3M Headlight Kit Results
Old Aug 17, 2014 | 08:57 AM
Chief F1 Fan's Avatar
my 530's right headlight clouded over so I plopped down $30 (I think) and had at it.
Before:
After:
It took about half an hour with a multi-step process being involved but was well worth it IMO. Huge difference driving home from a wedding last night in the country where there's no streetlights.
http://3mauto.com/products/headlight...tem-39008.html
Old Aug 17, 2014 | 09:08 AM
MSW 6SP's Avatar
It looks much better. My advice is to apply Blue Magic Headlight Sealer every other week or whenever you wash the car. It will keep the haze from coming back. It keeps my JDM headlights on my RL looking brand new
Old Aug 17, 2014 | 09:10 AM
thanks for the tip
Old Aug 17, 2014 | 09:35 AM
Hapa DC5's Avatar
אני עומד עם ישראל
that's a huge difference
Old Aug 17, 2014 | 01:06 PM
CLtotheTL32's Avatar
Very nice!
Old Aug 17, 2014 | 01:41 PM
knight rider's Avatar
Rooting for Acura
Looks good. I am curious about what the difference between these kits and traditional cleaner wax is. I remember using a Meguier's three-step on my headlight housings, and got the same result. It does take some "elbow grease" but it worked great. Even Mequier's Scratch X followed by a regular wax seems to do the trick. I am glad to say that my car is in a garage at home and at work, so I haven't had to do this in years. I do wax the housings every once in a while though.
Old Aug 17, 2014 | 02:24 PM
MarbleGT's Avatar
'08 MX5 GT 6spd.
I recently wet sanded my headlights as well. I researched the clearing a bit and saw that a Mineral Spirits/Spar Urethane mix can double as a long lasting UV clear coat as well.
Get something on them quick to preserve your good work or you'll be sanding again in a couple of months!
Old Aug 17, 2014 | 02:33 PM
ariantl13's Avatar
5th Gear
That looks pretty good
Old Aug 17, 2014 | 04:31 PM
TLDude876's Avatar
Chapter Leader (Houston)
Did this Friday on two cars. I have used the 3m kit before and personally I prefer to buy different grits of sandpaper and get the job done. I believe the 3M kit comes with a 500 or 800 grit as the first step. To avoid sanding too much of the headlight material I asses the lens to determine what grit to start with. The lowest I've had to go with is 1000 then I continue with 1500, 2000, 2500 and 3000. After sanding I buff with 3M compound, polish with Meguiars Plast-X then seal with Blue Magic Lens sealer.
Old Aug 22, 2014 | 03:42 PM
dallison's Avatar
registered pw
it looks awesome!
Old Aug 22, 2014 | 07:27 PM
YeuEmMaiMai's Avatar
I am going to do this to my CL-S headlights and then seal them with a clear coat paint... nice job OP...
Old Aug 22, 2014 | 08:50 PM
neuronbob's Avatar
I just did this to my "new" Pilot tonight with the Meguiars headlight kit (hand-sanding) as those headlights were severely oxidized. They look much better but I may have to re-sand a bit. HUGE difference these kits make. Thanks for the tip on preserving the work done, the Meguiars kit comes with protectant as well.
Old Aug 22, 2014 | 09:05 PM
achenator's Avatar
I have pretty much found that anything 3m brand works as advertised.
Old Aug 23, 2014 | 06:22 AM
I was ignorant about the whole thing really-just walked in to Autozone and asked which kit did the best and got referred to the 3M kit. Minimum amount of risk cost-wise so I went for it and glad I did.
Old Aug 23, 2014 | 02:53 PM
CLpower's Avatar
teh Senior Instigator
I used the meguiars kit on my 7. Results were good, I think i started to lose my patience and need to go over it again.
Old Aug 23, 2014 | 03:42 PM
Steven Bell's Avatar
cycdaniel
Dec 17, 2019 10:58 AM
BoricuaTL
Apr 8, 2016 01:08 PM
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Sep 17, 2015 08:57 PM
