J32 Miata: PLEASE help with header specs :)
Old Jan 29, 2018 | 04:03 PM
J32Miata's Avatar
8th Gear
Hello to all you Acura experts! I hope you can help me with some header specs please
I recently bought a J32A (JDM) engine (apparently the exact same as a J32A2) read to instal into my mk1 Miata.
I need to know the ideal dimensions to fabricate the headers. In particular the ideal length of the primaries from the engine ports to where they merge into the single exhaust section. Obviously the factory headers are very short and cast. I've seen lots of after market stainless steel items which look longer. But I cannot get any dimensions at all. A tuner mentioned he made some 17" long headers, based on physical limitations rather than the optimal length. But I do not know the IDEAL length as this must be critical for tuning surely? I know it will be hard to measure due to the curves. I guess using a length of tape or string would work.
If anyone has some headers they could measure I'd REALLY APPRECIATE your time and effort! Happy to buy you some beers for your time!
Thanks so much, Paul
Old Jan 29, 2018 | 04:05 PM
J32Miata's Avatar
8th Gear
ps
Engine will remain naturally aspirated and stock, aside from tuning with AEM computer and fitting a decent air filter on.
Old Jan 29, 2018 | 04:07 PM
J32Miata's Avatar
8th Gear
Engine: J32A (260bhp), as used in 2001-2003 Acura CL and TL Type-S, 3.2 V6
Old Jan 29, 2018 | 05:25 PM
Paging @fsttyms1 the resident 2G TL guru.
Old Jan 30, 2018 | 09:51 AM
gnuts's Avatar
3.5 psi
If you look at Comptech headers, the primaries are not very long. The primaries I'm pretty sure are 1.5" that merge into 2.5". One or two custom long-tube headers have been made. I believe they were put on cars that were stroked (3.6L or used the J35A3 so 3.5L). Since you're using a 3.2, you might want to do something a little smaller like 1.6" with a nice merge collector into 3". The J engine love to breath, so big intake, big throttle body, porting the manifold and runners will help. Also I believe P2R sells the flanges, so you can fab off those.
Here's a mock up of a set. They were 1.8" primaries, 2.5 downpipe to a 3" merge.
Here's a DIY set.
Old Jan 30, 2018 | 10:46 AM
TylerT's Avatar
Turd Polisher
gnuts ... I love your CLS6.
Old Jan 30, 2018 | 10:59 AM
gnuts's Avatar
3.5 psi
thank you! I love your S4!
Old Jan 30, 2018 | 11:14 AM
get a room you two, y'all useless to the OP
Old Jan 30, 2018 | 02:55 PM
J32Miata's Avatar
8th Gear
Thanks so much for taking the time to help
Could you let me know the rough LENGTH of the ideal header pipes please? Looking at the photos I would guess somewhere between 13" and 16" long? Is this critical? I am guessing it must be. If anyone has a set they can measure the length of the header section I'd really appreciate it! I know it will be a bit tricky as the pipers are curved!
Old Jan 30, 2018 | 08:59 PM
gnuts's Avatar
3.5 psi
I'm not sure there's an ideal. Longer primaries will probably yeild more torque down low. I'd say make the primaries as long as possible before you have to merge and bring the pipes under the car to merge. I'd guess the comptech primaries are closer to 10" if you measured with a string. So 13-16 would be great if you can pull it off.
Old Jan 30, 2018 | 09:02 PM
gnuts's Avatar
3.5 psi
I'm hoping his S4 mates with my CL and makes something great!
Old Jan 31, 2018 | 02:19 AM
J32Miata's Avatar
8th Gear
So CT are well respected and are +10”... ok thanks a lot for the info!
I ordered a set of stainless flanges plus gaskets from P2R. This is the guy I was talking to before, who mentioned using 17” primaries.
Old Jan 31, 2018 | 08:44 AM
gnuts's Avatar
3.5 psi
P2R really know their J series stuff. If they suggest 17" primaries then do it! They apparently broke 300whp on their J32 tuned Accord and I'm pretty sure they had custom long tube headers. So I'd go 17". Also post some pics!
Old Jan 31, 2018 | 08:49 AM
J32Miata's Avatar
8th Gear
P2R said it worked out very well, although we’re honest enough to say they only tried that one size due to instal limitations.
I really appreciate all your input. I will leave the final dimensions down to my talented installer / fabricator. Clearly we will have to work around the fixed Miata limitations.
Thanks!
Old Jan 31, 2018 | 09:24 AM
J32Miata's Avatar
8th Gear
I need to have the plenum modified so the throttle air intake angles down lower under the Miata hood. So a bit more custom fabrication to do. So before that is done...
Does fitting a larger throttle body make much different to power? If so which make and model do you suggest using? Or is this a waste of money for sensible power instals?
Thanks all
Old Jan 31, 2018 | 10:25 AM
gnuts's Avatar
3.5 psi
Here's an intake manifold some use to fit the J into civics. High Clearance Intake Manifold v2 ? Prank Parts
It says it accepts a mustang 90mm TB. Others have used Bseries 74mm Blox throttle body. I would definitely opt for a bigger TB and 3.5-4" intake.
Old Jan 31, 2018 | 11:02 AM
J32Miata's Avatar
8th Gear
Thanks, although I can keep the OEM plenum. Its only the intake which needs a tweak...
http://classicmotorsports.com/media/...s/IMG_9466.jpg
gerzand
116
Oct 13, 2011 03:44 PM
MadisonTLS
Jul 31, 2003 09:32 PM
oonowindoo
Nov 23, 2002 10:47 PM
juniorbean
Jun 5, 2001 07:01 PM
