Jetta A/C Problem
Old Jul 2, 2005 | 12:41 PM
KCheng's Avatar
Aspiring MultiBillionaire
Jetta A/C Problem
Hey guys, I need some help. I have a friend who has a 2000 Jetta, and she is experiencing some A/C problems. It just started recently, and I just got a chance to drive it so I can describe the problem, but I don't know what's going on.
I started the car, turned on the fan and A/C, and it definitely felt a little warm, like the A/C is trying to work, but just can't hit its potential. Once I got out to the main road and moving, the A/C performed better and it was a little cooler. Once I hit some stops and red lights, I could definitely feel the A/C heating up again.
Later, as I drove it back, I noticed the temperature gauge was pushing a little higher than normal (190 is the middle...It was just a notch or 2 above 190). Do you guys know what the problem might be?
Also, I don't know if this is related, but the car will also randomly vibrate pretty strongly. It doesn't affect the driving, but it can definitely be felt through the seats.
Thanks guys!
Old Jul 2, 2005 | 01:00 PM
dallison's Avatar
registered pw
part of it seems like it needs to be recharged(ac) that may be making the motor work a little harder when the compressor is kicking on ond off, but it also sounds like the cooling system needs to be flushed or some maintanance is required
Old Jul 2, 2005 | 01:05 PM
Crazy Bimmer's Avatar
Is the fan working?
Old Jul 2, 2005 | 01:10 PM
dallison's Avatar
registered pw
Originally Posted by Crazy Sellout
Is the fan working?
ah
Old Jul 2, 2005 | 01:11 PM
KCheng's Avatar
Is the fan working?
Maybe I'm thinking too much about it, but if air is blowing out of the vents (hot or semi-cold), the fan's working, right?
If so, it's working
Old Jul 2, 2005 | 01:57 PM
I have no idea, im not good with stuff like this.
Did you check out the VW forums? Maybe others had the same problem..
http://www.vwvortex.com/
Old Jul 2, 2005 | 01:59 PM
Minch00's Avatar
Pit Stop?
A she that drives a Jetta, who woulda thunk it?
Sorry I can't help you
Old Jul 2, 2005 | 02:06 PM
dallison's Avatar
registered pw
if the air coming out of the vents is warm, the ac needs to be charged
^ what would cause the car to overheat?
Old Jul 2, 2005 | 03:50 PM
dallison's Avatar
registered pw
um, it didnt over heat but it could be the fan
Old Jul 2, 2005 | 04:42 PM
KCheng's Avatar
Thanks a lot for your help guys. Any idea on how much a A/C recharge runs if that is the case?
Old Jul 2, 2005 | 05:12 PM
dallison's Avatar
registered pw
i can get it done at a local garage for $40, but most will prob charge prob 75-100 for r 134
Old Jul 3, 2005 | 12:31 AM
zamo's Avatar
Houses Won't Depreciate?
You might wanna check at the thermostat
I had a Jetta some time ago; it was HELL
to many freaking problems
Old Jul 3, 2005 | 02:27 AM
KCheng's Avatar
Thanks for all your help guys!
Old Jul 3, 2005 | 11:17 PM
KCheng's Avatar
I'm not sure if this is important, but I think it's just worth mentioning in case it helps further diagnose the problem.
The car is about 500 mi overdue for its oil change. Does this change anything? After driving it a little bit more, the basic problem is that whenever it stops (signs, red lights, etc.), the car will heat up a little bit. Once we are on the road again, the temperature drops back to a stable 190. Any clues?
Thanks a lot guys!
Old Jul 4, 2005 | 12:23 PM
zamo's Avatar
That means that there is either not enough coolant, or the fan is not working properly. Oil change has no impact, unless you are running very low on oil; you migt wanna check that too.
I had the same issue with my Jetta long time ago. It was the thermostat.
Old Jul 4, 2005 | 04:59 PM
KCheng's Avatar
zamo:
Thanks a lot for your help. Definitely important to figuring out the problem! I think I'm going to be taking the car into the dealer, so I'll keep you guys posted! Thanks again all!
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
