Help Azine!! TY
Old Mar 30, 2009 | 09:41 PM
AATSX's Avatar
Help Azine!! TY
HEY AZINE WHATS UP
I need your help again lol.
Here is my dilema i am looking for a certain engine and i might have found it the car has blown head gaskets, so what does this mean? can i still take the engine and put into a different car or does this mean the engine is toast?
thank you i need this asap so i will stick around and post more details to the questions you have. I am not mechanic so i dont understand. Thanks for the help.
Old Mar 30, 2009 | 09:52 PM
teranfon's Avatar
Moderator Alumnus
Nope.
An engine with a blown head gasket is not worth anything other than a boat anchor until repaired. The gasket(s) between the block and the cylinder head is damaged and must be replaced. The engine you found may indeed run, but not for long. Coolant leaking into the cylinders does very interesting things. And none of them good.
Either repair the problem before the engine is installed, or move on. Depending on the engine, replacement of the head gasket can be an expensive and labour intensive proposition.
Terry
Old Mar 30, 2009 | 09:58 PM
AATSX's Avatar
Originally Posted by teranfon
Nope.
Terry
Ok so i understand that i need to keep looking for another one ? thank you Terry
Old Mar 30, 2009 | 09:59 PM
teranfon's Avatar
Moderator Alumnus
What engine are you looking for?
Terry
Old Mar 30, 2009 | 10:00 PM
Will Y.'s Avatar
Registered but harmless
Just to add to what Terry said, "blown head gasket" can also mean that the heads warped, that the block cracked, etc.-- which means you can buy a boat anchor that will need between $2000 and $7000 (USD) in parts and labor to make into a working engine, assuming it is even repairable.
Bottom line:
Old Mar 30, 2009 | 10:24 PM
AATSX's Avatar
Terry
Chrysler Sebring 2001 2.7 L V6
AATSX's Avatar
Bottom line:
Yea I think I got the idea lol
Old Mar 30, 2009 | 10:47 PM
teranfon's Avatar
Moderator Alumnus
I believe that particular engine is an aluminum alloy, twenty-four valve design. Without going into too much detail, aluminum engine components such as cylinder heads react adversely to heat much more than a cast iron design. As Will mentioned, the cylinder head(s) itself may be damaged.
Definitely run away from this particular replacement engine.
Terry
pplcrew
Jan 30, 2021 08:59 AM
Rdub81
ILX Photograph Gallery
Mar 17, 2016 03:02 PM
Skirmich
Oct 1, 2015 12:59 PM
jterp7
3G MDX (2014-2020)
Sep 21, 2015 11:02 AM
acuradriver925
Sep 12, 2015 08:25 AM
