good assumption of the issue.
Old Feb 14, 2010 | 06:03 AM
  #62
dallison's Avatar
registered pw
when doing a stereo install, you don't run the rca's and power cable next to each other. It could cause interferance, i could see the rationale in this theory.
Old Feb 14, 2010 | 01:59 PM
  #63
Got your mom in
but with the AP1 you cant get the Hondata
Old Feb 14, 2010 | 03:47 PM
  #64
Costco's Avatar
Good point. I'm no electrician but I can see the logic in that
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
PortlandRL
Sep 14, 2015 12:01 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
