2005 GTO Judge
Old Sep 8, 2004 | 12:38 PM
savage's Avatar
Engineer
2005 GTO Judge
http://www.honda-acura.net/forums/sh....php?p=1889084
looks good...i wonder how it handles...
Engine Displacement: 6.4L (389 CID)
Bore: 105.03mm (4.135”)
Stroke: 92.00mm (3.622”)
REV Limit: 7000 RPM
Peak Hp: 575 Hp @ 6800 RPM
Peak Tq: 500 Lb-Ft @ 5200 RPM
Compression Ratio: 10.5:1
Cam Shaft: Custom GM Hyd Roller
Valve lift: 15.75mm (.620”)
Cam Duration Int: 232 deg @ .050” Tappet
Cam Duration Exh: 272 deg @ .050” Tappet
90mm Throttle Body
Dual Mass Air Flow sensors, Cold air induction system
Old Sep 8, 2004 | 12:41 PM
fdl's Avatar
fdl
are those for sale? how much $$?
Old Sep 8, 2004 | 12:50 PM
DEI99662's Avatar
The front still looks like a Grand Prix. What a waste of what once was an awesome car.
Old Sep 8, 2004 | 01:04 PM
savage's Avatar
Engineer
no clue, could be a close to production version they are showing to see how people react, i just came across it and thought i would put it up...maybe someone else on here can provide us with more info?
dom's Avatar
dom
It will be using the new LS2 engine used in the C6, Rated at 400HP/400lb/ft.
Old Sep 8, 2004 | 01:05 PM
fdl's Avatar
fdl
Its a pontiac, so its gotta look like a pontiac. Its like how people say the TSX looks like a civic. And a BMW M3 looks like a 320i.
Old Sep 8, 2004 | 01:06 PM
fdl's Avatar
fdl
Originally Posted by domn
It will be using the new LS6 engine used in the C6, Rated at 400HP/400lb/ft.
SO the posted stats are incorrect?
Old Sep 8, 2004 | 01:07 PM
dom's Avatar
dom
A post from the link.
speaking of power -
All engine parts are from the Gen IV small block family
REV Limit: 7000 RPM
90mm Throttle Body
Don't buy it, at least not for the production version.
Old Sep 8, 2004 | 01:11 PM
dom's Avatar
dom
GM will never rate another car that uses the same engine with more HP than a Corvette. (ie, 400HP CTS-V compared to 405HP Z06 both used the LS6)
GTO fans should consider themseleves lucky their getting the LS2 from the C6.
Old Sep 8, 2004 | 01:29 PM
TSX 'R' US's Avatar
Old fart
Looks are still not agressive enough...
Old Sep 8, 2004 | 01:47 PM
21_in_az's Avatar
Do I Make You Horny?
its gota be a ls6, boosted somehow...........like supercharged.......
or, this is bullshit!
domn is right, in their eyes the Z06 is GOD with 405hp, all NA........the only way to get that much HP is Bossted!!
but, GOD DAMN that would be sooooo sick!! that thing would desamate ALL!!!
Old Sep 8, 2004 | 02:01 PM
dom's Avatar
dom
I read in one of the big 3 mags that the 05 GTO is getting the LS2 from the C6, But now that I think about it I don't think they were referring to the Judge, The regular GTO is getting the 400HP LS2, so those stats MAY be correct.
And its fact that the next Z06 will be using a 6.4L V8 dubbed the LS7 so I guess the Judge is getting the same engine although I highly doubt that engine is capable of 575 ponies? and I highly doubt the GTO would be rated as high as the Z06.
Old Sep 8, 2004 | 02:04 PM
ClutchPerformer's Avatar
Does anyone know what the new Vette's compression ratio is? How about the redline?
Old Sep 8, 2004 | 02:09 PM
dom's Avatar
dom
and a higher compression ratio (10.9:1 versus 10.1:1)
I believe redline is somewhere around 7000.
Old Sep 8, 2004 | 02:15 PM
TdotSSTSX's Avatar
You all suck.
the orange car is a special vehicle motorsports car that has been boosted to create excitement around the launch of the GTO. The blue GTO in the film has nitrous.
