Cameras & Photography Because there aren't already enough ways to share photos...
Raw vs Jpeg
Old Aug 15, 2011 | 11:47 AM
spdy0001's Avatar
I now drive an accord....
Raw vs Jpeg
I got a Canon T1i a few months ago and so far I have the kit lens and a 50mm F/1.8 that I have been playing around with. A few of my co workers say that I should be shooting everything in RAW. So far I haven't really seen any benefit of RAW. It takes longer to write to the card and can take a long time to convert the pics to JPEG on the computer. A few pics I took the brightness was off so I altered that on the file but that's something I could do with the JPEG as well.
Im sure there is a good reason for them or else it wouldn't be there. So why should I continue to shoot in RAW?
Old Aug 15, 2011 | 12:02 PM
jupitersolo's Avatar
nnInn
Want to see the benefit of shooting RAW? Take a look at the Post Processing Thread.
jpeg= the camera telling you how the image should be.
RAW= You making the decision how it should be.
Old Aug 15, 2011 | 12:27 PM
LKLD's Avatar
I've been Canonized ;)
Just use "save as" and choose jpg., takes about 3 seconds. I only use raw myself, using Photoshop 5 to post process (PP). I find that you have more control of all aspects of how you make adjustments to the photo. Jpg. format is a compression form used for internet viewing and printing ( I prefer tiff. for printing). Raw isn't compressed, and holds all info that your sensor grabbed.
I would say to experiment first with raw and form your own opinion. Some here are well versed on this, and am sure they'll be able to enlighten you much more. Congratulations on your new camera
Old Aug 15, 2011 | 12:37 PM
is300eater's Avatar
I Shoot with a Camera
I don't think I would even bother using a dSLR if I couldn't shoot RAW... I'd just use a p&s
Old Aug 15, 2011 | 12:57 PM
synth19's Avatar
If you don't spend any time in post-production, then go with jpg. But, if you want to tweak more.. then RAW is the way to go. I shoot in RAW, but understand it's not the solution for EVERYONE.
Old Aug 15, 2011 | 02:14 PM
nnInn
It can take a long time, but most of what you shoot, you might not mess with.
Old Aug 15, 2011 | 02:42 PM
spdy0001's Avatar
Thanks for the info!
Old Aug 15, 2011 | 05:41 PM
Q1911's Avatar
I've read and hear a lot on this subject being new to photography. It seems if you want to edit every picture shoot raw. I also heard that if your shooting tons and tons of exposures and you don't want to edit them all shoot jpeg.
I just watched "a day with Jay Maisel" and when asked what he shot he said jpeg + raw. Asked why he shot raw, he said "because everyone told me I had to."
Old Aug 15, 2011 | 05:48 PM
nnInn
When I switched from Canon to Nikon, I shot jpeg+NEF for over a year. I kept deleting the jpegs after I processed the NEF files.
If I have a lot of images that I want to process at once, I use Lightroom, using the same setting for all.
Old Aug 15, 2011 | 05:49 PM
is300eater's Avatar
you can also shoot RAW + jpeg... and just decide later which ones you want to PP... but make sure you have a lot of memory because RAW + jpeg will use up a lot
Old Aug 15, 2011 | 06:24 PM
ChodTheWacko's Avatar
Moderator Alumnus
To be a bit more specific, RAW files basically contain much more data than jpegs. This is why they are huge. Yes, you can adjust the brightness of jpegs. But you can adjust brightness MUCH more with a raw file.
A picture is a thousand words - here is an example that I shot back from yellowstone. Typical high dynamic range scene, exposed for the sky.
The jpeg looked like this:
The RAW, after adjusting brightness/shadows:
Try downloading the first jpeg and try to adjust it to get the second. It's not going to happen. I could give another example for the other huge RAW advantage - adjusting white balance. Infinitely easier and real looking with RAW.
That being said, If you do very little adjustments to your pictures after the fact, then RAW doesn't gain you that much versus superfine Jpeg. So a pro who knows how to set their camera correctly may find the RAW overhead needless.
A reasonable compromise is to shot jpegs most of the time, but in 'tougher' situations (tricky lighting, usually) shoot RAW.
- Frank
Old Aug 15, 2011 | 06:27 PM
is300eater's Avatar
Lightroom 3... one of the best things I've bought (for photography), ever...
Old Aug 15, 2011 | 06:59 PM
einsatz's Avatar
I miss my 03 CL-S :(
I think my camera is one of the best things I've bought for photography
This made the rounds on the Internets a while back:
Old Aug 15, 2011 | 07:21 PM
Moderator Alumnus
Is that one legit?
I've never been able to push my brightness that far.
Even trying to save very underexposed pictures (aka not black) can lead to some really off colors.
RAW is fantastic and a life saver sometimes, but it's not magic.
- Frank
Old Aug 15, 2011 | 07:37 PM
is300eater's Avatar
you know what I meant
Old Aug 15, 2011 | 09:08 PM
einsatz's Avatar
Here's an example of a shot I found in my LR library that I just spent 5 minutes on...
Before:
After:
Still underexposed, but that probably wouldn't be possible with JPG.
Old Aug 15, 2011 | 09:37 PM
nnInn
Process it as jpeg, as is and then try to pull it out.
Old Aug 15, 2011 | 10:32 PM
leftride's Avatar
i want to ride my bicycle
this.
everyone who has asked me raw vs. jpeg, I say if you aren't going to touch every image you want in PP then shoot jpeg.
a jpeg SOC is going to look 'better' than a raw SOC.
