moon shots
moon shots
how do you take moon shots? I've seen peoples pictures where you can clearly see the craters in the moon
anyways here is a picture i took today
its a 100% crop so i think the exif info is gone, anyways heres what i used
300mm, 1/60 sec, F/5.6, ISO-400, Manual Exposure Program
one question is, how do you meter the moon? cause when i would take pictures w/ the exposure level at 0, metering off the moon it would come out over exposed, ex.
yea i know there is glare, that was from the UV filter, i took it off after this shot
300mm, 1/30 sec, F/5.6, ISO-1600, Manual Exposure Program
and what i did in the 1st shot, the camera was telling me that the picture was going to turn out really underexposed (blinking at -2)
if you want to see the actual picture not crop then here is the 1st one
and for the hell of it was messing with my tables yesterday and took a picture of it
140 mm, 1/30 sec, F/8.0, ISO-1600, Manual Exposure Program
(yes i know the handle for the needle is broken off)
here's a picture from POTN (hopefully it's okay if i post it, not my picture), but he was using massive tele.
http://www.casciola.com/pics/moonSigmaStack_3481.jpg
original link:
http://photography-on-the.net/forum/...d.php?t=265979
original link:
There's a trick to exposing the moon properly...
...use a calculator: http://www.shaystephens.com/moon_calc.php
Actually, I use the calculator to get me in the ballpark, then I still bracket a few frames.
Not too surprisingly, the best way to get Moon pictures is through a telescope. What a lot of people don't realize, however, is that you don't have to go nuts doing it. The Moon is bright enough that you generally don't have to worry about tracking mounts and so forth. There are even products available that allow you to couple a digicam directly to a telescope eyepiece (link below). This type of thing is known as afocal imaging. You're just using a digicam to look through the telescope the same way that you would with your own eye.
If you want to use an SLR to shoot the moon with a telescope, then you more or less have to do it with the SLR at prime focus. This is where you use the telescope as the camera's lens. This kind of imaging can quickly become a major PIA, even when shooting the Moon.
http://www.scopetronix.com/dtsystems.htm
I've got a copy of DSLR Focus that is designed to assist focusing with telescope, but the only problem is it won't talk to a 30D. It's fine for a 20D or a Rebel, but the guy hasn't issued an update for anything newer. He is still taking people's money though... Me =
http://www.stellar-international.com/digitalsf6.html
I have one and it worked very well in the three times I've actually used it.
original link:
original link:
kinda hard to top that!
Well if it's for Chinese New Year then I guess you're excused. Otherwise a full moon generally makes for boring pictures. It's the astrophotography equivalent of shooting outside during the day at noon.
k i tried again today, and wow that calculator works out really well, but what i want to know is how would you meter that w/o the calculator? im sure the calculator is made from someones metering off the moon, anyways...
100% crop
300mm, 1/125 sec, f/8, ISO-200, Manual Exposure Program
(i really dont know why pbase makes it off that i use program mode when i don't)
resized
BTW i absolutely LOOOOOVE IS, all my moon shots were taken hand held
i suppose they would've came out sharper w/ a tripod thou
100% crop
resized
I didn't comment because I'm completely spoiled by all the moon images I've seen that are taken through telescopes. For handheld with a camera lens, those are pretty good.
If you feel like some experimental image processing, go into the channels of your image and then turn off the red and blue so that you're only looking at the green channel. Select all, and then copy/paste into a new image file. Lastly, do a basic levels adjustment. It may sound complicated, but it takes less than five minutes and usually results in a notable improvement for most Moon images. The resulting file from this is technically a greyscale image, but the Moon has so little color to begin with, that hardly anyone will ever notice.
BTW, if you try tripod shots of the Moon, be sure to also use mirror lockup. The Moon has so much fine detail that even shutter speeds like 1/125 can sometimes benefit from MLU.
Biggest and Yellowest(!?) Moon I have ever seen
Few months ago, on the way back from a local mall, I saw the biggest moon ever..
almost looking like a UFO..
Thank god I had my camera with me.
First pic is with full auto setting i believe..
and second, third shot are on shutter speed priority.
cool shots, moon shots are definitely not a trivial shot because people think that they need a long exposure.
Here are some tips (from my scott kelby book):
full manual
f/11
1/250
zoom is tight as possible 200mm+
and a tripod
full manual
f/11
1/250
and a tripod
hmm... im thinking there isnt going to be a moon visable for chinese new year, the full moon was a few days ago and chinese new year is on the 18th
anyways its been really cloudy lately so i couldnt get the full moon, this is the next best i could do, i was driving to my friends place saw the moon and pulled to the side and took a few quick shots of it
1/125s f/8.0 at 300.0mm iso200 manual mode
http://aa.usno.navy.mil/data/docs/RS_OneYear.html
sweet site, so pretty much id only be able to catch the moon during the day time or the first moments of night time, better start scouting out good areas to capture it
you would think that they would program in when daylight savings is and adjust for that
MrHeeltoe
20
Feb 23, 2023 01:54 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
