03 galant problem
03 galant problem
I think it is is 03 or 02 galant... The engine starts for half a sec then dies out. I see the RPM gauge go to 1.. The steering becomes loose (like when the engine is on) then the engine dies out half a sec later...
What could this be from ?
Received 1,080 Likes
Bad gas, plugs, clogged air filter? Jeez it could be a ton of things?
Does the check engine light come on?
Tell her once it's started to give it some gas and see if it keeps it from stalling
it wont start.. Ive tried it.. the motor starts i pump the gas pedal and i got no reaction... All the lights are on.. But the car starts for a split second... (all lights come on ON mode) but it doesnt go away when the car semi starts
Back in a TL again.
Spark plugs i would first unplug each one one at a time from each end, make sure they look good not corroded then start the car again. if it is a no go then unscrew each spark plug check them.
Could be a hundred different things. Anything from bad fuel pump, clogged injectors, bad gas, distributor/rotor, security key issue.......
Have it towed to a shop.
COME AT ME BRO!
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
