This wire must be critical
Old May 24, 2007 | 04:55 PM
broly's Avatar
HonGod - Nature, Nurtured
Hi guys,
I have a wire that's not connected and it's for my sound system since the labelling says AMP on one line surrounded by 2 japanese characters on each side
then on the next line it says CONTROL +B
XXAMPXX
CONTROL +B
I think since this wire is unplugged my stereo is not turning on and it seems to be the problem since it's not been powering on and it's been sitting in my trunk (Thanks alot acura techs for fixing my A/C but not putting this wire back in!)
Anyone know?
It's a white 2 rows of 6 double pins (one larger pin and smaller) and on the other side is a female rounded connector with 13 pins (3 rows of 4, one single pin above them) and a squared indent opposite of the 1 pin and the labelled wire which i said is above which is blue and white in color and has a plastic casing over it and seems to fit something cylindrical.
/ white/blue wire
white connector -
\ cylindrical wire that has alot of wires going to it
thanks
Old May 25, 2007 | 08:16 AM
feuss2's Avatar
10001110101
Are you talking about a +12V low current (definitely under 1A, but probably more like 300mA) line that's used just to click over a relay in an external component? Lots of amps have this input because it allows a "soft power-on" where the full current that the device needs is not abruptly switched on an off (causing a pop). Without this your device may have power, but does not "know" to turn on. If this is the case, that wire should have +12V when the accessory setting is on (may require you to try to turn the head unit on to) but it would be shut off when the car is completely off...
Old May 25, 2007 | 09:50 AM
broly's Avatar
Yeah it seems critical
but where do I connect it ?
Old May 25, 2007 | 04:14 PM
fsttyms1's Avatar
Does the EQ have the harnesses plugged in? The EX is behind the climate control area. Its a metal box.
Old May 25, 2007 | 04:58 PM
broly's Avatar
I haven't opened my dash yet, I'm this close to
I"m just wondering if this wire goes in the back or in the EQ
It must be this wire because I'm telling you man it just seems to fit the bill with hte above description since the deck itself has the dash lighting on it but doesn't turn on ...
Should I open my dash and look? Im' very computer saavy so I doubt alot of wires will discourage me.
LEt me know
thanks
Old May 30, 2007 | 02:27 PM
broly's Avatar
http://img181.imageshack.us/img181/5585/photo1fn4.jpg here's the pic
Old Jun 9, 2007 | 04:21 PM
broly's Avatar
bump, anyone ever seen that wire?
Old Jul 7, 2007 | 10:38 PM
tlguy99's Avatar
Team Anthracite Member
That's probably the remote turn on wire. It turns on the amp when the stereo is turned on, that way the Amp isn't always on. I would check the voltage coming out of the amp to see if its actually sending a signal to the speakers.
Acura604
20
Aug 5, 2017 12:55 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
