Houston we have a problem...
Old Jun 20, 2008 | 11:02 PM
Ken1997TL's Avatar
I'd ask this in the RL forum but I'm usually the one that does the answering..
I was screwing around with my instrument cluster (changing LED bulbs) and after putting everything back together - my left turn signal turns on and stays solid as long as the battery is connected..
Now if I put the turn signal stalk to the 'right' position, all four flash. NOTHING happens when I go left...
My guess is I blew a fuse. Any other possibilities?
All connections are good, i didn't screw anything up on the instrument cluster at all.
I'll check the fuses in the morning, but after screwing around with my RL for over two hours I'm done, moving on to dinner and a beer. AKA I'm lazy.
Thank god I have another car in the stable.
/end embarrassed rant
Old Jun 20, 2008 | 11:05 PM
Bearcat94's Avatar
AZ Community Team
Everything wired/connected back to the same/correct place? No shorts?
Old Jun 20, 2008 | 11:06 PM
Ken1997TL's Avatar
EVERYTHING else works
Old Jun 21, 2008 | 12:04 AM
Will Y.'s Avatar
Registered but harmless
Try the hazard light switch- maybe a bad signal bulb (although usually that slows the blink rate)?
Old Jun 21, 2008 | 12:11 AM
Ken1997TL's Avatar
Tried that. Hazards don't work...
I still say fuse. We'll find out in the morning.
Old Jun 21, 2008 | 12:18 AM
CLpower's Avatar
teh Senior Instigator
fuse
Old Jun 21, 2008 | 10:21 AM
Ken1997TL's Avatar
It was a fuse
Old Jun 21, 2008 | 06:08 PM
Ken1997TL's Avatar
Turns out its not a fuse. None are blown and its still doing it..
Bad relay? I checked those too
Old Jun 21, 2008 | 06:40 PM
teranfon's Avatar
Moderator Alumnus
When you changed your LED bulbs behind the dash, were they factory replacements? Some automotive electrical systems, primarily accessory systems such as dash lights/blinkers, use resistance to operate correctly. In fact, some relays used for such things as flashers/signals depend on the resistance created by the electrical system to create the correct amount of heat in order for the relay to operate correctly. If you have the old bulbs still available, put them back in and see if you still have the same problem.
Terry
Old Jun 21, 2008 | 07:59 PM
iTimmy's Avatar
dɐɹɔ ǝɥʇ ʇɐɥʍ
Is it just the turn signal indicator that is on or the directional light itself, or both?
Old Jun 21, 2008 | 08:46 PM
Ken1997TL's Avatar
Parking lamp/Turn signal
This also applies to the turn signal indicators on the instrument panel
Old Jun 21, 2008 | 08:47 PM
Ken1997TL's Avatar
Terry
They're replacement LED's, but same voltage. I've used them before without any problems. I rechecked the instrument cluster, all the screws are in and the voltage is as it should be
Old Jun 21, 2008 | 09:06 PM
teranfon's Avatar
Moderator Alumnus
Odd problem. You'd think if something is grounding or shorting out a fuse would have blown, but it seems not to be the case. It still sounds to me as if a there may be a resistance problem. A number of years ago I had a similar problem on a 540, and the dealership eventually traced it back to an electrical resistance problem.
Hope you get it figured out. Things like this are generally simple to rectify, but maddening as hell to determine.
Good luck
Terry
Old Jun 21, 2008 | 09:43 PM
Ken1997TL's Avatar
Its all good, I'm going to go screw with the Prelude for a bit
Old Jun 21, 2008 | 11:24 PM
Will Y.'s Avatar
Try swapping the new LEDs with the old LEDs on the other side, and try switching relays for one side to the other to eliminate the possibility of a bad LED or a bad relay.
If that doesn't ID the problem, drink heavily.
G/L.
Old Jun 22, 2008 | 12:34 AM
Ken1997TL's Avatar
Drink heavily and drive my other cars
Poor RL
Old Jun 22, 2008 | 06:37 AM
mrmako's Avatar
Someday, an RS6 Avant+
Talking
I agree with the LED being the issue. It just doesn't sound right...... And the drinking idea is not all that bad. Just stay out of the cars.
Old Jun 22, 2008 | 06:54 AM
Costco's Avatar
Did you check the underhood fuse box too? I just forgot that today....
Old Jun 22, 2008 | 10:25 AM
Ken1997TL's Avatar
Pulled each one AND checked the relays...
Old Jun 23, 2008 | 01:08 PM
Will Y.'s Avatar
Hopefully it isn't a jacked-up turn signal lever switch, broken detent or something. Maybe blow some compressed air into the steering column behind the stalk to see if there's something lodged in there?
Let us know when you solve the problem-- I'm really curious now.
Old Jun 23, 2008 | 03:59 PM
SSMTL01's Avatar
Try to reset your battery.. could be a BCM issue?
Old Jun 23, 2008 | 05:16 PM
GreenMonster's Avatar
Poor RL
Just noticed your sig... What happened to the Redondo Red TL ?? Maybe I'm confusing you with someone else.
Old Jun 23, 2008 | 05:38 PM
Ken1997TL's Avatar
It was me, I sold that when I got the '02 RL. I just got bored with it and got a lot of my money back.
As for the RL, I figured it out. Bad relay. My foglights wouldn't work either, so I replaced that and I'm back to normal.
Sidenote: 1st gen RL is a BITCH to take apart.. I could have done the exact same work on my '97 TL in a third of the time. What a pain in the ass..
Old Jun 23, 2008 | 05:43 PM
Mokos23's Avatar
oops
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
truonghthe
Oct 1, 2015 03:13 AM
hashbrown
Sep 29, 2015 12:13 PM
CostcoFanAUS
Sep 18, 2015 06:05 AM
