2012 GT-R goes 0-60 mph in 2.7 seconds!?!
Old 02-01-2011, 09:47 PM
  #41
speedemon90's Avatar
Originally Posted by MTwEeZi
those things apply to almost every car...
what I dont understand is why they give a switch to turn the VDC off...AMG traction control is supposed to always be on but dont make it so easy to defeat
does porsche do this? Or bmw?
edit: i'm talking about driving on a track, not turning the stability or traction control off
Old 02-01-2011, 09:50 PM
  #42
rossv1's Avatar
Originally Posted by WILLDOGS
FTA:
Mizuno says this is to protect the driver’s neck from injury, although we suspect a desire to stem escalating transmission temperatures also factored into that change.
It happened to Jeremy Clarkson.
Old 02-01-2011, 09:51 PM
  #43
ghttf's Avatar
Is this a serious question? If you blow the engine while racing on a track you think they are going to replace it for you?
Old 02-01-2011, 09:57 PM
  #44
ghttf's Avatar
This Warranty Does Not Cover:
• Emission Control Systems and Corrosion. (Refer to the Emission Control
and Corrosion Limited Warranties in this Booklet.)
• Batteries damaged from storage, lack of normal vehicle use, or non-
Porsche approved electrical or accessory installation.
• Tires damaged by road hazard. (If you need further assistance, contact
your authorized Porsche automobile dealer.)
• Tires damaged by premature wear.
Note: Porsche's race-bred heritage demands that tires are an integral
part of the vehicle suspension, braking, and active safety systems. As
a result, all Porsche automobiles are equipped with tires designed for
higher performance than those found on other passenger vehicles.
While tire wear varies with vehicle operation, high performance tires
like these are designed to assist the vehicle's suspension in delivering
increased cornering forces and better handling. Thus, they may exhibit
increased wear characteristics when compared to tires on other
passenger vehicles. Consult your Owner's Manual for information concerning
the proper care and selection of your tires. (Refer to the
Porsche Tire Information Guide for additional information.)
• Parts that fail due to lack of required maintenance or use of non-
Porsche Cars N.A. distributed parts.
• Normal wear or deterioration of any part.
• Cleaning and polishing.
• Contamination of fuels, lubricants, or other fluids.
• Lubricants, unless part of a warranty repair.
• Air conditioner refrigerant charge after the first three months of service
• Glass breakage, chips and/or scratches that are not due to a defectin material or workmanship.
• Appearance items that are not due to a defect in material or workmanship.
• Any car registered or normally driven outside of the United States and
Canada.
• The replacement of expendable maintenance items (such as spark
plugs, filters, worn wiper blades, worn brakes, worn clutches, worn
tires) when the replacement is not due to a defect in material or workmanship.
• The adding of any fluids unless they are needed as part of a warranty repair.
• Any car with an odometer that has been altered so that the actual
mileage cannot be determined.
• Dealer-installed accessories not distributed by Porsche Cars N. A.
(Refer to the Replacement Parts and Accessories Limited Warranty in
this Booklet.)
• Wheel balancing and wheel alignment beyond the first three months of
service unless part of a warranty repair.
• Unauthorized modifications or vehicles with total loss or salvage titles.
• Modifications not authorized by Porsche Cars N.A.
• Service adjustments (such as idle speed, air/fuel mixture, brake,
clutch, headlight, and drive belts) beyond the first three months of
• Improper repairs by someone other than Porsche Cars N.A. or its authorized
dealers.
• Abuse, accident, acts of God (wtf), competition, racing, track use, or other
events.
Note 1: Components and/or parts that fail during racing or driving
events (including Porsche sponsored events) may not be covered by the
new car Limited Warranty.
Note 2: You should also be aware that Porsche Cars N. A. may deny
you warranty coverage if your vehicle or a part has failed due to abuse,
neglect, improper maintenance or unapproved modifications.
• Minor wind noise and insignificant seepage at the joints between
the top and the body, or door windows in Cabriolet,
hardtop, or Targa models cannot be completely avoided under
all circumstances. Your Cabriolet should not be washed in a
car wash and may experience damage to the top or rear window
due to the scratching by the brushes or may experience
leaks due to the high pressure water streams directed in areas
which would not experience water in normal driving conditions.
It is extremely important to have the cabriolet and soft top
drains (including the body cowl drains) cleaned as part of yearly
maintenance or more frequently if they become clogged with
debris. Failure to do so may result in subsequent damage.
