I totally agree with the whole investment thing, it's never an investment... but I think when people use the term "invest in ______" they are referring to committing or the commitment into a mount... I don't think anyone actually expects a financial return on any purchase
I know, it's just a term. But people have used it in monetary terms with the camera gears they own. Just one of those things, I'll always comment on.
Just like when people say "I've got a lot invested in the car..."
Yea if I sold all my gear I would only be able to afford just a new body.... So no thanks
The only way to turn over your gear without losing your ass, monetarily speaking, is to buy used or refurbed. I can sell all of my stuff with almost NO loss because I did just that. In fact I could probably sell some specific pieces and make some $$ based on what the current used prices are.
I'm just not emotionally attached to canon so I always have my eye on "better" tools.
One of the hopes people had for the Nikon D810 was that it would feature 4K video, but even though Nikon made it obvious in the press materials that this camera is a capable video machine, the rumored 4K capability never came to fruition.
You can understand, then, why we’ll suggest you take this next rumor with a grain of salt. Nothing like getting our hopes up only to have them dashed.
According to Canon Watch, a tipster has told them that the Canon 5D Mark IV, which is rumored to arrive in early 2015, will sport 4K video capabilities. To be fair, it seems more likely that Canon will implement the feature than Nikon (given their history as a leader in DSLR video) but we’re still trying not to get our hopes up.
The rumored announcement is still a ways away, so keep checking back in the interim and we’ll be sure to update you as rumor sites reveal more of the camera’s potential specs.
(via Canon Watch)
Image credits: EOS 5D Mark III Body by Norio NAKAYAMA
Just remembered this, and I didn't mean new as in brand new in box, just new as in a newer body that what I have.
Canon EOS 7D Mark II Specifications Confirmed
SEPTEMBER 11, 2014 CANON 7D MARK II FOLLOW ON OUR FORUM
Our specifications for the EOS 7D Mark II look to be confirmed. You can get our full specification list here. There’s nothing really new here, other than the max ISO being 16000, which we thought this was a typo in our information and changed it in our spec list. The other new feature we see is the intervalometer. I expect to see this camera announced on Monday with availability in late October or early November.
Specifications
All metal body
Dust and weather resistant
GPS
20.2MP CMOS sensor
10 fps
65 AF point all cross type
Dual Pixel CMOS AF
EOS iTR Autofocus
Dual DIGIC6
Max ISO 16000
RGB + IR Photometry Sensor
Intervalometer
Our Full Specifications
Kit lenses: 18-135 IS STM and 15-85 IS (no STM)
CF, UDMA mode 7 + SD, UHS-I
GPS is in the camera
No WiFi
Fixed LCD, with no touch function.
20.2MP APS-C Sensor
Dual Pixel CMOS AF
Dual DIGIC 6 Processors
65 AF points “All Cross-type”. Dual cross on the center point.
f/8 on center point at least, could be on more points.
10fps
ISO 100-16000, ISO Boost mode 25600 and 51200 (updated this to 16000)
1080p/720p both get 60fps
Servo AF for video shooting.
Anti-flicker mode, eliminates flickers under flickering lights (e.g. fluorescent lamps).
Spot metering size 1.8%
Built-in flash
Intervalometer
Mic and headphones connectors
Can sync time between 7D II cameras.
Lens electronic MF
About 100% coverage OVF
New Battery – LP-E6N
New Battery Grip BG-E16
EF 400mm f4 DO IS
EF400mm F4 DO IS USM II Specifications
Total length 232.7mm
Weight is 2100 grams
Third generation DO lens
One large-diameter UD lens
One large-diameter aspherical lens grinding
Camera shake compensation effect of the four stages
SWC special coating
Dust and water resistant
EF 24-105 f3.5-5.6 IS STM
EF 24-105mm F3.5-5.6 IS STM Specifications (Google Translated)
One UD lens and two glass aspherical lens
AF and smooth quiet by stepping motor
Full-time manual focus
4 stop image stabilization
Maximum magnification is 0.3x
EF-S 24mm f2.8 STM pancake
Canon EF-S 24mm f/2.8 STM Pancake Specifications Google Translated
focal length conversion 38.4 mm
1 piece using high-precision glass molded aspherical lens
full-time manual focus
shortest shooting distance is 0.16 M
maximum magnification is 0.27X
22.8 mm thickness Weight 125g
Below is a rundown of what we’ve been told about the lens.
Smaller than the current EF 100-400 f/4.5-5.6L IS
Will retain the same aperture range of 4.5-5.6
Zoom ring design instead of push/pull
Similar design to the EF 70-300 f/4-5.6L IS (zoom ring at front of lens)
Lens hood is designed to make using polarizers easier
Lens hood will be ET-83D (from DCI)
New thumb screw design on the foot of the lens
Obvious optical, AF and IS improvements
Canon EF 100-400mm F4.5-5.6L IS II USM Specifications (Google Translated)
One fluorite lens, one Super UD glass
A newly developed coating (ASC)
Keith at Northlight wonders if this is actually means nano SWC coating?
3 modes of IS, the third is for sports photography
A minimum focusing distance of 0.98 m
Maximum magnification of 0.31 times
9 aperture blades
AF motor the ring-type USM
Rotational zoom, not push/pull
Zoom touch adjustment ring
Detachable tripod mount
Dust and weather sealing
Fluorine coating
The two high megapixel cameras, with and without an AA filter. Resolution is said to be 53mp (though the pixel count is not CR3)
The EOS Rebel T6i/750D.
EF 11-24 f/4L
EOS M3 Camera
Various PowerShot cameras
The long rumored high megapixel full frame Canon DSLR now finally coming, here is the first leaked image and specifications of the upcoming Canon EOS 5Ds / Canon EOS 5Ds R DSLR camera, the difference between Canon EOS 5Ds and 5Ds R is that 5Ds R has no low-pass filter.
Canon EOS 5Ds / 5Ds R specs:
I very rarely go above ISO 3200 - I'm usually around 320-800 or so - when I'm not at 100 that is - so the max of 6400 is completely OK with me. If I'm doing club photos (which I don't do too much these days) I'll entertain 1600-3200, as needed.
