Diagnosis of problem (1983 Town Car)
Old Aug 8, 2006 | 09:34 PM
Minch00's Avatar
Pit Stop?
Hey guys, my 1983 Lincoln TC has been acting up recently. It has the 5.0l V8 and a 4speed auto tranny. I'll be driving and it'll start, "bucking", as it it will surge forward then stop, every few seconds repeatedly. I've also had it stall out after these episodes, as in I'll be driving normally and the engine will just die. I know this is a rather vauge description, but if anyone knows what could possibly be wrong I'd appreciate any info. Thanks.
Old Aug 8, 2006 | 09:37 PM
SpeedyV6's Avatar
Clogged fuel filter or a weak fuel pump?
Old Aug 8, 2006 | 09:42 PM
Stapler's Avatar
my grandmas 2000 marquis and 1992 crown vic had similar issues due to a fuel pump.
Old Aug 8, 2006 | 10:33 PM
Eggplant-EX's Avatar
do the cheap stuff first.
Fuel filter, plugs and plug wires.
Old Aug 8, 2006 | 10:39 PM
Minch00's Avatar
Pit Stop?
Did that already
Old Aug 8, 2006 | 10:52 PM
joedokes28's Avatar
It's a FORD?
experience with fords....
Old Aug 8, 2006 | 10:59 PM
SpeedyV6's Avatar
See if you can get a hold of someone who manages a cab company or a livery fleet of
TownCars/ CrownVic's and hit 'em up for an opinion. I'm pretty sure they would be able to diagnose any problem that these cars would have.
It could also be a vacuum leak but I really don't know.
Old Aug 9, 2006 | 01:41 AM
Minch00's Avatar
Pit Stop?
Originally Posted by joedokes28
It's a FORD?
Hmmm..........maybe the fact that it's a 23 YEAR OLD CAR with 140k miles might have something to do with a mechanical part failing?
Old Aug 9, 2006 | 07:28 AM
fuzzy02CLS's Avatar
Is it carbed or fuel injection?
If it's FI does it have a MAS air sensor, or IAC(idle air control valve)
Try cleaning those with some 02 sensor safe cleaner. Also look into the 02 sensors.
Another thing to lok at is the TB. The TPS(throttle position sensor).
Does it do it when hot, cold, or all the time?
SakiGT's Avatar
Another vote for fuel pump. At least thats why its shutting off after the bucking.
When does the car start bucking? Are you accelerating? Slowing down? Id try and pull codes and see if you can find out anything.
Old Aug 9, 2006 | 06:26 PM
joedokes28's Avatar
No, that couldn't be it.
I think the fact that it's a FORD is the problem
Old Aug 10, 2006 | 08:11 AM
fuzzy02CLS's Avatar
At least older Ford problems are common among all their lines. So if you know the problems of 1 Ford you can fix most any Ford.
Old Aug 10, 2006 | 09:13 AM
Chief F1 Fan's Avatar
It's a FORD?
I was gonna say it's old. Christ, the thing is 23 years old, what do you expect?
Old Aug 11, 2006 | 11:47 PM
Ron Burgundy's Avatar
Just the facts...
how much longer on the extended warranty?
Old Aug 12, 2006 | 01:38 AM
SpeedyV6's Avatar
Are you gonna let us know what the problem was?
One last possibility that no one has mentioned is a clogged catalytic converter. If that's the case this problem would most likely manifest itself under heavy engine loads (e.g.: 3/4 throttle or more).
Old Aug 12, 2006 | 09:42 PM
Minch00's Avatar
Pit Stop?
I haven't been able to determine what the problem is yet. I need to take it in to a mechanic, but finding time to do so is proving troublesome. I was quoted around $800 for a new fuel pump and installation
Old Aug 12, 2006 | 09:45 PM
Crazy Bimmer's Avatar
I thought you and your dad was restoring it?
Changing a fuel pump isnt that hard....
Old Aug 12, 2006 | 09:51 PM
Minch00's Avatar
Pit Stop?
I don't have all the details yet, I don't even know if that's the problem. We are restoring it, but we'd also like to be able to drive it, you know
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
jfman55
Sep 5, 2015 02:55 PM
jordanboi
Sep 5, 2015 01:33 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
