help header bolt broken on accord
Old Jul 23, 2004 | 01:23 PM
dallison's Avatar
registered pw
didnt know where i could put this b/c it didnt have to do with an acura
anyway
ok my fiance picked up a 95 accord coupe non vtec 4cylinder back in jan.
only paid 2k for it with 170k and its a 5 speed.
her exhaust was getting louder up in the engine bay, so i took apart the manifold and found one of the studs sticking out that helps attach the header to the motor, was misssing.
i am no expert on tapping or drilling out bolts, but i did my best, i used a 1/4 drill bit and used lubricant to help drill out the hole. i only got so far and i couldnt drill anymore.
i tried to use a self tapping screw w/o success.
so reassembled everything reusing the old gasket b/c i knew i would be taking it apart inthe future any way and also teh local shops werent open on sundays.
so my question is , is it cheaper to replace the unit that the header bolts on to or is it cheaper to have the dealer install a new stud.
the stud that is broke off is the one on the very end of the right side of the manifold
Old Jul 23, 2004 | 01:31 PM
ju5tchi11in's Avatar
roomate has a CL too
Ur talking about the nut right? or the bolt that extends from the head to the header.
I have the same engine and same header I installed my other header myself so im familiar with the picture you posted but im not understanding what the problem is.
Old Jul 23, 2004 | 01:33 PM
you are talking about part #11? the nut that screws onto the "stud" bolt extending from the engine block/head?
so that bolt broke off and now you cannot screw the nut on to close the gap between engine and header... so it keeps leaking?
im not sure if they can put another stud onto the "exhaust manifold?" I dunno?? perhaps they would weld it on and rethread.
Old Jul 23, 2004 | 01:36 PM
dallison's Avatar
registered pw
the stud that the nut screws onto is missing
dallison's Avatar
registered pw
where part #11 is thats the stud that is missing
Old Jul 23, 2004 | 01:39 PM
yeah I get it... where part #11 screws into... ask the dealer im not sure you can just "replace" the stud it is part of that whole engine block part... if it can be welded then they could do that but it will never be the same as before and you will probably still have that exhaust leak... try and buy a new engine should only cost you 400 or something for a newer f22a1 or get a f23a1.
Old Jul 23, 2004 | 01:40 PM
good thing this is in car and bike talk now because you get way more responses over here
Old Jul 23, 2004 | 01:45 PM
dallison's Avatar
registered pw
thanks with the new format i didnt look around.
i could prob just have some shop weld one in place for me instead of taking it to the honda dealership
Old Jul 23, 2004 | 01:46 PM
dallison's Avatar
registered pw
i had already drilled out the holewhere the stud was so i don't know what they would be able to do.
i called those dumb fuckers almost 2 hours ago about it and no fucking phone call..
stupid ass central pa
Old Jul 23, 2004 | 01:47 PM
dallison's Avatar
registered pw
thanks for the info, you got points
Old Jul 23, 2004 | 01:57 PM
dallison's Avatar
registered pw
just talked to the parts dept. 17$ for the gasket and 3 for the stud and 2 for the nut. 25 aint bad
he says that the studs are the screw in type, so i guess i need to find a tap set
Old Jul 23, 2004 | 02:30 PM
lol for 1 rubber bushing for the front shock ... if you look under the hood where the sway bar attaches to the frame of the car... you can see a rubber bushing sticking up...
15.95 at the dealer...plus special order time.
1.49 on acuraautomotiveparts.org
mother fuckers... except on the website minimum order is $30.
I ended up buying a suspension install kit for 17.20 shipped... comes with 2 which I need... really sucks though could have just spent 6 bucks and had them here but no... there is a minumum order.
try websites they have it even cheaper.
Old Jul 23, 2004 | 02:36 PM
dallison's Avatar
registered pw
holy shit what a difference,
same thing when i bought lower control arms for our 89 camry, at the deal they wantes over 200 for each side. i got em from ebay for 120 shipped.
well i just need to figure out what i need to do before november before the inspection is due
Old Jul 26, 2004 | 12:25 PM
I think you can buy new block or new head for 200-300... so might want to do that... a cheap "upgrade" and it will fix your exhaust leak. I mean 170k is a lot of miles.
Old Jul 26, 2004 | 01:36 PM
dallison's Avatar
registered pw
something i need to think about
IBankMouse
Jun 13, 2020 12:53 PM
Charles Bennett
Jan 28, 2018 08:53 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
juanrl
Sep 29, 2015 03:25 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
