good tires on front or on back?
on a FWD car. should the better tires be put on front or on the rear. with concern to safety. im tired of debating with my buds about this and i want to know the concensus
Tire Rack recommends that the new tires go on the back because the back would be where traction would be lost first in an emergency. http://www.tirerack.com/tires/tirete...jsp?techid=52&
For me, I would probably put the new tires on the front if the rear tires had at least half the tread wear left. I would get four new tires if the rears had a quarter or less tread wear left.
The consensus and Tire Rack differ on FWD cars.
If you have two that are in really good shape, put those on the front and the two new ones on the rear. If you have iffy tires all around, buy 4.
I forget how bad my other two tires were. I think they were kinda low, cause I bought another 2 tires within the next year or so.
I think the next time around I just put the new ones on the front. I bought less aggressive tires the second time around though, and the other ones weren't that old.
Trailing brake or trottle oversteer (TBO and TTO) happens when you unbalance the car and shift weight too quickly to the front. That is why you need the new tires in the rear for better grip when it is needed unexpectedly. Newtonian physics works well in this case, but can be a little counter intuitive. Oversteer is difficult to correct unless you anticipate it. TTO and TBO also can be your good friend if you can control it well.
http://www.michelinman.com/tire-care...artire-change/
Terry
New tires in the rear.
Most drivers are not prepared for the consequences of oversteer (ie the back end giving way) ... however, most can deal with understeer (that's why most cars are engineered to bias understeer versus oversteer).
You learn something new everyday.
Every shop i've been too always has recommended putting new[er] tires on the front when it's a FWD car. on a FWD car, if you don't have any traction on the front two wheels it doesn't matter how good the rear tires are because all the power and steering is on the front so if you lose control of the car, your pretty much SOL if the front's don't have traction.
I just replaced the front tires on my GTI by my friends shop, I confirmed with him that the new tires should go in back, but his guys were too busy to do it, so they put the new tires on the front, and he told me to come back on a day he's not so busy to switch 'em the way they should be.
Man that Michelin vid looked fun when the E36 was sliding.... after seeing that I'd almost be inclined to put them on the front first.
But yeah the rear almost always loses grip first, but in certain cars if you lose grip in the front chances are you've lost grip in the rear too, which means you're screwed anyways especially in the rain. I know my car always loses grip in the rear first (no traction control FTW) and I make the most out of it
Rear wins (unless the only thing you care about is even tire wear, so you put them on the fronts)
didn't read every post but saw the first few and thought i'd chime in,
its a VERY common misconception that good tires should be in the fornt.
I'm gonna concur good tires in the back, especially on a FWD.
I tested this once on some nice lake effect snow with one of my old beaters. Had 2 tires that were in pretty bad shape and two that still had pretty good tread.
With the "good" tires in back the car drove OK, had some trouble getting traction to start moving especially on any inclines.
When the good tires were moved to the front car drove amazing UNTIL the first corner. Lost the rear end on almost every corner no matter what speed. Keep your best tread in the rear - especially in the snow.......
From a performance perspective, put new tires in the front. On nose-heavy FWD cars like ours, we could use the slight oversteer, as long as you expect it and handle it under control. This shouldn't be done anywhere but on a race track. It's a concept similar to front-biased staggered setup, where the front has wider tires than the rear.
From any other perspectives, always in the rear.
Regardless of drivetrain layout and location of the engine, it's simple physics when it comes to vehicles - Front provides steering and rear provides stability.
Rear, but today's cars are different. Some have traction systems, & other systems that need to be taken into account.
Also car weights are different front to rear.
I don't think it's a simple front or rear question any longer.
I never replace 2 tires, I get sets of 4.
Even when the stability system kicks in, it's still all in the tires, because it can only work with the amount of traction present. It cannot create traction.
So if you want to aid the stability system in correcting your vehicle's travel path, then it is wise to put the new tires in the rear.
Front provides steering and rear provides stability. Stability systems are designed and implemented based on that simple principle. The more stability in the rear, the better.
And yes, 4 > 2. I'm the same way.
rear, its about obtaining more lateral traction. I was in the tire biz for a long time and people never got it, old habits die hard.