Old Aug 16, 2011 | 12:03 AM
Mizouse's Avatar
to my understanding a jpeg file has 8 bits per color channel.
that allows 256 brightness levels.
when you goto a 12 bit RAW, that gives you 4,096 brightness levels
and 14 bit raw gives you 16,384 brightness levels.
Old Aug 16, 2011 | 01:10 AM
tmnhs81's Avatar
+1. I am not as hard core as some of you guys here but I love Lightroom 3. Someone posted link to lighroom 3 $150 off last week!
Old Aug 16, 2011 | 05:59 AM
einsatz's Avatar
You know, I've actually never tried that! Here's side-by-side:
Attachment 118139 Attachment 118140
(RAW, Edited RAW, Edited JPG)
Thanks for the tip, I'll need to try this on a few other photos
So, to the OP - yet another reason to shoot RAW!
Old Aug 16, 2011 | 06:55 AM
TRIOD3SIGNS's Avatar
SHAWD 04TL is in
OK... here a noob question for yall RAW pros... I am having the hardest time (impossible) opening my CR2 Raw files in PS CS5. What gives? cant open in iphoto either.
Camera is a Canon 60d
Old Aug 16, 2011 | 08:20 AM
nnInn
You should have any problems opening a RAW file with CS5 for a 60D file. You my need to upgrade Adobes Camera RAW that has the latest camera profiles if you haven't done that. From what I can tell you should be using Camera RAW 6.2.
Old Aug 16, 2011 | 10:39 AM
2001AudiS4's Avatar
I just bought it an got it pretty cheap using my girlfriend's teacher discount
Old Aug 16, 2011 | 11:02 AM
2001AudiS4's Avatar
I take primarily RAW. Although I do also shoot jpeg basic to a Eye-Fi card in my second card slot on my camera to quickly send pictures to my iPad.
I process just about all my pictures it seems. One thing I do it just leave the white balance set on the camera and adjust in ViewNX2. In Understanding Exposure by Bryan Peterson, he mentioned that for outdoor shots, he always sets the white balance to Cloudy. It is a great tip and I always make the adjustment PP. That would not be possible with Jpeg and if I forgot to change the white balance on the camera I would be losing out.
Old Aug 17, 2011 | 05:32 PM
Moderator Alumnus
Wait, what?
You said: Still underexposed, but that probably wouldn't be possible with JPG.
What jupitersolo suggested was actually trying it.
I.e. open up your first image above (i.e. https://i.imgur.com/bZnua.jpg)
and edit that and see what you can get. That basically emulates what you wuold have gotten if you shot jpeg to begin with.
I'm not sure what you did but there's no way you got 'Edited JPEG'.
- Frank
Old Aug 17, 2011 | 08:10 PM
einsatz's Avatar
Ooooh... I misunderstood his suggestion. I thought he said edit it as RAW as much as you can, then export as JPG, then import the JPG and edit as JPG.
Haha I'm an idiot. Yeah if I open up the original and edit as JPG the best I could do was this:
Old Aug 17, 2011 | 08:19 PM
Thanks gentlemen, I'm shooting in RAW this weekend.
Old Aug 17, 2011 | 11:30 PM
Sarlacc's Avatar
The Third Ball
RAW....exclusively. On both my D3 and GF1.
My iPhone shoots jpegs...so I'm locked into that.
I put everything through post, so RAW is the way to go for me.
I also feel that RAW + jpeg is such a waste of space...but I do understand the need for certain applications.
Old Aug 18, 2011 | 07:33 AM
^i'm learning from the best.
Old Aug 18, 2011 | 11:45 AM
spdy0001's Avatar
I have been shooting raw + jpeg and can get a decent amount of pics on my 8g card. I will probably switch to raw only but the jpeg's are nice for my wife when she wants to email the pics to her family instantly after taking them
Old Aug 18, 2011 | 12:14 PM
nnInn
I leave to D90 on NEF+jpeg because that's the camera the wife uses and she wants instant access to the pictures. Then I get the NEFs, if I want to process them.
Old Aug 18, 2011 | 12:24 PM
Sarlacc's Avatar
The Third Ball
My wife knows she has to wait for me to process
Old Aug 22, 2011 | 09:49 AM
LKLD's Avatar
and that's never fast enough, is it? At least, not in my case.
Old Aug 22, 2011 | 10:08 AM
Here's a noob question.....
LR3 doesnt recognize my .NEF's
how do I open them!!?!?!?!??!?!
Old Aug 22, 2011 | 10:20 AM
nnInn
Make sure you have the latest version of LR3, which body you shooting with?
Old Aug 22, 2011 | 12:15 PM
Sarlacc's Avatar
The Third Ball
As long as SHE can see the pics whenever she wants as I'm working on them, she's fine.
With the exception of this last trip, I usually have them done within a day anyway.
Old Aug 23, 2011 | 08:13 AM
I'll have to update LR3 when I get home, I most likely dont have the most current version.
I'm shooting with a D7000
Old Sep 2, 2011 | 12:50 PM
ttk5's Avatar
Vancouver B.C.
great thread guys. really learned alot
Old Sep 2, 2011 | 12:59 PM
2001AudiS4's Avatar
I had the same problem as you by the way, and I also shoot with a D7000. Jupitersolo was right on. I updated LR3 and it now imports the RAW images fine.
ITSJESTER
17
Dec 6, 2018 02:29 AM
tj19855
Dec 5, 2016 09:16 PM
knight rider
Mar 4, 2016 08:59 AM
bailey24
Nov 21, 2015 08:43 PM
Miyagi__
Sep 22, 2015 12:47 AM