400hp is probably overstate, if they even decide to sell a hopped up version, it will be like 375, more like a TA replacement....
Old Sep 8, 2004 | 02:18 PM
So this Judge has a LOWER compression ratio, the same redline and makes 160 more HP than the Vette with nothing more than 0.4L and a glorified CAI? Even though those cams are very, very agressive, I'm going to go ahead and call . This car is impossible.
Old Sep 8, 2004 | 02:56 PM
jiggaman's Avatar
I spend 2 much time here
definately an improvement over the GTO that just came out. that thing looks wimpy.
Old Sep 8, 2004 | 03:06 PM
Dan Martin's Avatar
Photography Nerd
That "ram air" system sure doesn't look very impressive. The scoops are 1/2" high and the intake has to make an S-turn before it enters the throttle body. I bet our CAI flows more air and a cooler charge than that system does.
575hp would have to come from forced induction, likely a supercharger.
Old Sep 8, 2004 | 03:10 PM
DEI99662's Avatar
Nothing like the ones from the 60's and 70's.
Old Sep 8, 2004 | 03:11 PM
DEI99662's Avatar
I see your point but TRU is right. It does not look aggressive enough.
Old Sep 8, 2004 | 04:04 PM
gfxdave99's Avatar
6MT Snob
Okay im selling my trans am and my TSX...
(just kidding)
But im sorry, it looks way better then the previous GTO
Hey you have to give pontiac SOME credit, they put out a dud, they try to do something with it right away.. For example, the Pontiac ASSTek, the first year of it was UGLY AS SHIT.. Did they wait a few years to do something? No the next model year they updated the styling, its still not amazing but I have to say it is better looking then the 1st year.
Old Sep 8, 2004 | 04:06 PM
Dan Martin's Avatar
Photography Nerd
IMO it's the best looking Pontiac since the 70's
Old Sep 8, 2004 | 04:14 PM
TSX 'R' US's Avatar
Old fart
Oh I think it looks great...but if it looks just a little bit more agressive...
I dunno... without the hood scoops, side flares...it just looks like a previous gen two door grand prix...
Old Sep 8, 2004 | 05:34 PM
lokman's Avatar
Boy Genius
I think the GTO looks plain, but certainly far from ugly. Probably not aggressive enough for a GTO, but given that Bob Lutz just looked over to GM's Australia operations to pull a decent platform over to North America within a year or two is definitely not bad. Wonder what Bob has in mind for us with the next generation GTO? IMO, the Holden Monaro and previous-generation Commodore on which the GTO is based are some of the best-styled cars on the road bar none.
Old Sep 8, 2004 | 06:21 PM
xizor's Avatar
Bye TSX, hello domestic?
looks pretty decent to me, a lot better than the vanilla GTO styling. I wouldn't buy that over a Corvette however.
Old Sep 8, 2004 | 07:22 PM
Dan Martin's Avatar
Photography Nerd
The C6 is a sweet ride.
Old Sep 8, 2004 | 09:02 PM
captainjack's Avatar
Über Geek
I agree. Not that it will ever see the flourescent light of a showroom floor. But it's sharp. I love the rims. The fender flares smack of Skyline. In fact, this is a pretty nice blend of American muscle (via Australia) and tuner style.
Old Sep 8, 2004 | 09:42 PM
jcg878's Avatar
Obnoxious Philadelphian
(just kidding)
Which of these is the newer, better looking one??? I still cringe every time I see one.
I think the Judge looks way better than the base GTO.
Old Sep 8, 2004 | 09:43 PM
CGTSX2004's Avatar
I rather like the look. It's far more aggressive than the standard GTO. A true GTO Judge would be
Old Sep 9, 2004 | 08:21 AM
dom's Avatar
dom
Officially the 05 GTO (Not Judge) will get the C6's 6.0L 400HP LS2 but rated with 5lb-ft less than the Vette at 395. The old 5.7L LS1 is dropped altogether. If there is a Judge we won't see one for the 05 MY.
agupta3224
May 23, 2017 08:30 AM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
Oakroadsteve
Oct 28, 2015 10:28 PM
lanechanger
Oct 13, 2015 10:56 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
