Insurance Question
Old Jan 17, 2010 | 02:37 PM
  #41
dallison's Avatar
registered pw
@ snooki
Old Jan 17, 2010 | 04:37 PM
  #42
subinf's Avatar
One on the right for me
Well, from the insurance company's perspective, it was your wife's and your fault that you damaged your cars, hence they mostly likely would not cover that. It was not an accident, so no claim will be made. Even if you asked, I doubt they would cover it. I would pay for the repairs out of pocket. :twocents:
Incorrect
Old Jan 17, 2010 | 04:42 PM
  #43
teranfon's Avatar
Moderator Alumnus
Originally Posted by Snooki
Just called Geico and they will only fix one accident per car, so that would get one panel fixed, not sure if its even worth it....They they told me that I need to report any accidents to them regardless and I quickly hung up....Never gave them my policy number...
How many bent panels are there?
Terry
Old Jan 17, 2010 | 04:43 PM
  #44
Whiskers's Avatar
Go Giants
Terry
My car has one and hers have one, the other areas are just paint scratches..
Old Jan 17, 2010 | 06:37 PM
  #45
The Dougler's Avatar
Unofficial Goat
could you maybe put some kind of rubber edge on the part of the entry that you keep rubbing up against to at least give the paint on the car a break.
Old Jan 18, 2010 | 04:00 PM
  #46
Fibonacci's Avatar
I feel the need...
Originally Posted by Whiskers
My neighbor and I do drive on the grass between, so I guess we can still do that, but it doesn't always work.
Cheapest option is to share the cost of a brick paver driveway extension with your neighbor so you can both make a wider turn in.
I suck.
Old Jan 18, 2010 | 04:10 PM
  #47
jupitersolo's Avatar
nnInn
I think the only option is to remove the two doors and make it one, but not sure on how to do that. Plus there is a poll inside...
Can you make the driveway wider at the entrance of the garage, it would let you swing into it wider? I can't tell how close you are the house next to you from your image.
Originally Posted by dallison
there's your problem, you've got a poll in your garage.
That's his stripper pole, it's not going anywhere.
Old Jan 18, 2010 | 11:17 PM
  #48
NightHawk CL9's Avatar
WAS HONDATAFIED IN
From an architectural/engineer point of view it is not a big change to remove the poll and make it a two car garage door. The contractor will add a post (poll) at the ends of the garage door and a header spanning the 16ft as (3)2x12 or (2) PSL beams that go across dependent if there is a room above your garage or just the roof to distribute the load from the one post to the two new posts. It is a simple change that I don't think will cost very much at all. I didn't stay at a Holiday Inn but I'm an architect. PM me if you want any more info or have any questions.
Old Jan 19, 2010 | 12:15 AM
  #49
YeuEmMaiMai's Avatar
you guys gotta learn to be more careful when you exit and enter that there garage...
your insurance will cover it but they will classify it as an at fault accident and therefore your rates may go up if you do not have some sort of accident forgiveness program.
I live in a city with skinny alleys and drive a CL-S with a HUGE Turning radius and I have never hit my car on the side of my garage.....
if you have having troubles with the garage, turn in back up and straighten out before you enter, problem solved
Old Jan 19, 2010 | 07:54 AM
  #50
Whiskers's Avatar
Go Giants
The wife nixed any plans of repairing cars and or garage... /thread
Old Jan 19, 2010 | 07:59 AM
  #51
fsttyms1's Avatar
its easy to do, i have done it for 2 friends that had double doors.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
lanechanger
Oct 13, 2015 10:56 AM
navtool.com
Sep 25, 2015 05:15 PM