Please see your authorized Porsche dealership for details concerning
required maintenance.
• The outside of the underbody (floor pan) or any other part of the car
except body panels.
• Paint damage caused by abuse or lack of proper maintenance.
• Environmental damage (such as that caused by acid rain or other industrial
pollution, insect or bird droppings, tree sap, stones or other
flying missiles, highway maintenance chemicals, flood, storm, and
other forms of disaster.)
• Paint color matching. (Porsche Cars N.A. reserves the right to decide
whether painting the repaired or replaced panel to match the original
finish is practicable. Porsche Cars N.A. will not, under any circumstances,
pay for painting the entire car solely for paint color matching.)
• Paint damage caused by the application of unauthorized paint
sealants or polymers. See your authorized Porsche automobile dealer
for details.
Note: Your vehicle is a mechanical device. All mechanical devices
make some sort of noise and/or vibration, and these
noises and vibrations can differ from vehicle to vehicle. PorscheCars N.A. recognizes those noises as normal and characteristic
of the product. Normal noises or vibrations as determined by
Porsche Cars N.A. can be anything from brake squeal to road
vibration. Therefore, normal noise and/or vibration and/or deterioration
as determined by Porsche Cars N.A. or its representative
are not covered by our new car Limited Warranty.
Your Responsibility for Using Appropriate Replacement Parts
Porsche Cars N. A. recommends only the use of parts supplied by
Porsche Cars N. A. The use of replacement parts not supplied by
Porsche Cars N. A. may void some or all of your car’s limited new car
warranty. If a replacement part that Porsche Cars N. A. did not supply is
used in maintenance, repair or modification of your car, and an authorized
Porsche representative determines it is defective or not equivalent
to the original part, your claim for warranty repair or some or all of your
car’s limited new car warranty may be voided.
Your Responsibility for Maintenance
You must maintain your Porsche automobile according to the Maintenance
Schedule in the Maintenance Booklet and the Car Care Instructions in
the Owner’s Manual and keep the receipts as proof of maintenance.
Your Responsibility for Normal Vehicle Use
Your Owner’s Manual (which includes specific recommendations against
using your car in certain ways) was written with the assumption that you
will use your car only in ways for which it was designed:
• To carry passengers and cargo within specified load limits. (The
load limits are specified on labels located in different places
depending on your model Porsche. Your Owner’s Manual gives the
locations.)
• To be driven on reasonable road surfaces within legal speed limits.
Porsche Guidelines specify reasonable mileage to be at least 15
miles / 24 kilometers per day or 6000 miles / 9600 kilometers per
rolling 12 months.
• If you drive less than the above-mentioned limits, or in the event of
prolonged storage, contact your local authorized Porsche dealer for
instructions.
(Note: A battery maintainer is available at your local authorized
Porsche dealer. It must be used to maintain your vehicle’s battery
state of charge if your vehicle will not be used for several days.)
• To be run on unleaded gasoline with the recommended octane
rating as specified in the Owner‘s Manual.
• To be properly maintained according to the Maintenance Schedule
in the Maintenance Booklet and Car Care Instructions in your
Owner’s Manual. You must keep the receipts as proof of
maintenance.
You are responsible for presenting your Porsche automobile to a
Porsche dealer as soon as a problem exists. Failure to do so could result
in consequential damage that may not be covered by your limited
factory warranty.
http://www.porsche.com/usa/accessori...rrantyperiods/
Old 02-01-2011, 09:58 PM
  #45
SpiderX1016's Avatar
WHile more expensive C&D got the 911 turbo to do 2.7 seconds
The fastest 0-60 i've done in a car is my moms accord. which is low 6's possibly high 5's. Other than that I've done it in my acura, and my dads corolla. I wonder how that feels
I've been in an 08 GTR and my god, that was fast. It hits you out of nowhere.
Old 02-01-2011, 10:02 PM
  #46
well i meant it like this. Say I go on a track day, and a couple weeks or a month later something happens to the transmission. Will it be covered?
well i guess they have no clue if you used it at a track
I guess I never knew they put it in fine print.
but like the gtr first came out. If you used the launch control, and later your transmission goes out. Nissan knows you used launch control, so your warranty is voided.
