wires for sub
Old Jan 4, 2004 | 06:20 PM
soccerbenk's Avatar
wires for sub
i was wondering after you get the wire that comes from the headunit for the sub; is this already amped or is this preamped and also what did u do for wiring tot he trunk and how did u get the wires back into the trunk?
Old Jan 4, 2004 | 10:41 PM
soccerbenk's Avatar
anyone?
Old Jan 5, 2004 | 09:42 AM
Scott P's Avatar
Mobile Elec. Guru
i am assuming you are talking about adding an aftermarket sub to the factory headunit. if this is the case then this is what you need to do: The amp that will power the sub needs 3 things Constant power, switched power and ground. You can get the ground in the trunk by touching it to bare metal back there. The switched power you can get from behind the factory radio, and the constant power will need to come directly from the battery. There wasn't much space in the footwells to drill a new hole in the firewall when i ran my constant from the battery so i used a pre-existing grommet. all you have to do from there is just run it along the side of the car and under the back seat to get it into the trunk. you can do this really however you see fit since you would know best what kind of look you are going for. let me know if you have any more questions.
Old Jan 7, 2004 | 11:08 AM
soccerbenk's Avatar
what do u use for the bass signal from the unit can u just use the wire that already goes back to the stock woofer?
Old Jan 7, 2004 | 11:52 AM
If you remove the back seat, the half with the center rest, there's an amp on the passenger side, you can tap into those wires if you plan to keep the sub or you can disconnect the wiring harness and plug your own wires into it to give signal to your amp. I do not remember the wire colors, I believe they are blue and orange/brown. But there are only 2 wires going into it.
Old Jan 7, 2004 | 12:20 PM
soccerbenk's Avatar
how do you take out the back seat?
Old Jan 7, 2004 | 06:40 PM
soccerbenk's Avatar
any one?
Old Jan 8, 2004 | 12:25 AM
Iggy's Avatar
Run a search,
This has been discussed extensively.
Cheers
Old Jan 8, 2004 | 04:02 PM
soccerbenk's Avatar
i actually cant find this any where searching mabye im jus really bad at using the search any help?
Old Jan 9, 2004 | 07:20 PM
fsttyms1's Avatar
here check out this link it has the wire colors for you
http://www.acura-tl.com/forum/showth...threadid=68321
the rear seat is bolted in. if you stck your hand inbetween the backrest and the cussion by the belt buckles (the part that hold the seat belt) there should be bolts in there. i cant remember off my head but i think 1 on each side. then the cussion should lift up. the front part of the cussion just clips in so just give it a tug. then you should see the rear bolts and it then lifte straight up
Acura604
20
Aug 5, 2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
