Raw vs Jpeg
Raw vs Jpeg
I got a Canon T1i a few months ago and so far I have the kit lens and a 50mm F/1.8 that I have been playing around with. A few of my co workers say that I should be shooting everything in RAW. So far I haven't really seen any benefit of RAW. It takes longer to write to the card and can take a long time to convert the pics to JPEG on the computer. A few pics I took the brightness was off so I altered that on the file but that's something I could do with the JPEG as well.
Im sure there is a good reason for them or else it wouldn't be there. So why should I continue to shoot in RAW?
I would say to experiment first with raw and form your own opinion. Some here are well versed on this, and am sure they'll be able to enlighten you much more. Congratulations on your new camera
If you don't spend any time in post-production, then go with jpg. But, if you want to tweak more.. then RAW is the way to go. I shoot in RAW, but understand it's not the solution for EVERYONE.
I've read and hear a lot on this subject being new to photography. It seems if you want to edit every picture shoot raw. I also heard that if your shooting tons and tons of exposures and you don't want to edit them all shoot jpeg.
I just watched "a day with Jay Maisel" and when asked what he shot he said jpeg + raw. Asked why he shot raw, he said "because everyone told me I had to."
When I switched from Canon to Nikon, I shot jpeg+NEF for over a year. I kept deleting the jpegs after I processed the NEF files.
If I have a lot of images that I want to process at once, I use Lightroom, using the same setting for all.
A picture is a thousand words - here is an example that I shot back from yellowstone. Typical high dynamic range scene, exposed for the sky.
The jpeg looked like this:
The RAW, after adjusting brightness/shadows:
Try downloading the first jpeg and try to adjust it to get the second. It's not going to happen. I could give another example for the other huge RAW advantage - adjusting white balance. Infinitely easier and real looking with RAW.
That being said, If you do very little adjustments to your pictures after the fact, then RAW doesn't gain you that much versus superfine Jpeg. So a pro who knows how to set their camera correctly may find the RAW overhead needless.
A reasonable compromise is to shot jpegs most of the time, but in 'tougher' situations (tricky lighting, usually) shoot RAW.
- Frank
Lightroom 3... one of the best things I've bought (for photography), ever...
I've never been able to push my brightness that far.
Even trying to save very underexposed pictures (aka not black) can lead to some really off colors.
RAW is fantastic and a life saver sometimes, but it's not magic.
- Frank
everyone who has asked me raw vs. jpeg, I say if you aren't going to touch every image you want in PP then shoot jpeg.
a jpeg SOC is going to look 'better' than a raw SOC.
to my understanding a jpeg file has 8 bits per color channel.
that allows 256 brightness levels.
when you goto a 12 bit RAW, that gives you 4,096 brightness levels
and 14 bit raw gives you 16,384 brightness levels.
You know, I've actually never tried that! Here's side-by-side:
Attachment 118139 Attachment 118140
(RAW, Edited RAW, Edited JPG)
Thanks for the tip, I'll need to try this on a few other photos
So, to the OP - yet another reason to shoot RAW!
You should have any problems opening a RAW file with CS5 for a 60D file. You my need to upgrade Adobes Camera RAW that has the latest camera profiles if you haven't done that. From what I can tell you should be using Camera RAW 6.2.
I take primarily RAW. Although I do also shoot jpeg basic to a Eye-Fi card in my second card slot on my camera to quickly send pictures to my iPad.
I process just about all my pictures it seems. One thing I do it just leave the white balance set on the camera and adjust in ViewNX2. In Understanding Exposure by Bryan Peterson, he mentioned that for outdoor shots, he always sets the white balance to Cloudy. It is a great tip and I always make the adjustment PP. That would not be possible with Jpeg and if I forgot to change the white balance on the camera I would be losing out.
You said: Still underexposed, but that probably wouldn't be possible with JPG.
What jupitersolo suggested was actually trying it.
I.e. open up your first image above (i.e. https://i.imgur.com/bZnua.jpg)
and edit that and see what you can get. That basically emulates what you wuold have gotten if you shot jpeg to begin with.
I'm not sure what you did but there's no way you got 'Edited JPEG'.
- Frank
RAW....exclusively. On both my D3 and GF1.
My iPhone shoots jpegs...so I'm locked into that.
I put everything through post, so RAW is the way to go for me.
I also feel that RAW + jpeg is such a waste of space...but I do understand the need for certain applications.
I have been shooting raw + jpeg and can get a decent amount of pics on my 8g card. I will probably switch to raw only but the jpeg's are nice for my wife when she wants to email the pics to her family instantly after taking them
I had the same problem as you by the way, and I also shoot with a D7000. Jupitersolo was right on. I updated LR3 and it now imports the RAW images fine.
ITSJESTER
17
12-06-2018 02:29 AM