Old 02-01-2011, 10:11 PM
  #47
ghttf's Avatar
All GTR owners that have LC1 used before and were afraid that the tranny did not have any warranty because of turning VDC off and doing a LC1 will have their warranties re-setted for 5yr or 60k miles if they upgrade to LC2. All LC1 will be forgotten and the tranny will be fully covered by NISSAN. After LC2 being installed, all LC2 with VDC on will be fully covered by NISSAN. If you turn VDC off today , do your thing ( drag/road course/etc) and the tranny goes bad at that moment, the warranty will not hold, BUT if the problem arises some time later after turning VDC off back on and driving the car without any issues then the tranny will be covered 100%. If not NISSAN WILL HAVE TO PROVE that turning VDC OFF a week or a month prior the damage was the cause of failure. THEY WILL NEED TO PROVE IT , not like before that they just saw the BB data and said it was not covered.
http://www.nagtroc.org/forums/index.php?showtopic=33578
Old 02-01-2011, 10:21 PM
  #48
AZ Community Team
Bearcat94's Avatar
Received 7,771 Likes on 4,342 Posts
I've always liked the GT-R.
At under $100k, it's a supercar I can aspire too. It's not the ONLY one, but it is one of the few.
Old 02-02-2011, 12:37 AM
  #49
Punk Rocker
majin ssj eric's Avatar
Seems like Nissan has finally corrected its stupidity in regards to the LC warrranty fiasco. Limiting it to 4 uses before a 1.5 mile "cool-down" seems perfectly reasonable to me. I guess the GT-R haters have just lost one of their major critisms for this car (of course they can always fall back on how ugly it is)....
I still find it funny that all the Porsche "purists" say how much better the 911 is than the GT-R, yet most of the laptimes I've seen have the Nissan quicker than the 911 turbo/GT3 RS:
C&D Lightning Lap
10 2:55.6 NISSAN GT-R LL3 11/08
11 2:55.9 PORSCHE 911 GT3 RS LL4 2/11
12 2:57.4 DODGE VIPER SRT10 LL3 10/07
13 2:57.5 PORSCHE 911 TURBO S LL4 2/11
TG Power Laps:
Nissan GT-R - 1:19.5
Porsche Carrera GT - 1:19.8
Porsche 911 Turbo - 1:22.2
Porsche 911 GT3 RS - 1:22.3
Certainly faster does not equal better, but considering the price penalty for the so-called "P-car" I'd definitely opt for the faster GT-R...
Old 02-02-2011, 12:44 AM
  #50
myron's Avatar
I bet tranny will fail after a couple cycles of 4 launches and 1.5mile cool downs. Do 4 launches, cool down, then do that 10 more times. And trannies will start failing again.
Old 02-02-2011, 05:14 AM
  #51
Your Friendly Canadian
Aman's Avatar
Received 1,485 Likes on 1,049 Posts
Originally Posted by Bearcat94
OK, who're the physics brains here?
0 - 60 mph in 2.7 seconds, assuming constant acceleration, is how many G's?
1.00781 G
I'd take a porsche any day of the week over the GT-R. The GT-R is stupidly fast. Thats really all it has. From readings, the only way the car is fun is if you are driving fast. You don't feel connected to the road as you do in other cars, like porsche which I hear has one of the best connectedness out there.
I think this is more to do with outright performance though, and in that arena the GT-R wins hands-down. Besides, I'm pretty sure the GT-R is exciting and involving in its own right. Kinda like the whole 328 vs. G37 magazine debates.
Originally Posted by Crazy Acura
2012 owners manual
http://www.nagtroc.org/files/2012-Nissan-GTR.pdf
What a buzzkill.
Originally Posted by pttl
"Buy our really fast car but don't do anything with it. It wasn't really meant to be driven like a high performance car. We were just trying to undercut Porsche price wise. We didn't really think the people who would buy an 80 thousand dollar Nissan would actually want to drive it like a Porsche. Sorry....we want you to buy, but don't play.
Nissan"
and . Fine print FTL. But on the other hand, I bet all manufacturers don't cover "competition use". More a complaint with hi-po car manufacturers in general.
C&D Lightning Lap
TG Power Laps:
I think they're just different options. GT-R if you want the fastest car, period. 911 Turbo if you want an involving drive, I guess. Different strokes.
Old 02-02-2011, 05:40 AM
  #52
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,652 Likes on 1,117 Posts
The problem is that you can't assume constant acceleration when friction forces, tires, and all that make contact with the ground. It's constantly changing. You'd have to find the G force AT 2.7 seconds.
