03 galant problem
Old Jan 31, 2008 | 11:58 AM
kosstick's Avatar
03 galant problem
I think it is is 03 or 02 galant... The engine starts for half a sec then dies out. I see the RPM gauge go to 1.. The steering becomes loose (like when the engine is on) then the engine dies out half a sec later...
What could this be from ?
Old Jan 31, 2008 | 12:08 PM
evilone's Avatar
COME AT ME BRO!
throttle cable not on? thtas just a guess I have no idea. Have you done a compression test?
Old Jan 31, 2008 | 12:35 PM
kosstick's Avatar
its my grandpas but my sister was borrowing it .. Now she is borrowing my tl-s and my heart is aching cuss i know shes gonna fuck it up loll
Old Jan 31, 2008 | 03:00 PM
NSXNEXT's Avatar
Bad gas, plugs, clogged air filter? Jeez it could be a ton of things?
Does the check engine light come on?
Tell her once it's started to give it some gas and see if it keeps it from stalling
Old Jan 31, 2008 | 03:12 PM
kosstick's Avatar
it wont start.. Ive tried it.. the motor starts i pump the gas pedal and i got no reaction... All the lights are on.. But the car starts for a split second... (all lights come on ON mode) but it doesnt go away when the car semi starts
Old Jan 31, 2008 | 03:35 PM
BENDER08's Avatar
Back in a TL again.
1. turn on the ignition and see if the car has gas
2. check the sparkplugs.
3. check and make sure has oil then report bak
Old Jan 31, 2008 | 03:41 PM
kosstick's Avatar
gas check how can i check spark plugs lol ?
Old Jan 31, 2008 | 03:45 PM
BENDER08's Avatar
Back in a TL again.
check and make sure the oil is there
Old Jan 31, 2008 | 03:47 PM
BENDER08's Avatar
Back in a TL again.
Spark plugs i would first unplug each one one at a time from each end, make sure they look good not corroded then start the car again. if it is a no go then unscrew each spark plug check them.
BENDER08's Avatar
Back in a TL again.
if it has one check the fuel filter.
Old Feb 1, 2008 | 11:56 AM
SakiGT's Avatar
Take it to a shop.
Old Feb 1, 2008 | 02:53 PM
SodaLuvr's Avatar
Originally Posted by SakiGT
Take it to a shop.
Old Feb 1, 2008 | 03:09 PM
CL Platano's Avatar
Tristate ViP Crew
Problem is that its a Galant
Old Feb 1, 2008 | 03:28 PM
NSXNEXT's Avatar
Could be a hundred different things. Anything from bad fuel pump, clogged injectors, bad gas, distributor/rotor, security key issue.......
Have it towed to a shop.
Old Feb 2, 2008 | 09:35 AM
evilone's Avatar
COME AT ME BRO!
:Iagree: it's almost impossable to say what the problem is without looking at the car in person.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
