Would like to replace factory sub in factory opening
Old Apr 8, 2005 | 11:17 AM
cM3go's Avatar
I have a 2004 TL and although the 8" sub is decent, in the overall scheme of things, it sucks for quality bass. I'm not looking to pound my ears out (i have a 12" Vega in the garage i could have put in if I really wanted to) nowadays I just want clean bass, that is louder, but not out of control. If I can, I would like to just put in a better 8" sub in the factory opening (I understand the sub will have to be free air, and not very deep (as the factory one isnt) which may make it difficult to find a sub for my request). I already know I will have to use a seperate amp as the factory one will not support the power of the new sub. Worst case scenario, I could go for a 10" in an enclosure that takes as little trunk space as possible. But I want to see what you guys have to say first.
Old Apr 8, 2005 | 03:05 PM
dark inspire's Avatar
El Presidente
as far as i know, your options for an 8" sub in the factory location are VERY limited. I think there used to be an 8" kicker, but it got discontinued. I'd suggest you get a 10" sub in a sealed enclosure and an aftermarket amp in the trunk, that would probably be ur best bet.
Old Apr 10, 2005 | 11:07 PM
elduderino's Avatar
VP Electricity
Lemme check on this and get back to ya : ) Tomorrow probably.
Old Apr 11, 2005 | 01:08 PM
elduderino's Avatar
VP Electricity
There's an 8" sub from Vifa in Denmark that has a real impedance of just under 6 ohms, a resonant freq of 26 (useful with infinite baffle), a QTS of .37 (also useful), and a total excursion of 12mm (xmax=6, which is one-way). Poly cone, rubber edge, means longer life in a R deck with UV exposure.
There's also a Peerless driver that is not as smooth sounding (Fs of 36 and QTS of .46 means peakier sound a little higher in the bass) , but has 20mm of travel. Deeper frame and motor though.. is there a depth restriction in this car?
Old Apr 11, 2005 | 01:27 PM
elduderino's Avatar
VP Electricity
Oh, either would be well under $100 bucks including shipping.
Old Apr 11, 2005 | 10:02 PM
SmoKeGray04's Avatar
9th Gear
if u replaced the factory sub wit an aftermarket sub and an aftermarket amp to power it.......would that affect the DVD-Audio 5.1 stuff at all?........meaning.....would it still function the same as before, just now with a louder, more powerful sub
Old Apr 11, 2005 | 10:08 PM
elduderino's Avatar
VP Electricity
If it's integrated properly, shouldn't make a diff...
Old Apr 12, 2005 | 02:27 AM
xaznperswaesonx's Avatar
from what i've heard from other TL owners .. they just use a 8" JL w(zero) and sounds great.
Old Apr 13, 2005 | 08:24 AM
cM3go's Avatar
Thanks elduderino, there is a depth restriction, which I will find out. and post here
Old Apr 13, 2005 | 08:35 AM
cM3go's Avatar
Upon searching in the 3G TL forum I found:
Originally Posted by andym22
Sub 8", cutout of 7.4" with 3.375" depth clearance, but there is a round cutout just below the speaker about the size of the magnet so that a deeper sub could be fit if the bottom hole is enlarged.
Also have you heard of this brand? It seems they have one that would work.
http://www.imagedynamicsusa.com/webs..._idq08dvc.html
Old Apr 15, 2005 | 02:19 PM
jpswanberg's Avatar
they have 2 subs that can work for ib, id and id max. the idq will not. the id max is much better ( and much more $). i don't think the id max has an 8 " model though. make sure you use a high pass filter (subsonic, or ultrasonic filter at its resonant frequency). 100 to 200 watts should be plenty for the id sub. go to www.sounddomain.com for pricing and feedback. jps
Old Apr 18, 2005 | 10:48 PM
cM3go's Avatar
Old Sep 5, 2009 | 08:45 PM
davewhodavedunn's Avatar
I need a link where to buy a sub to run off the oem amp that will fit with no cutting of anything. It needs to provide the best bass and cost eifficent...any ideas?
Old Sep 6, 2009 | 03:28 AM
DRASTIK's Avatar
how bout these?
http://www.crutchfield.com/p_130SW84...1D.html?tp=111
Old Sep 6, 2009 | 11:28 AM
looks good but how do you install the sub to the oem amp? anyone got pics?
Old Sep 7, 2009 | 12:11 AM
mattastick's Avatar
Originally Posted by DRASTIK
Bad idea... That sub's not designed to be used in an Infinite Baffle type setup. That's what your factory sub is. So if you're going to replace it, look for a sub that's meant for IB use.
Old Sep 7, 2009 | 04:01 AM
drunkenninja4305's Avatar
i got my 10" Boston sub in ported Boston box for $150 from Custom Sounds, and because the salesman was nice, he gave me a 2-channel, 1,000 watt Exile amp for $200 instead of $300 (original price 400). the whole set cost me 380 including tax
installed everything myself, and i am very satistied with what i got, sound quality is great, the single 10in sub is strong enough to shake up my whole car if turned up high, Boston really lives up to their reputation
Old Sep 7, 2009 | 10:39 AM
I need some install pics of how to install the sub in the oem sub area
cycdaniel
Dec 17, 2019 10:58 AM
TLDude876
Dec 28, 2016 03:18 PM
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
scionxb3003
Oct 2, 2015 05:50 PM
asahrts
Sep 4, 2015 05:55 PM
