Can I Get Some Help. My father's Camry won't start..?
Not a Registered User
It's a 2000 Camry w/ about 105,000 miles on it, but it usually runs very strong. This is completely out of the blue, the car wasn't showing any signs that it was about to die before this.
When I turn the ignition, all I hear is a very fast clicking noise. Almost like a woodpecker pecking on a plastic tree.
that is the battery, replace and hope alternator isn't shot.
Originally Posted by peacefrog
Step 1. battery?
Step 2. For sale sign in window
Step 3. Acura Dealership
And oh right...IBTMOVETOCARTALK...
USTHS76
It could be the starter. But, before you buy a new one, check the negative battery cable for corrosion or grease build-up specially the end that bolts to either the car body or the engine block. Unbolt and thoroughly clean both mounting areas. This will only work if the battery is still good. Hope this helps.
If yuo're hearing the ticking. It's the battery. The battery could've been on it's last limb and you just didn't know it. Give it a jump and see if it helps. If it does, it's the battery. Change battery and you'll be fine. Get an Optima battery for optimum crisp starts.
If it was the starter, you wuoldnt' hear anything. It would just be silent when you turned the key.
08_UA7_Gr33k
02-11-2016 02:17 PM
DerrickW
11-15-2015 05:52 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
