Eibachs are squeaky
Old Oct 28, 2008 | 10:05 PM
BC2G's Avatar
Registered Big Dog
Eibachs are squeaky
My Eibachs on the truck are squeaking in the rear, seems to happen when coming to a stop and letting off the brake and also while accelerating.
any suggestions? the squeak annoys the pants off me
Old Oct 28, 2008 | 10:06 PM
Infamous425's Avatar
fap fap fap
wd-40
Old Oct 28, 2008 | 10:08 PM
The Dougler's Avatar
Unofficial Goat
you lowered it. cars go down, trucks go up. a 3' lift should fix it.
Old Oct 29, 2008 | 12:05 AM
stangg172004's Avatar
_____ like a rabbit
well said
Old Oct 29, 2008 | 12:34 AM
v6cord2k5's Avatar
seizure force field!
Problem: squeaking rear?
Solution: K-Y Jelly
Old Oct 29, 2008 | 12:35 AM
BC2G's Avatar
Registered Big Dog
Some awesome helpful posts here!! /redtext
Old Oct 29, 2008 | 01:01 AM
v6cord2k5's Avatar
fine...
so have you tried some grease/lube? are you sure its the springs and not bushings?
try lithium grease
Old Oct 29, 2008 | 02:25 AM
Costco's Avatar
Squeaks are usually bushing related. Check your strut tower bushings, WD-40 them like someone said. and also white lithium grease
Old Oct 29, 2008 | 09:44 AM
CLpower's Avatar
teh Senior Instigator
do you have the spring isolator on there. Eibachs generally come with a spring isolator that's a little piece of rubber tubing you wrap around the bottom of the springs.
This problem is very very common, the spring isolator solves it
Old Oct 29, 2008 | 10:18 AM
fsttyms1's Avatar
Agree.
Old Oct 29, 2008 | 11:15 AM
BC2G's Avatar
Registered Big Dog
these are leaf springs, not sure about an isolater, this isnt like a car spring
the r
Old Oct 29, 2008 | 11:54 AM
CLpower's Avatar
much different story, can't help you then, sure there didn't need to be grease somewhere?
Old Oct 29, 2008 | 02:37 PM
BC2G's Avatar
Registered Big Dog
I greased it... Probably not well enough...... Noise is killing me
Old Oct 29, 2008 | 03:56 PM
phee's Avatar
I got the Shifts
loud stereo
/thread
Old Oct 29, 2008 | 03:59 PM
Unofficial Goat
how have you been liking the hemi btw? yours is RCLB right?
Old Oct 29, 2008 | 04:21 PM
Will Y.'s Avatar
Registered but harmless
Torque and re-tighten all of the rear suspension bolts since the squeaking started?
Old Oct 29, 2008 | 04:50 PM
JS + XES's Avatar
I drive a Subata.
ear plugs
Old Oct 29, 2008 | 05:13 PM
Unofficial Goat
is it a metallic squeak? or definitely a bushing squeak? if it's metallic maybe the U-bolts on the axle are not torqued enough.
emailnatec
29
Sep 28, 2018 04:27 PM
Onyxthecat
Oct 18, 2016 02:05 PM
mmhdavid
ILX Tires, Wheels & Suspension
Nov 9, 2015 11:18 PM
TSX 09
33
Oct 25, 2015 01:32 AM
TSX 09
Sep 10, 2015 10:21 AM
