Can someone please explain the video too me?
Floyd Mayweather Jr.
How does this happen? I'm assuming both cars are stock.
http://www.youtube.com/watch?v=BA5X7dmAQrk
dɐɹɔ ǝɥʇ ʇɐɥʍ
Originally Posted by S A CHO
The only logical thing I can think of (assuming the SLR didn't lift off) is nitrous.
I would guess engine management upgrade on the SL65, increasing boost.
AMG SL65
Type: V12, Biturbo
Displacement cu in (cc): 365 (5980)
Power bhp (kW) at RPM: 604(450) / 4800
Torque lb-ft (Nm) at RPM: 738(1000) / 2000-4000
Redline at RPM: 5950
Electronically limited to 155 so I am guessing this is the brabus SL65 in the video.
Brabus offers an engine swap for the SL65.
BRABUS T65 S performance kit, 715 hp / 526 kW, 1,100 Nm
Type: V12, Biturbo
dɐɹɔ ǝɥʇ ʇɐɥʍ
Originally Posted by TSXey
this is not true
That was uncalled for...
Originally Posted by Tireguy
Nitrous on a turbo car is usually a bad idea.
Yes it is, on most modern cars with out re-programing the engine management you'll have detention, which will dramatically shorten the life of the engine and probably end up losing hp instead of gaining. Yes, it can be done, but typically its not wise unless you have a good understanding of what your up against. A lot of turbo cars are running moderately high compression from the factory these days.
No it's not.
But maybe I see your point ...which seems to be that if you do it "wrong" it is a bad idea. So I agree with that.
Originally Posted by mltk53
vtec kicked in yo~
navtool.com
31
11-16-2015 08:30 PM
