2006 Ferrari 612 Scaglietti by Novitec
The car looks too happy for me ( face)...but, I'd still take one...
Specifications
Engine
Type: V12
Displacement cu in (cc): 351 (5748)
Power bhp (kW) at RPM: 555(408) / 7250
Torque lb-ft (Nm) at RPM: 442(599) / 5300
Redline at RPM: n.a.
Brakes & Tires
Brakes F/R: ABS, vented disc/vented disc
Tires F-R: 275/35 R19 - 335/30 R20
Driveline: Rear Wheel Drive
Exterior Dimensions & Weight
Length × Width × Height in: 191.2 × 76.3 × n.a.
Weight lb (kg): n.a.
Performance
Acceleration 0-60 mph s: n.a.
Top Speed mph (km/h): >196 (>315)
Fuel Economy EPA city/highway mpg (l/100 km): n.a.
The Italian tuner Novitec offers the following accessories for the 612 Scaglietti:
- Power upgrade through modified engine electronic as well as stainless steel exhaust system without flap-regulation
- High-performance brake system NCCB (NOVITEC Composit Ceramic Brake), including two 8-pistons brake- calipers and 380 mm ceramic- discs for the front and two 4-pistons brake- calipers with 380 mm ceramic- disc for the rear, 2 brake- air blades, steel- flex brake lines and brake pads. Weight reduction in comparison with standard 20,5 kg (only mountable in combination with NOVITEC 19” inch wheels)
- Set of rearlights
- Set of side indicators
- Stainless steel coil over suspension Sport (dual adjustment), including dual adjustable stainless steel shock absorbers with separated expansion reservoir at damper housing, compression and rebound adjustable in front and rear
- Aluminum wheels:
9,0J x 19J ET 28 for the front axle
12,5J x 20J ET 46 for the rear axle
9,0J x 19J ET 28 for the front axle Chrome-paint finishing
12,5J x 20J ET 46 for the rear axle Chrome-paint finishing
- Pedal set aluminum
- Foot rest aluminum
- For the interior, various colors for leather are available, optional alcantara, surcharge for special colors
Specifications
Engine
Type: V12
Brakes & Tires
Performance
- Set of rearlights
- Aluminum wheels:
very subtle changes... but I'm happy to report I would drive it...
stunning
Big Block go VROOOM!
Originally Posted by SanJoseRoller
is it me or does this thing resemble the Porsche 944 ALOT
Other than the happy face grill, I like this one better!
Yes it is!
Can a Ferrari nut answer this question for me:
Some Ferraris I see have the sheild on their front fenders, some don't. I've even seen the same model with shields and without.
Is that like an option to be added by the owner, or do the sheilds actually indicate something (like a trim level, etc).
Need to add this to my list of Must have's wheni win the lottery!
Originally Posted by srika
it's an option. it doesn't indicate anything other than, the owner wanted it.
Originally Posted by Billiam
History question for anyone in the know, has the shield always been available on the road cars? I was under the impression that the shield used to only be employed for the Scuderia logo (with the SF) and that its use on road cars is a recent thing. "Recent" being relative to Ferrari's age, of course.
here's some further info on the shield option, straight from the horse's mouth:
http://www.ferrariusa.com/360Modena/...ontent=Options
Ahhh... see that's different. For some reason the pcitures of the 612 appeared to me as if it had the shield logo without the SF. Now that I see that option is the full Scuderia logo, it makes more sense.
My Garage
Actually, the Aston Martin DB9 was the first thing that popped into my head.
quite sure it does have the SF.. hard to see, but pretty sure its there.
Yes it is!
Rooting for Acura
It just don't say, "I'm a Ferrari"
That one is hot though and I would pimp it.
