Cameras & Photography Because there aren't already enough ways to share photos...
Rechargeable Batteries (AA)
Old Feb 8, 2008 | 01:06 PM
asianspec's Avatar
Which type do you guys have for you camera?
Old Feb 8, 2008 | 01:25 PM
moeronn's Avatar
is learning to moonwalk i
I have energiser rechargables for the flash. They've been great - getting at least 200+ flashes per charge. They should also work well for a P&S. Just get at least 2 or 3 sets worth.
Old Feb 8, 2008 | 01:47 PM
asianspec's Avatar
yea i go thru batteries crazy when im doing alot of shutter shots.
Old Feb 8, 2008 | 01:54 PM
Dan Martin's Avatar
Photography Nerd
I use green label Sanyos and Sanyo Enerloops. For charging I use a Maha MH-C9000 and it's fantastic. Check out www.thomasdistributing.com the next time you're ordering batteries...
Old Feb 8, 2008 | 01:55 PM
moeronn's Avatar
It really depends how fast your camera goes through a charge, but 1 or 2 sets should last you a day and you can recharge at night (or in the car). Get the 15 minute charger if you think you'll run through batteries too fast.
Old Feb 8, 2008 | 02:10 PM
asianspec's Avatar
ok thanks! Thanks for the link Dan!
Old Feb 8, 2008 | 07:50 PM
ChodTheWacko's Avatar
Moderator Alumnus
You must use lithium batteries for digital cameras, by the way.
'normal' alkaline batteries have a different power curve which is totally inappropriate for digital cameras. After your digital camera 'uses up' an alkaline battery, you'll find it still works plenty well with remote controls, etc, etc.
- Frank
Old Feb 9, 2008 | 01:49 AM
asianspec's Avatar
^^hmm good to know thanks man.
Old Feb 9, 2008 | 12:11 PM
Dan Martin's Avatar
Photography Nerd
- Frank
NiMH are fine too, but I agree that alkalines are pretty lame due to their internal resistance. The Sanyo Enerloops are great if you need a battery that will hold it's charge for long periods of inactivity. The Sanyo green label batteries that you can get from Thomas Distributing are extremely durable and are what I use for my flashes and P&S camera. The green lable batteries are what manufacturers use to build bigger battery packs, so they are more rugged and their capacity can be expanded beyond their 2500mah rating with a good charger, like the Maha MH-C9000. Most of my green lables are over 3000mah after a few cycles on the C9000...
Old Feb 9, 2008 | 02:22 PM
PimpCL23's Avatar
contrarian in fashion
duracell
and have u cleaned that lens yet???
Old Feb 10, 2008 | 10:40 PM
BIGTUFFGUY's Avatar
2003 TL-S A-SPEC
i just got four energizer 2500mah for my Canon 580ex II flash. I took ~300 photos with it at an event and it still cycles immediately.
Old Feb 10, 2008 | 10:50 PM
leftride's Avatar
i want to ride my bicycle
i have been using Sony NiMH batteries, no problems so far. the 15 min charger is nice.
Old Feb 11, 2008 | 04:14 AM
asianspec's Avatar
Originally Posted by PimpCL23
duracell
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
steve
Sep 30, 2015 09:23 PM
mars
Sep 28, 2015 11:03 AM
jmaxima03
Sep 27, 2015 10:22 AM