But, playing your game, using the equation v = u + at, where u is initial velocity, and v is the final velocity of 60MPH (26.67m/s), and t is time elapsed of 2.7 seconds, you have an acceleration of 9.87 m/s^2, almost 1.01 times the force of gravity.
Old 02-02-2011, 08:31 AM
  #53
achenator's Avatar
The GT-R transmission issues were way overblown. Plenty of peeps running 600whp and having no problems. There were some solenoid issues in early cars and with the very first launch control. 10's and 11's have been rock solid. I paid $70k for my absolutely fully loaded 2010 with 1500 miles, to me it was a bargain. That being said, would I pay $90k? Almost certainly not. I love the car. Do I love it more than I loved my M3? Not really. Just a different car.
Old 02-02-2011, 09:18 AM
  #54
Pinky all stinky
phile's Avatar
events.
LOL that's actually common, and everyone's insurance policy, not just the automaker's warranty. should have that.
Acts of God basically means freak accidents, like a tree limp snapping off and falling on your car.
EDIT: that would actually/should be covered under Comprehensive. AOG would be like a major flood or hurricane or disaster.
Old 02-02-2011, 09:22 AM
  #55
CLtotheTL32's Avatar
Received 9,507 Likes on 6,176 Posts
I'm so sick of LEDs going on the front bumper of so many cars nowadays
Personally I love the GTR. It would be hard to buy one over a 911 though.
Old 02-02-2011, 10:27 AM
  #56
Be a better driver
RedRyder's Avatar
Originally Posted by ANC297
Honda is on the right track, Acura is not. IMO
I hate what Honda is doing right now. The Odyssey, Civic, and CRV look alright, but the Accord, Fit, Pilot, and CRZ are awful. I know Acura has been criticized for lack of direction, but I still think they look decent.
Originally Posted by jayhawk815
fixed.
While it could look better than their current production models, let's not get carried away here.
Your quote is the same as my post. But I think I know what you meant.
I hated the 4G TL for the longest time, but after seeing this guy's car I know the potential it has.
https://acurazine.com/forums/showpos...&postcount=177
https://acurazine.com/forums/showpos...&postcount=187
Now I love them. So for me, the NSX potentially could look great. Then again, the 2010 concept was nothing special so who knows.
Old 02-02-2011, 10:49 AM
  #57
אני עומד עם ישראל
Hapa DC5's Avatar
Maintenance costs on the 911 comparable or more I assume?
Old 02-02-2011, 11:44 AM
  #58
Punk Rocker
Why the hell would anybody do that???
Old 02-02-2011, 12:01 PM
  #59
CousinJoey's Avatar
That's sick!
Old 02-02-2011, 12:14 PM
  #60
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
While i will admit that its a fast car, i would much rather have a Porsche. But at the near 100k mark i would spend a little extra and get a ZR1. Something i know i can drop the clutch over and over and not do any thing other than ruin tires, and its cheap to make more power.
Old 02-02-2011, 03:53 PM
  #61
Punk Rocker
I wouldn't call a ZR1 clutch replacement "cheap".
Old 02-02-2011, 04:13 PM
  #62
jayhawk815's Avatar
I changed a portion of your post to a red text representing sarcasm, if there's any remaining confusion. I still hate the stock looks of the 4G TL. Sure, you can perform a number of mods to make it look decent. Still, you shouldn't have to performs mods on a car just to get it looking decent.
Old 02-02-2011, 04:16 PM
  #63
myron's Avatar
I don't know. You got a car that can got 0-60mph in 2.7sec. Why the hell wouldn't you do that?
Old 02-02-2011, 04:19 PM
  #64
I got the Shifts
phee's Avatar
he didnt. he said making power is cheap.
Old 02-02-2011, 05:12 PM
  #65
Por Favor?
Brandon24pdx's Avatar
I miss the old days when GT-R's were basically AWD Toyota Supra's...essentially indestructible. I'd be scared to own one of these new ones.
Old 02-02-2011, 07:49 PM
  #66
Costco's Avatar
Received 3,489 Likes on 2,089 Posts
I didn't think they could do it, but they made the GT-R even uglier with the refresh
Impressive, definitely. But as good as it is, like the 4G TL, I just can't get over the styling.
Old 02-02-2011, 08:01 PM
  #67
AZ Community Team
Bearcat94's Avatar
Originally Posted by Aman
1.00781 G
Thanks.
Well, that's why they call 'em "assumptions". It allows you to fix some parameters to define an estimate.
Regardless, I'm not sure the G's AT 2.7 seconds is what I'd want to know. What I mean is, I'd be more interested in the MAX G in a "typical" 0 - 60 in 2.7 seconds. I'd guess that would occur just after launch or perhaps at a gear change as opposed to the end of the run.
Old 02-02-2011, 08:18 PM
  #68
nokiaman's Avatar
70k is one thing, but around 100, there's just a ton more options. Only a C2S/C4S can be obtained new around that price point and they still come short performance wise, making the ZR-1 the best car for the money.
But again, 100k buys a 07-08 GT3RS nowadays.
Old 02-02-2011, 08:22 PM
  #69
Elcoqui128's Avatar
Even if they bring the NSX back i dont think it will keep up with the GTR. unless they put 600 horses under the hood/trunk. and add some VTEEEEEC
Old 02-02-2011, 08:41 PM
  #70
Elcoqui128's Avatar
But if i ever have $90,000 i would get that GTR. wouldnt drive it too much because insurance and gas. lmao. but it would still feel good knowing i have 1 of the fastest cars out there. haha
Old 02-02-2011, 09:36 PM
  #71
I think if you had 90 grand, you wouldn't complain about insurance or gas lol.
Old 02-02-2011, 09:44 PM
  #72
Punk Rocker
Is definitely go GT-R over a ZR1 just because the limits of the Nissan are so much more accessible than those of the Chevy. Just the slightest mistake in a Corvette will kill you but the GT-R will just settle down and go. Fast.
I'd feel a 1000 times more confident in a GT-R on a track day than the axe-murderer ZR1....
Old 02-02-2011, 09:52 PM
  #73
Can you get a ZR1 for $100,000? Last one I saw the sticker was close to 140k. Keep in mind this was a few months after the release.
Old 02-02-2011, 09:56 PM
  #74
Elcoqui128's Avatar
Lmao. i think 90k only covers the car. hahaha well im trying to go overseas being a contractor so i might just get that 90k hahaha
Old 02-02-2011, 09:58 PM
  #75
Crazy Bimmer's Avatar
Cheapest new ZR1 i saw was $109k.
The one my buddy has on his lot is stickered at $124k.
Old 02-02-2011, 10:14 PM
  #76
nokiaman's Avatar
If you look hard enough you can find one around the 110k area that's not too loaded...When they first came out, some dealers had ridiculous markups...
It's a matter of personal opinion I guess, but yes the ZR1 demands more driver skill to fully enjoy it, one that probably a pro can fully extract.
Let's not exaggerate, the slightest mistake in a C6 will not kill you; you just have to be gentle and moderate with the throttle just like you have to remember an AWD car isn't above the laws of physics. I've seen drivers at track events with AWD, dealing with lift off oversteer as well.
Axe-murderer? You just need to know how to deal with opposite lock.
Old 02-02-2011, 11:08 PM
  #77
ThermonMermon's Avatar
dear lord, that thing is ugly
Old 02-02-2011, 11:27 PM
  #78
Costco's Avatar
It's just a matter of taste, like blondes or brunettes. As great as they both are for the money, there are those who will never take a GT-R or a ZR1 for the price. I just prefer the way the ZR1 looks and sounds (don't get me wrong, the GT-R sounds good but there's no way it can beat the sound of the blown LS9) and I like the fact that it comes in a 6-speed manual.
The GT-R has very little appeal to me, though I can see why a lot of people love it. The sooner people start seeing this, the less often threads will end up devolving into a GT-R vs. ZR1 or GT-R vs. 911 Turbo/GT3/etc. or GT-R vs. whatever debate
Old 02-02-2011, 11:42 PM
  #79
To me its not about lap times. First off I'll probably never be racing on a track competitively and neither will most of you. Just against yourself or with friends. Being that, it doesnt really matter if you have a gtr or 911. The driver will be the bigger factor. And I dont think learning to race in a gtr will make you a better driver.
That being said, I'll take the car thats more engaging to the driver over the one that produces a better lap time
Old 02-03-2011, 02:21 AM
  #80
Ultra Negro
OperationDarkie's Avatar
I would buy one, and I would use it as my weekend warrior road course car, put some R compounds on it and have fun.
Quick Reply: 2012 GT-R goes 0-60 mph in 2.7 seconds!?!
